Camry vrs Sonata
by tblt44 - 01/28/20 07:50 PM
Parasitic battery draw.
by wtd - 01/28/20 07:49 PM
AAP clearance 2020
by GMguy84 - 01/28/20 07:34 PM
2017-2019 GLA 250 4-Matic vs BMW X-1
by HangFire - 01/28/20 07:20 PM
Good news for .300blk shooters
by The_Eric - 01/28/20 06:43 PM
‘16 Lexus GS350 vs ‘16 Lexus RX350
by miden851 - 01/28/20 06:19 PM
Stone guard removal
by dawgn86 - 01/28/20 06:09 PM
Craigslist is like a petty HOA now
by eljefino - 01/28/20 05:06 PM
Shoretel PABX - any experience?
by stockrex - 01/28/20 04:44 PM
Around Australia record in the 1970's
by sanoptic - 01/28/20 03:21 PM
Oil mixing...does density matter?
by LotI - 01/28/20 02:02 PM
Uh Oh. Subaru Front Halfshaft CV Going Bad
by ARCOgraphite - 01/28/20 01:25 PM
Help choosing the right oil
by CAJ1966 - 01/28/20 12:33 PM
Which cooler line is return?
by LeakySeals - 01/28/20 11:39 AM
New Havoline ProDS 0w20 boosted Moly?
by jayjr1105 - 01/28/20 10:59 AM
Diesel fuel pump, pump synthetic 40 weight?
by H20ham - 01/28/20 10:54 AM
Review: 2019 VW Passat Wolfsburg 2.0T
by wemay - 01/28/20 10:16 AM
Group 2 mix with Group 4
by ridgerunner - 01/28/20 09:50 AM
Power Steering Fluid for 54 Chevy
by ThomasJ49 - 01/28/20 08:54 AM
indigo2020, Towkid, denor, Jubaxtreme, CAJ1966
70551 Registered Users
104 registered members (afaisalkk, adams355, Anthony, 14Accent, 2004tdigls, 55hambone, 12 invisible), 3,023 guests, and 14 spiders.
Topics300,682
Posts5,181,055
Members70,551
Heavy duty/ high power block heater for gm v8 #5322412 01/14/20 12:14 PM
A
apollo18 Offline OP
A
Looking for a heavier duty/ more power block heater for my 2003 hummer h2, it has a 6.0l v8. I believe the current dealership installed block heater is a 400w? so I wanna get something bigger and maybe with more heating capability. It gets to -40 celcius and I would love the extra heat inside the cabin.
What do you guys recommend? And do all block heaters fit universally?
thx
Re: Heavy duty/ high power block heater for gm v8 [Re: apollo18] #5322430 01/14/20 12:39 PM
P
Pelican Offline
P
[quote=apollo18]Heavy duty/ high power block heater for gm v8
thx /quote]
Frankly I'd forget the block heater and install an inline coolant heater, they do cost more, but are way more efficient!
And you never have to worry about rust. grin
Re: Heavy duty/ high power block heater for gm v8 [Re: apollo18] #5322437 01/14/20 12:45 PM
R
ragtoplvr Offline
R
You have a V8 and can put a block heater on each side.
I would cardboard over most of the radiator in the winter.. this returns warmer water to the engine and also heats the transmission fluid too. Make sure the thermostat is good, get a good one, not the bargain china stuff if possible.
Most people use the heater on too high a fan speed this delays engine warm up. If you can warm up with the heater off or on the lowest fan speed. Then use no more fan speed than needed for comfort. You are better off with medium amount of HOT air than a lot of warm air.
Note that block heaters can set a trouble code. because of a disagreement between block and air temp at start up, the diagnostics think a sensor is broken.
Rod
Re: Heavy duty/ high power block heater for gm v8 [Re: apollo18] #5322455 01/14/20 01:06 PM
A
apollo18 Offline OP
A
thanks for the reply guys! i also want to find something that allows me to remote start and leave the heater plugged in until i come out to unplug it before i leave. thats why i think a block heater would be the best bet because i dont want to ruin a inline heater when i remote start
Re: Heavy duty/ high power block heater for gm v8 [Re: apollo18] #5322466 01/14/20 01:24 PM
Snagglefoot Online Content
Online Content
Have a look at Amazon.ca. Only problem is they don’t seem to post the wattage. Your GM dealer might be a good source. I had one put in by the dealer. They definitely needed a hoist to get to the freeze plug. The mechanic was not ready for the avalanche of coolant. There is still coolant in the block even if you drain it at the lower rad hose. Mine is also a 6.0. smile
If you want the job done right......do it yourself.
Re: Heavy duty/ high power block heater for gm v8 [Re: apollo18] #5322649 01/14/20 04:22 PM
W
WobblyElvis Offline
W
I had a frost plug type of block heater in a GM 305 many years ago. I'm sure it was 600 or 660 watts. Worked very well. You could install two of them totalling 1300 watts. That's a lot of juice!
Re: Heavy duty/ high power block heater for gm v8 [Re: apollo18] #5322677 01/14/20 04:51 PM
03cvpi Offline
Keep in mind most block heaters are thermostaticaly controlled and only allow for a 60 to 70 degree temperature degree rise. The usual warm up to max output is 2 to 3 hours. Two block heaters will still cutoff at max output, but will bet at max heat twice as fast. Europe has a system that will use a block heater, trickle charger and cabin heater that is programmable to turn on at a particular time, but I have not seen them imported. They are also 220v.
Re: Heavy duty/ high power block heater for gm v8 [Re: apollo18] #5322683 01/14/20 04:57 PM
03cvpi Offline
Also most block heaters are safe with remote start, as they turn off at a specific temperature rise to prevent the heaters from melting the insulation. I have them in all my vehicles and only use them below 20 degrees farenheit and use remote start with no problem.
Re: Heavy duty/ high power block heater for gm v8 [Re: apollo18] #5322815 01/14/20 07:56 PM
P10crew Online Content
Online Content
OP on the 6.0 ls motor there is really only one place for a block heater. Wattage choice is limited because the element is so short. If I were you I’d get a 1000 watt zerostart circulating heater. It goes in one of the heater hose’s and 1000 Watts will have the block and heater core nice and warm after 2 hrs run time. I have mine on a timer and start it 3 hours before I head to work in the am.
Re: Heavy duty/ high power block heater for gm v8 [Re: apollo18] #5322886 01/14/20 09:11 PM
Dyusik Offline
I got one of these NOCO splitters installed, and run my block heater and a silicone oil pan heater on the same plug.
95 Cherokee 190K DELO XLE 10W30, XG8
04 YZF-R1 20K Frankenbrew 20w50ish, XG7317
14 RX450h 50k M1 AFE 0w20, WIX 57047
18 RAM 3500 10k Delvac 15w40, DBL7349
96 Cherokee
Re: Heavy duty/ high power block heater for gm v8 [Re: apollo18] #5322996 01/14/20 11:20 PM
U
userfriendly Offline
U
Pelican knows best.
Re: Heavy duty/ high power block heater for gm v8 [Re: Pelican] #5323380 01/15/20 11:31 AM
W
wag123 Offline
W
+1, a tank-type circulating heater is what you need, like this one...
https://www.amazon.com/Zerostart-2204037-Circulation-Diameter-Approved/dp/B002UNGL44/
Most of these devices do not have a pump, the coolant circulation is accomplished by convection (hot water rises). Notice that it must be installed vertically. It will not have any affect or negative ramifications for your remote start because the coolant flows right through it. This heater will warm up all of the coolant in the engine (both banks) and heating system (but not the radiator because the coolant doesn't get hot enough to open the engine's thermostat). When I used to use them I found that they didn't need to be left ON all night, so I put them on a timer. This will get you the immediate heat you are looking for.
