Duralast Max Ceramic Pads Photos!
by NASTI - 01/20/20 11:23 AM
expensive rotors
by Donald - 01/20/20 11:19 AM
3 Fram Ultra's Cut Open
by jetman - 01/20/20 10:31 AM
Standard Cab Commercial
by Duffyjr - 01/20/20 10:17 AM
The thin grease for firearms
by fnbrowning - 01/20/20 10:07 AM
Replace coil packs with spark plugs?
by jayjr1105 - 01/20/20 09:34 AM
Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
Oil ideas for 2 v6 fords and more
by kessellrun - 01/20/20 06:50 AM
Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
FCA and Foxconn partner on EV's
by OVERKILL - 01/19/20 08:55 PM
IIHS Crash pics of Full Size Trucks
by kstanf150 - 01/19/20 08:15 PM
Are Engine Splash Guards Really Needed?
by Mr_Luke - 01/19/20 08:14 PM
supertec cartridge filters
by super20dan - 01/19/20 06:17 PM
EAC1, Kronguy, jamespeter26, RSH, Bobjr94
70490 Registered Users
110 registered members (1978elcamino, amblerman, ABerns, AandPDan, 12 invisible), 2,866 guests, and 22 spiders.
Topics300,349
Posts5,173,916
Members70,487
Most Online3,825
Jan 19th, 2020
jump starter and lead-acid battery #5322399 01/14/20 12:04 PM
V
vicjo Offline OP
V
I just purchased a jump starter that warns that it must be used on lead-acid batteries only. I have a Rayovac battery. Are all car batteries lead-acid? The battery has on the label: part number SL175DT. If you need additional info please let me know.
Re: jump starter and lead-acid battery [Re: vicjo] #5322446 01/14/20 12:55 PM
Chris142 Offline
Not all automotive batteries are flooded. Some are AGM. But both are still considered lead acid. So I dunno.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: jump starter and lead-acid battery [Re: vicjo] #5322461 01/14/20 01:20 PM
T
tomcat27 Offline
T
I have seen some lithium ion batteries in cars. very pricey
2019 Cherokee, 2018 Jetta, 2014 Sentra, 2001 Camry, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: jump starter and lead-acid battery [Re: vicjo] #5322482 01/14/20 01:49 PM
M
mk378 Offline
M
Yes that's a lead acid battery. The warning label on the battery will specifically mention the hazards of lead and acid.
Re: jump starter and lead-acid battery [Re: vicjo] #5322543 01/14/20 02:53 PM
Duffyjr Online Content
Online Content
What is the brand name and model of the jump starter? Just curious.
89 GMC Sierra Advanced 5w30/51036 Wix
08 Lucerne CX Advanced 5w30/1040 Gold
18 Toro Super Recycler T5 10w30
Re: jump starter and lead-acid battery [Re: vicjo] #5322630 01/14/20 04:07 PM
Dave9 Offline
While I would advise following their directions, that kind of statement is more of a "we can't possibly know all the random things out there and can only test for our target market".
In general there is no problem using a jump starter with a peak voltage that is no higher than your alternator's peak. That ensures there is no additional stress on the electrical system. This is practically never an issue with a lead acid powered jump starter pack, but if you have some generic chinese jumper make to a low price point that has too many Li-Ion cells in series, that has the potential to risk your electrical system even if you do have a lead acid battery (but for example it is not taking charge or the battery terminals are too corroded, etc so the system still sees excessive voltage).
Re: jump starter and lead-acid battery [Re: vicjo] #5322727 01/14/20 05:46 PM
V
vicjo Offline OP
V
I have a JUMP-N-CARRY: JNC660
Re: jump starter and lead-acid battery [Re: vicjo] #5322937 01/14/20 10:08 PM
T
The_Nuke Offline
T
That jump pack will do just fine on your battery.
2012 Charger Pursuit aka "The Bacon Hauler"
- 5.7L + NAG1 (A5) + 2.65 (215mm)
Re: jump starter and lead-acid battery [Re: vicjo] #5323578 01/15/20 02:47 PM
V
vicjo Offline OP
V
OK, good to know.
