Repairing acid stained wheels
by IMSA_Racing_Fan - 05/25/20 12:30 AM
Collection of Euro Oils
by js1956 - 05/24/20 10:29 PM
00 grease in my brush mower
by Elkins45 - 05/24/20 09:55 PM
Coolant UV Dye - for without flushing
by Ndx - 05/24/20 09:10 PM
STP S8A C&P
by mpack88 - 05/24/20 07:50 PM
Aprons
by buck91 - 05/24/20 07:35 PM
Oil Additives for GDI engines
by Drew99GT - 05/24/20 07:21 PM
Memorial Day - Veteran's Cemetery
by JeffKeryk - 05/24/20 07:18 PM
CQ Blue, made by who?
by AJB0009 - 05/24/20 06:45 PM
recommended 5w30 for ticking and engine noises
by apollo18 - 05/24/20 06:29 PM
need new group 65 for my F-150, here's my choices:
by DirtyApe - 05/24/20 06:23 PM
Castrol EDGE cleaned my funnel
by AJB0009 - 05/24/20 05:29 PM
Metal Cloak FAD + Fox Steering Stabilizer
by 2015_PSD - 05/24/20 04:55 PM
Blue Driver OBDII
by Al - 05/24/20 04:50 PM
Coca Cola 600 at Charlotte Motor Speedway
by bdcardinal - 05/24/20 04:38 PM
Memorial day
by gman2304 - 05/24/20 04:33 PM
BBC_bias, rabblrouzr, Modoi, zx6rsi, Chumpchange
71522 Registered Users
29 registered members (Arrechera, daves87rs, buddylpal, DallasTexas, blufeb95, 6 invisible), 1,403 guests, and 41 spiders.
Topics305,824
Posts5,281,073
Members71,522
Page 1 of 3 1 2 3
Does this need replacing? #5321966 01/13/20 08:47 PM
M
Mr_Luke Offline OP
M
It's a little dirty, though the Prius it came out of was carefully maintained all its life.
[Linked Image]
2012 Toyota Prius C / 109k
Castrol Edge 0w20 FS
Federated PG4476F
Re: Does this need replacing? [Re: Mr_Luke] #5321969 01/13/20 08:52 PM
P
PowerSurge Offline
P
Change it.
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra and a few others
Re: Does this need replacing? [Re: Mr_Luke] #5321983 01/13/20 09:10 PM
JohnnyJohnson Offline
No its just broken in unless you care for your car.
2004 Corolla 140080
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77077
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Does this need replacing? [Re: Mr_Luke] #5321999 01/13/20 09:24 PM
H
hallstevenson Offline
H
How hard is it to replace ? Never mind, just watched a video.... Will take more time to empty the glove box. Since you have it out, I'd vacuum it and put it on my to-do list. It doesn't need changed just from visual.
Re: Does this need replacing? [Re: Mr_Luke] #5322019 01/13/20 09:45 PM
CR94 Offline
Nobody can tell for certain just by seeing the photograph. Very likely it's ok, though, and filters better than a new one would.
2011 Toyota Prius now at 110K
Re: Does this need replacing? [Re: Mr_Luke] #5322031 01/13/20 10:01 PM
K
Kira Offline
K
Air filter elements live in boxes above large chambers which have small entrance ports. This creates "velocity drops".
Larger particles fall away due to their mass.
Finer particles are left for the filter to catch.
I think they look cleaner after use than some filters.
Nobody says if dirt particles of different size fill a filter differently.
I don't know.....
The good thing is that regular maintenance factors in "doing it more often".
EXAMPLE: If you get a "Tearolater" oil filter you can extract some comfort from the likelihood of the next oil change being OK.
Re: Does this need replacing? [Re: Mr_Luke] #5322045 01/13/20 10:15 PM
O
OVERKILL Offline
O
Install a restriction gauge and then you'll know when the filter needs changing.
Re: Does this need replacing? [Re: Mr_Luke] #5322080 01/13/20 11:03 PM
slacktide_bitog Offline
Replace it smile
Re: Does this need replacing? [Re: OVERKILL] #5322171 01/14/20 06:15 AM
L
Lubener Offline
L
Between your restriction gauge and my airflow measuring tool, we should be able to determine if replacement is needed.
The "thinking" man's friend.
Re: Does this need replacing? [Re: Mr_Luke] #5322186 01/14/20 06:59 AM
AZjeff Offline
The way you put this sounds like it's an older car and this is the OEM filter. Why not change it out?
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, 0W-20 QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Does this need replacing? [Re: Mr_Luke] #5322202 01/14/20 07:28 AM
J
joekingcorvette Offline
J
Replace it since you have it out anyway.
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
Re: Does this need replacing? [Re: Mr_Luke] #5322329 01/14/20 11:44 AM
demarpaint Offline
I'd change it.
God Bless Our Troops
Re: Does this need replacing? [Re: joekingcorvette] #5322358 01/14/20 12:33 PM
W
WyrTwister Offline
W
Exactly . After all , how much money for a new filter ? ( Is this an engine air filter or a cabin air filter ? )
Wyr
God bless
Re: Does this need replacing? [Re: Mr_Luke] #5322439 01/14/20 01:46 PM
gathermewool Offline
The flow should be through the other end, right? How does THAT side look?
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (2nd OFI) (77,760mi, 3/7/20)
15 Legacy Premium FB25
Magnatec 0W-20 D1G2+ FU filter (2nd OFI) (54,621mi, 3/4/20)
Re: Does this need replacing? [Re: AZjeff] #5322464 01/14/20 02:23 PM
CR94 Offline
... Why not change it out?
How 'bout because there's no reason to do so? The engine won't be impressed.
Page 1 of 3 1 2 3
