RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
30 monograde
by mpack88 - 01/21/20 10:15 AM
Extended life destroys copper?
by mpack88 - 01/21/20 09:49 AM
Project Farm Lucas transmission additive video
by 1978elcamino - 01/21/20 09:43 AM
1.8t 0w40, plus a situation.
by WMNN1988 - 01/21/20 09:25 AM
Mobil 1™ ESP X2 0W-20 US Availability
by TheIceStormof06 - 01/21/20 08:46 AM
Wire harness/connector
by Redright9 - 01/21/20 07:58 AM
Will You Jump Someone Else's Car?
by Gebo - 01/21/20 07:08 AM
NAPA Edge $20 A/R
by dblshock - 01/21/20 04:54 AM
8 Utes on test.
by Silk - 01/21/20 03:03 AM
Magnetic Socket Rails
by The Critic - 01/21/20 01:19 AM
Oreilly Select complete fuel system cleaner
by keantoken - 01/21/20 12:19 AM
Local Costco Has all Oils and Viscosities $10 Off
by SteveG4 - 01/21/20 12:14 AM
EBC Rotor Pictures
by BBDartCA - 01/20/20 11:28 PM
2012 Acura TSX Wagon
by WhyMe - 01/20/20 10:47 PM
reylafo, PastPresMike, RedBeard83, dfrybeck, ckinch1
70495 Registered Users
106 registered members (2015_PSD, 90crvtec, 1978elcamino, AlaskaMike, aircooled, 2011335d, 8 invisible), 2,241 guests, and 22 spiders.
Topics300,388
Posts5,174,772
Members70,495
Kitchen floor space between sub floor be filled? #5322290 01/14/20 09:05 AM
J
JLawrence08648 Offline OP
J
I'm putting in new kitchen cabinets and had to pull up some of the sub flooring under the sink and dishwasher plus a little. I had planned to put down vinyl planking directly over everything. The old floor is almost level with the new except for 1/32" ? 1/64" ? difference. I did my best to make a straight and accurate cut but there are minor gaps as you see in the picture. I really don't want to put down Luan plywood on the whole floor as an overlay. The gaps you see in the sub flooring will be under the cabinets or stove except for where you see the pencil, along there for about 8', your toes and feet will be. Can I pay the padded on the back of the vinyl planking over these cracks or should I fill in? And with what? I have Easy Sand 45 and Thinset.
IMG_20200114_094248.jpgIMG_20200114_094404.jpgIMG_20200114_100329.jpgIMG_20200114_100316.jpg
Re: Kitchen floor space between sub floor be filled? [Re: JLawrence08648] #5322316 01/14/20 10:14 AM
AZjeff Offline
Glue down or floating vinyl planks? We have glue down and it telegraphs every imperfection, very visible when the sun is at a low angle. Floating give specs on irregularities.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Kitchen floor space between sub floor be filled? [Re: JLawrence08648] #5322325 01/14/20 10:35 AM
demarpaint Offline
This might be of some help. Underlayment I used it on under the same circumstances you have and it worked perfectly.
God Bless Our Troops
Re: Kitchen floor space between sub floor be filled? [Re: JLawrence08648] #5322386 01/14/20 11:53 AM
O
ondarvr Offline
O
It totally depends on the exact flooring product you use, some rigid flooring may move over time.
Rigid will span the gaps, but if the floor is uneven use self leaving flooring compound under it.
On my last remodel I used luan in two rooms under the flexible vinyl, and self leveling compound on a few areas under the rigid.
Both turned out great and there is no distortion migrating through to the surface.
Re: Kitchen floor space between sub floor be filled? [Re: JLawrence08648] #5322421 01/14/20 12:29 PM
doitmyself Offline
I'll share a few of my lessons learned (mistakes) about 1/4 inch underlayment that Demarpaint linked to.
- For a glued down vinyl floor, my flooring store sold me CHEAP 4 x 8 luan underlayment which had dyes that migrated thru the adhesive and discolored the flooring about 5 years later. Too late to attempt some kind of warranty claim.
Use a quality job specific underlayment available in 4 x4 and 4 x 8 such as this: https://hw.menardc.com/main/items/m...yWarrantyandInstallationInstructions.pdf
It's pre marked for the fasteners and has no internal voids (denting)
- For fastening down the underlayment, don't use ring shank underlayment nails. From contraction/movement, I had nail heads that telegraphed into the flooring that became an eyesore.
Rent an underlayment stapler (manual or powered). The staples are glue coated and they countersink into the plywood.
Manual Stapler (cheap to rent) .......................................................................................................................................Countersunk staples don't show through the floor
[Linked Image from wirtzrentals.com] [Linked Image from renovation-headquarters.com]
Just my 2 cents from my experience and school of hard knocks. Don't cut corners.
Re: Kitchen floor space between sub floor be filled? [Re: JLawrence08648] #5322433 01/14/20 12:42 PM
F
Farnsworth Online Content
Online Content
F
Try Fixall I have used it to level, fill gaps, and it's good stuff. Becomes as hard as wood. Comes as powder, get at hardware store or home center. There is also concrete Fixall which is good too.
Re: Kitchen floor space between sub floor be filled? [Re: JLawrence08648] #5322440 01/14/20 12:47 PM
J
J
The vinyl planking she wants to buy has a rubber backing and it's flexible, you can bend it, you pick up one end and the other end bends to the floor. The vinyl planking will be floating as it is a click system. Most of the floor is adhesive backed vinyl squares except under the refrigerator, stove, sink, dishwasher. I pulled off the top vinyl squares which were over Luan fastened with staples, on top of that was indoor outdoor carpet we had laid years ago.
I have a 150psi, 4.5cfm @ 90psi compressor with nail guns for studs, 16 & 18 gauge, and a combo pin nailer/stapler if I need to go the Luan route, which I don't think, other than possibly filling the crack space. The floor is level other than a very very very slight edge and space at the edge of the cabinets where your feet would go.
Re: Kitchen floor space between sub floor be filled? [Re: JLawrence08648] #5322655 01/14/20 04:24 PM
marine65 Offline
I'm in the flooring business.
Any flexible vinyl planking is a waste of money.
Spend a little more and get an 8 MM product such as Shaws Lazio plus.
It will walk well,very tough surface and water proof.
It will cover small imperfections in your existing floor.
https://shawbuilderflooringsf.com/flooring/vinyl/details/lazio-plus-ve230/pecorino
2018 Hyundai Elantra GT black
2018 Hyundai Elantra GT silver
yup got two of them.
Re: Kitchen floor space between sub floor be filled? [Re: AZjeff] #5322672 01/14/20 04:41 PM
M
maxdustington Offline
M
You're fine dude, anything under 1/4" is nothing to worry about.
99 Toyota Tercel CE 5EFE/C151
Re: Kitchen floor space between sub floor be filled? [Re: Farnsworth] #5324387 01/16/20 11:56 AM
J
J
I've discovered through Custom Building Products they sold Fix-It-All to Tex-Rite. CBS retained the rights to sell it in California only and Tex-Rite sells Fit-It-All in only TX, NM, AZ areas.
Other suggestions?
How would CBS thinset or Easy-Sand 45 work?
