Do all synthetic oils act as a cleaner?
by Loobit - 01/18/20 08:26 AM
Mobil 1 ESP now sold in 5qt jugs
by Patman - 01/18/20 08:12 AM
Mobil 1 Extended Performance Oil Filters
by jrommelt - 01/18/20 08:08 AM
These the same?
by Bettez88 - 01/18/20 06:53 AM
MaxLife SB 10w40 on Sale
by Mad_Hatter - 01/18/20 04:27 AM
Walmart Oil Change?
by Talent_Keyhole - 01/18/20 12:50 AM
Bleh, mother’s gas furnace fan burned up
by Rmay635703 - 01/17/20 11:23 PM
Rotella gas truck vs Valvoline modern engine
by MoPowa - 01/17/20 09:25 PM
Afton Specification Handbook -- September 2019
by Gokhan - 01/17/20 09:04 PM
Old Retired Navy Commander
by KeithS_NW_Ohio - 01/17/20 08:58 PM
Mobil 1 EP vs Mobil 1 EP Truck & SUV
by jrommelt - 01/17/20 08:29 PM
Stick with Maxlife or go back to DW-1?
by jayjr1105 - 01/17/20 07:58 PM
Thread locker
by zzyzzx - 01/17/20 07:56 PM
A preppers tale
by Bluestream - 01/17/20 07:50 PM
19 Ram Rebel oil choices
by Schwifty - 01/17/20 07:35 PM
Is it impossible to get a loan for an older vehicle?
by FordBroncoVWJeta - 01/17/20 07:22 PM
Fridge and freezer oil test
by jkhawaii - 01/17/20 06:59 PM
2EHA, jonnyb433, kzbd, 54Robert, CPA1989
70464 Registered Users
103 registered members (4WD, 53' Stude, 14Accent, 55hambone, 54Robert, 5 invisible), 2,042 guests, and 16 spiders.
Topics300,274
Posts5,172,171
Members70,464
Most Online3,728
Jan 11th, 2020
Page 1 of 3 1 2 3
No mufflers #5322146 01/14/20 03:14 AM
2
2014_K5_Optima Offline OP
2
So, the previous owner of my vehicle cut the mufflers out and welded pipe in place, with some nice exhaust tips. For a 4 banger, it sounds mean. My concern is, I'm sure I'm losing back pressure, which from my current understanding, means that I'm also losing HP.
Question #1 - What long-term effects, on which components, will the lack of back pressure have?
Q #2 - What are some options to add back pressure without putting mufflers back on? I know some fellow bikers I've met have welded bolts, washers, etc. inside their short exhaust to compensate for the loss of back pressure.
Thanks in advance!
Re: No mufflers [Re: 2014_K5_Optima] #5322150 01/14/20 04:00 AM
Silk Offline
I don't believe in back pressure.
1987 BMW R65 - Penrite VTwin 20-50
2005 Nissan Expert - 5W-30 Castrol Edge
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: No mufflers [Re: 2014_K5_Optima] #5322151 01/14/20 04:03 AM
2
2
Care to explain why?
Re: No mufflers [Re: 2014_K5_Optima] #5322152 01/14/20 04:03 AM
L
Lubener Offline
L
I would be more concerned with the long term effects on your hearing and getting stopped by police for your excessive noise. Hopefully, a nice officer will convince you to change your thinking.
The "thinking" man's friend.
Re: No mufflers [Re: 2014_K5_Optima] #5322153 01/14/20 04:04 AM
2
2
I spent 6 weeks in New Plymouth for a previous employer by the way. You have a very beautiful country! I hope to go back some day!
Re: No mufflers [Re: Lubener] #5322154 01/14/20 04:06 AM
2
2
Lol, I'm not going to pay to put mufflers on if I don't have to. Haven't been stopped yet, I'm not obnoxious with it during sensitive hours. To each their own I suppose.
Re: No mufflers [Re: 2014_K5_Optima] #5322165 01/14/20 04:48 AM
B
Black_Thunder Offline
B
i think they make clamp on exhaust tips that have a couple baffles to quiet the exhaust a smidge and maybe add a little bit of backpressure.
if you do end up putting mufflers on, you can get either a turbo muffler or glasspack for not a lot of money.
the glasspack would only tone it down a little bit, but a turbo muffler would dampen it enough to be legal and they do give a nice rumble.
or you could always cut out a section of pipe some where intermediate and put in a section of small diameter pipe so going from stick size to small size back to stock size to add some restriction
I'd buy Callahan autoparts if I could.
Re: No mufflers [Re: 2014_K5_Optima] #5322170 01/14/20 05:15 AM
SteveSRT8 Offline
Noisy is not fast. The two are often confused.
What if everybody had loud pipes?
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: No mufflers [Re: 2014_K5_Optima] #5322172 01/14/20 05:19 AM
Q
quint Offline
Q
Whatever forum you are frequenting that perpetuates the blanket "engines need backpressure" claim is a forum where you want to log off and never return. Engines need proper breathing and an exhaust that's properly tuned and sized, i.e. tube diameter, for the amount of airflow the engine is capable of producing. And depending on the specific engine, that may mean smaller diameter piping for proper scavenging. Put huge pipes on a small engine and the airflow is going to be terrible because the exhaust velocity is going to be slow and the engine is going to have issues, usually being gutless on the bottom end.
My friend had a Dodge Ram a few years back, and towed his 25 ft boat with it. He then went all out and put a beautiful aftermarket full chrome exhaust on it, huge pipes, huge money, sounded absolutely incredible..... and now he couldn't tow his boat, it was like pulling a 30 ft camper with a Prius. He called me and said he thought he screwed something up, could I come look at it, he can barely tow his boat anymore. I took one look at it and thought these pipes belong on a Kenworth semi, not on a pickup. I said "where is your factory exhaust?" He showed it to me, I looked at the pipe size difference, and said "Put your factory exhaust back on". He reluctantly did. Then he was thrilled he did. The torque was back and he could tow again.
You can run lean, run rich, burn valves, run hot, induce detonation, and whole bunch of other undesirable things running an exhaust that is a bad match for the engine and how it is used, what cams it has, how its being fed fuel, what RPM range its running, and lots of other variables. Simply removing mufflers, putting on big pipes, welding in baffles and washers and other things just says that the person doing it doesn't really have a good understanding of exhaust tuning. Plenty of reading to be had on the web about this.
Re: No mufflers [Re: 2014_K5_Optima] #5322179 01/14/20 05:36 AM
F
fozzdesy2001 Offline
F
If the 4 banger has a catalytic converter it has backpressure. If it's supposed to have a cat but now your running catless then it probably has or should have a tune for the check engine light and performance. What is this 4 banger in any way?
2001 Subaru Forester S
Replaced with a 2006 Forester
2004 Subaru Forester XT
Death by deer. Replaced with 2003 Impreza Outback Sport (beater)
Re: No mufflers [Re: 2014_K5_Optima] #5322187 01/14/20 06:00 AM
A
atikovi Online Content
Online Content
A
Unless you are getting a check engine like for something like lean conditions, you'll be fine. Fiat Abarths come without mufflers too from the factory and they sound terrific.
[Linked Image from fototime.com]
Re: No mufflers [Re: 2014_K5_Optima] #5322201 01/14/20 06:26 AM
Skippy722 Offline
Quint nailed it on the head. If your engine has to work to push the exhaust out, like what happened when his friend put a massive pipe on his truck, the engine is now using power to push that exhaust out instead of putting it to the ground.
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: No mufflers [Re: atikovi] #5322266 01/14/20 08:23 AM
A
ARCOgraphite Offline
A
Being a Fiat tuner and fan from the 70's and early 80's ( Yugo GV too!)
I'm not a fan of that new abarth sound. , Also that's a turbo - which take a lot of energy from the exhaust.
I wonder if the OP car is a turbo?
If not, I would put a muffler on that pig! You will in time. Its get old fast.
Youth, hormones. Lots of testosterone, the "run through the forest gorilla" attitude dragging a branch making noise to show your station - Its actually in our DNA
To point, 4 strokes don't need "back pressure", they need proper scavenging, which means the " correct" sized pipes for the torque range.
Its resonance tuning - like organ pipes in church or ported subwoofer boxes. and its not just the primary length, the "collector" area air mass and velocity is critical too. Open headers make less power than say a header with a necked down 20" collector extension with a turnout.
The car will have a muffler soon.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: No mufflers [Re: 2014_K5_Optima] #5322273 01/14/20 08:39 AM
O
Oily_Thing Offline
O
What's the point of running without a proper muffler? Do you like to be annoying to others?
2020 Nissan Rogue SV AWD
2015 Dodge Durango Limited 3.6
Re: No mufflers [Re: 2014_K5_Optima] #5322285 01/14/20 08:57 AM
RDY4WAR Offline
Back pressure is a myth. It was most likely started decades ago when people would put bigger exhaust pipes on their car and lose a few hp. They mistakenly thought this meant the engine liked back pressure. In reality, the engine liked the higher exhaust velocity of smaller pipes while not being small enough to cause back pressure. It's a bit of a goldilocks zone.
I am considering no mufflers on my track car because 1) the class I race in doesn't require them, and 2) I have no way to run mufflers right off the headers without hacking at the frame. I would have to add intermediate pipes to extend back with a merge and put mufflers back near the rear axle. That adds weight, and this pig is already heavy enough. So... probably going sans muffler.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Page 1 of 3 1 2 3
