Are all 9012 bulbs HIR2?
by dvancleve - 01/18/20 03:30 PM
Ariens L-3 Synthetic Severe-Duty Gear Lube
by Astro_Guy - 01/18/20 02:04 PM
LSx Crank lock
by P10crew - 01/18/20 02:03 PM
ST9688 gasket
by Farnsworth - 01/18/20 01:26 PM
From my stash
by Fattylocks - 01/18/20 12:48 PM
Toyota to Mexico
by kstanf150 - 01/18/20 12:37 PM
Final Sludge Cleanup, HDEO - Diesel ??
by jssaab - 01/18/20 12:31 PM
A good cabin filter
by NH73 - 01/18/20 10:36 AM
K&N cut open.
by laserred96gt - 01/18/20 10:25 AM
Toyota Oem filter mileage
by Bettez88 - 01/18/20 10:22 AM
OCI, Owners manual versus oil Mfg.
by VQLT - 01/18/20 10:06 AM
MacBook Pro to Microsoft Surface
by Kira - 01/18/20 09:53 AM
Ford 5R55E Auxiliary Transmission Filter
by benjamming - 01/18/20 09:33 AM
Do all synthetic oils act as a cleaner?
by Loobit - 01/18/20 08:26 AM
Mobil 1 ESP now sold in 5qt jugs
by Patman - 01/18/20 08:12 AM
Mobil 1 Extended Performance Oil Filters
by jrommelt - 01/18/20 08:08 AM
These the same?
by Bettez88 - 01/18/20 06:53 AM
MaxLife SB 10w40 on Sale
by Mad_Hatter - 01/18/20 04:27 AM
Bebo77, 2EHA, jonnyb433, kzbd, 54Robert
70465 Registered Users
94 registered members (750IX, 2oldtommy, Armkb, atikovi, Aichiguy, 8 invisible), 2,445 guests, and 16 spiders.
Topics300,290
Posts5,172,536
Members70,465
Most Online3,728
Jan 11th, 2020
Obsolete purolator disecting #5321821 01/13/20 05:29 PM
M
mpack88 Offline OP
M
I bought a whole case from RockAuto about a year ago of Purolator PL20081 because they can fit all my Chryslers and some Fords. This filter is obsolete and replaced by PL14670. I believe these filters come from the year 2001. I know some people are afraid of using old filters but I say why not. As you can see in the pictures there are no rust. The filter media held together and even the anti drain back valve will still flexible. I ran this particular filter on a 1988 Ford F-150 with a 5.0L after using Amazon 5w40 euro-spec. It stopped up the Purolator classic I had on it. Instead of changing the oil I just swapped using this old filter. Enjoy!!!
20200113_181630.jpg20200113_181618.jpg20200113_181504.jpg20200113_181334.jpg20200113_181327.jpg20200113_181323.jpg20200113_181313.jpg
Re: Obsolete purolator disecting [Re: mpack88] #5321936 01/13/20 07:11 PM
blupupher Offline
Filter looks good.
That is the pre-tearing days of Purolator when they were still good.
I would use one of those no problem.
'18 Santa Fe: PP 10W-30/OEM
'18 Soul: Synpower 5W-30/PG
'10 Santa Fe: Synpower 5w-30/D+
'04 F150: Magnatec 10w-30/ST
'12 xB: M1EP 0W-20/CQ Blue
'02 F150: Magnatec 5W-20/D+
'94 VT1100: Peak 15W-40/D+
Re: Obsolete purolator disecting [Re: mpack88] #5321971 01/13/20 07:57 PM
L
LeakySeals Offline
L
Wonder if deleting that string had anything to do with the future media issues..
06 Escalade 6.0L LQ9 AWD 170k M1 5w30
03 Maxima 3.5L 170k Maxlife HM 10w30
05 Malibu Classic 2.2 111k M1 5w30
06 Altima 2.5L 167k unk
Re: Obsolete purolator disecting [Re: LeakySeals] #5321976 01/13/20 08:03 PM
B
Bettez88 Online Content
Online Content
B
Probably just helped with during production
2013 Honda Fit, QSUD 0W20 with Honda filters
2009 Toyota Corolla, PP 0W20 with Toyota filters
Re: Obsolete purolator disecting [Re: LeakySeals] #5322014 01/13/20 08:38 PM
CR94 Online Content
Online Content
During the 80s and 90s I used a lot of Purolators that did not have the string (or any tears after typically ~18k miles), and a few Frams that did have string. Ironically, that pattern must've reversed later, judging what I've seen on BitOG.
2011 Toyota Prius now at 107K
Re: Obsolete purolator disecting [Re: mpack88] #5322182 01/14/20 05:41 AM
demarpaint Offline
IMO those were the best Pure One filters they made. When they changed over to metal flake puke colored filters it was all down hill for them, imo.
God Bless Our Troops
Re: Obsolete purolator disecting [Re: mpack88] #5322190 01/14/20 06:10 AM
Sayjac Offline
Unless I missed it in several readings, I don't see an fci. Be good to know.
If you post the date code on the dome, manufacture date can be determined. Blue can P1 like topic, ~2008 or before. As long as storage environment decent, they can be serviceable for some time. Not surprised silicone adbv still flexible, those good for a long time.
The seam pleat spacing especially on one side, a tad wide in the pic. I only mention it because, because area of greatest failure for tears. Whatever the fci looks like this one got the job done. As for the assembly string, now I think mostly the larger diameter, bigger filters. Perhaps more earlier applications.
What "stopped up" the Classic?
Thanks for c&p.
Re: Obsolete purolator disecting [Re: Sayjac] #5322277 01/14/20 08:44 AM
M
mpack88 Offline OP
M
Yes sir. The classic stopped up. The oil pressure had a delay after startup and pressure would fluctuate, then the engine would over heat with screeching sounds coming from the bottom end. I put this old pure one on it and resolved all those issues. Amazone euro 5w40 will clean a old engine. I'll check the date code when I get home. The boxes are copyright 2001 and look old and dusty.
Re: Obsolete purolator disecting [Re: mpack88] #5322364 01/14/20 11:37 AM
53' Stude Offline
Maybe I missed it, but what oil and filter went back in and on? Great quality pics and thank you for c&p smile
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: Obsolete purolator disecting [Re: 53' Stude] #5322516 01/14/20 02:15 PM
M
mpack88 Offline OP
M
I used 15w40 pureguard ck4 with a motorcraft fl1a. There's a voa on pureguard in the voa forums.
Re: Obsolete purolator disecting [Re: mpack88] #5322521 01/14/20 02:19 PM
L
Linctex Offline
L
Hmmmmmmm.......... smirk2
Re: Obsolete purolator disecting [Re: Linctex] #5322540 01/14/20 02:51 PM
K
kschachn Online Content
Online Content
K
And this:
I had a dodge aries wipe out its rod bearings and oil pump due to me using valvoline 20w50 and a 20°f. It can happen.
So it's not just Amazon oil.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Obsolete purolator disecting [Re: kschachn] #5322732 01/14/20 05:51 PM
M
mpack88 Offline OP
M
Yup. Different time. That was 12 years ago.
Re: Obsolete purolator disecting [Re: mpack88] #5322750 01/14/20 06:29 PM
53' Stude Offline
Thank You for oil you used info and filter you replace P1 with kind sir smile
161,669 miles
Re: Obsolete purolator disecting [Re: 53' Stude] #5322753 01/14/20 06:35 PM
M
mpack88 Offline OP
M
welcome
