Severe Service
by tiger862 - 01/27/20 08:53 PM
Platinum, Iridium, Ruthenium, oh my!
by Astro_Guy - 01/27/20 08:28 PM
Hit 200K miles today!
by SLO_Town - 01/27/20 08:20 PM
Valve Cover at 304849 miles
by Marco620 - 01/27/20 08:17 PM
Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T
by chinee - 01/27/20 07:11 PM
Quaker State deal
by JohnnyJohnson - 01/27/20 06:46 PM
A new deal on Castrol Edge EP 5W-30
by JohnnyJohnson - 01/27/20 06:37 PM
Burning smell from rear wheel
by 2010Civic - 01/27/20 06:01 PM
2017 VW Golf 1.8T - Valvoline 5w40 MST - 8,600 miles
by BurntMusic - 01/27/20 06:00 PM
Cost to rebuild a Ford 4R75E vs. new or used.
by atikovi - 01/27/20 05:26 PM
Autozone Clearance 85w140 gear oil 5 gal
by GON - 01/27/20 04:31 PM
Resonating Noise at 3000rpm
by tookien - 01/27/20 04:28 PM
Looking for Purolator Tech oil filter pics.
by Black_Thunder - 01/27/20 04:02 PM
2019 Mini Cooper Clubman S ALL4 Review
by oilpsi2high - 01/27/20 02:51 PM
The "Penny Challenge"
by ZeeOSix - 01/27/20 02:32 PM
2008 Highlander Battery Post Bolt Snapped
by maverickfhs - 01/27/20 02:31 PM
conventional wisdom rebuild axle or replace?
by NissanMaxima - 01/27/20 01:22 PM
will a thermostat gasket leak coolant into the engine?
by motor_oil_madman - 01/27/20 12:55 PM
IslandOil, 01VFR, M10, H20ham, Meletz
70544 Registered Users
135 registered members (01VFR, 4WD, 2015_PSD, 2003f7, 2009Edge, 330indy, 10 invisible), 3,267 guests, and 24 spiders.
Topics300,653
Posts5,180,312
Members70,544
Reciprocating air compressor oil Miles Stratus D ISO 68 #5321987 01/13/20 08:13 PM
dylanm Offline OP
Anyone familiar with Miles Stratus D ISO 68 synthetic diester-based compressor lubricant? Looks like a good quality synthetic lubricant for reciprocating air compressors. Have a Makita MAC700 that came with enough sample oil to fill it the first time. I've done the breaking in for the 20 minutes with the air drain drank valve open been using it for a bit so I'd like to change the oil out for synthetic. I think the Makita P68 that ships with the compressor is Quin-Cip D. Makita specs SAE 20W ISO 68 for the MAC 700 for 33.8 degrees to 78.8 degrees F. I live in Southern California so the garage is usually 60 degrees to 90 degrees.
MAC 700 OIl
SAE 10W ISO 32 3.2°F - 32°F
SAE 20W ISO 68 33.8°F - 78.8°F
SAE 30W ISO 100 above 80.6°F
Re: Reciprocating air compressor oil Miles Stratus D ISO 68 [Re: dylanm] #5322129 01/14/20 12:57 AM
sloinker Online Shocked
Online Shocked
Yep Quin-Cip 20W is what I use in my Quincy compressor. Like motor oil you can get synthetic or not. My compressor is about 10 years old and I've changed the oil three times and the air filter about 5 times. The oil I drain looks just like the new oil. Crystal clear. I would possibly change the oil more often but there is no combustion process involved. Strictly lubrication and no visual indication of use. I have the manual somewhere that tells the recommended hours between changes but also only specs the Quincy oil. I will take my chances with my extended intervals.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: Reciprocating air compressor oil Miles Stratus D ISO 68 [Re: dylanm] #5322184 01/14/20 05:52 AM
F
fozzdesy2001 Offline
F
I use DEWALT D55001 Synthetic Compressor Oil. Keeps my cheapy compressor happy. Its been running with this oil for years. Kind of expensive but it only holds 4 ounces after 2 changes I still have enough for 2 more. [img]https://www.amazon.com/DEWALT-D55001-Synthetic-Compressor-Quart/dp/B0008GLW9Y[/img]
2001 Subaru Forester S
Replaced with a 2006 Forester
2004 Subaru Forester XT
Death by deer. Replaced with 2003 Impreza Outback Sport (beater)
Re: Reciprocating air compressor oil Miles Stratus D ISO 68 [Re: dylanm] #5322291 01/14/20 09:06 AM
A
ARCOgraphite Offline
A
Isnt the M-S di-ester for closed refrigerant systems? High TAN issue on open systems?
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Reciprocating air compressor oil Miles Stratus D ISO 68 [Re: dylanm] #5322723 01/14/20 05:42 PM
dylanm Offline OP
Miles cross-reference shows Miles Stratus D ISO 68 as universal compressor oil and it's listed as a synthetic diester-based compressor lubricant.
To avoid high TAN is their another product you recommend?
https://www.grainger.com/product/MILES-LUBRICANTS-16-oz-Bottle-of-Compressor-49CN20
https://www.grainger.com/ec/pdf/49CL18_2.pdf
