Duralast Max Ceramic Pads Photos!
by NASTI - 01/20/20 11:23 AM
expensive rotors
by Donald - 01/20/20 11:19 AM
3 Fram Ultra's Cut Open
by jetman - 01/20/20 10:31 AM
Standard Cab Commercial
by Duffyjr - 01/20/20 10:17 AM
The thin grease for firearms
by fnbrowning - 01/20/20 10:07 AM
Replace coil packs with spark plugs?
by jayjr1105 - 01/20/20 09:34 AM
Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
Oil ideas for 2 v6 fords and more
by kessellrun - 01/20/20 06:50 AM
Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
FCA and Foxconn partner on EV's
by OVERKILL - 01/19/20 08:55 PM
IIHS Crash pics of Full Size Trucks
by kstanf150 - 01/19/20 08:15 PM
Are Engine Splash Guards Really Needed?
by Mr_Luke - 01/19/20 08:14 PM
supertec cartridge filters
by super20dan - 01/19/20 06:17 PM
RSH, Bobjr94, GarageKings, JohnnyD1980, Harry_Seaward
70487 Registered Users
107 registered members (1978elcamino, Anthony, 2015_PSD, AlienBug, 2011335d, 9 invisible), 3,063 guests, and 27 spiders.
Topics300,349
Posts5,173,896
Members70,487
Most Online3,825
Jan 19th, 2020
2010 Jeep Commander 5.7 Hemi 78000 miles, 6000 miles on Redline 5w30 #5321722 01/13/20 03:31 PM
drfeelgood Online Content OP
OP Online Content
First UOA on Jeep with Hemi. Redline has now been used for 2 consecutive 6000 mile intervals. Has definitely quieted, but not eliminated "tick" sounds. Oil filter is FL820s Motorcraft. Vehicle has AFE dry filter intake and Diablosport tune with MDS turned off .Sorry that image is sideways. Not sure why.[Linked Image]
2008 Z06
2005 Z51
2002 M5
2017 Charger SRT
1996 Prelude VTEC
1969 Mustang 428CJ
1970 Chevelle SS396
2010 Commander Hemi
2009 Escape Hybrid
2010 Cube
Re: 2010 Jeep Commander 5.7 Hemi 78000 miles, 6000 miles on Redline 5w30 [Re: drfeelgood] #5321859 01/13/20 06:06 PM
SubieRubyRoo Offline
Not bad; ~2.75 ppm Fe per 1k mi is more than I am used to personally, but IIRC it might be lower than the Blackstone averages for Hemis. Maybe burla will be along soon and share, he has quite a database of Hemi UOAs that likely have that info in them. Have you considered getting a particle count done to see if there are larger contaminants circulating, as spalling on the cam lobes would not show up on the UOA but should on the PC? Some of the other "universal" averages would also be illuminating such as on the higher silicon readings. Your next sample should be enough to start to generate a decent trend, and with a 5.3 TBN reading you will likely be able to stretch that OCI out longer if that's what you'd like. Thanks for the UOA!
Re: 2010 Jeep Commander 5.7 Hemi 78000 miles, 6000 miles on Redline 5w30 [Re: drfeelgood] #5322093 01/13/20 10:29 PM
OP Online Content
Thanks for the comments! I believe the silicon readings are in line with the 2 most recent Redline VOAs in that section(0w30 and 0w40). I think the sodium is from previous runs of Valvoline and Schaeffers that have sodium in the add packs. Not sure if this lab does particle counts.
2008 Z06
2005 Z51
2002 M5
2017 Charger SRT
1996 Prelude VTEC
1969 Mustang 428CJ
1970 Chevelle SS396
2010 Commander Hemi
2009 Escape Hybrid
2010 Cube
Re: 2010 Jeep Commander 5.7 Hemi 78000 miles, 6000 miles on Redline 5w30 [Re: drfeelgood] #5323076 01/15/20 03:28 AM
dave1251 Offline
I don't recall Schaeffers containing sodium in it's additive package.
don't use.
Re: 2010 Jeep Commander 5.7 Hemi 78000 miles, 6000 miles on Redline 5w30 [Re: drfeelgood] #5323120 01/15/20 06:08 AM
OP Online Content
The iteration of their synthetic 5w30 before the current D1G2 had sodium in the add pack, along with their usual moly, antimony, etc.
2008 Z06
2005 Z51
2002 M5
2017 Charger SRT
1996 Prelude VTEC
1969 Mustang 428CJ
1970 Chevelle SS396
2010 Commander Hemi
2009 Escape Hybrid
2010 Cube
Re: 2010 Jeep Commander 5.7 Hemi 78000 miles, 6000 miles on Redline 5w30 [Re: drfeelgood] #5323174 01/15/20 07:59 AM
dave1251 Offline
I'll take your word on it but I've read back to 2008 and VOA's if s9000 contained only trace amounts of NA.
don't use.
Re: 2010 Jeep Commander 5.7 Hemi 78000 miles, 6000 miles on Redline 5w30 [Re: drfeelgood] #5323243 01/15/20 09:09 AM
OP Online Content
If you look at the analysis on PQIA from 2013 or 2014, it had 472 ppm of sodium. I had a case of this purchased around 2014 or so that I used
2008 Z06
2005 Z51
2002 M5
2017 Charger SRT
1996 Prelude VTEC
1969 Mustang 428CJ
1970 Chevelle SS396
2010 Commander Hemi
2009 Escape Hybrid
2010 Cube
Re: 2010 Jeep Commander 5.7 Hemi 78000 miles, 6000 miles on Redline 5w30 [Re: drfeelgood] #5326127 01/18/20 09:40 AM
Schwifty Online Content
Online Content
I've been thinking about switching to Redline 5w30 for me new Rebel. Did you notice anything different performance wise when switching to a 30 vs a 20?
Re: 2010 Jeep Commander 5.7 Hemi 78000 miles, 6000 miles on Redline 5w30 [Re: drfeelgood] #5326252 01/18/20 11:53 AM
OP Online Content
I have not noticed any perceptible difference in performance with 5w30 vs 5w20. I ran 5w20 for the first several oil changes, then did a couple with a mix of 20 and 30, then have been running 5w30 for the last several. My Hemi has always had a "tick" and nothing made a significant difference in it(I posted a thread on this a while back) until I started running the Redline. As stated above, the engine is by no means silent now, but is definitely quieter. No plans on changing from the Redline at this point. Will probably do another UOA in future just to compare to this one.
2008 Z06
2005 Z51
2002 M5
2017 Charger SRT
1996 Prelude VTEC
1969 Mustang 428CJ
1970 Chevelle SS396
2010 Commander Hemi
2009 Escape Hybrid
2010 Cube
Re: 2010 Jeep Commander 5.7 Hemi 78000 miles, 6000 miles on Redline 5w30 [Re: drfeelgood] #5326452 01/18/20 04:18 PM
JohnnyJohnson Online Content
Online Content
With that great $50 oil I'll be frank your wear metals don't impress.
2004 Corolla 138348
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77060
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: 2010 Jeep Commander 5.7 Hemi 78000 miles, 6000 miles on Redline 5w30 [Re: JohnnyJohnson] #5326457 01/18/20 04:22 PM
K
kschachn Online Content
Online Content
K
Which is consistent with everything the oil analysis places say, that a UOA isn't about the oil.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: 2010 Jeep Commander 5.7 Hemi 78000 miles, 6000 miles on Redline 5w30 [Re: drfeelgood] #5326475 01/18/20 04:57 PM
OP Online Content
Compared with wear metals from other engines, I'd agree the "numbers" aren't the lowest, but for a 5.7 Hemi, I think they are pretty good. If you check out some of the iron and copper levels on UOAs on Ram Forum, I don't think you'll find many with single digit levels.
2008 Z06
2005 Z51
2002 M5
2017 Charger SRT
1996 Prelude VTEC
1969 Mustang 428CJ
1970 Chevelle SS396
2010 Commander Hemi
2009 Escape Hybrid
2010 Cube
Re: 2010 Jeep Commander 5.7 Hemi 78000 miles, 6000 miles on Redline 5w30 [Re: drfeelgood] #5326499 01/18/20 05:40 PM
Online Content
Are those numbers better than say QSUD at nearly 1/3 the cost?
2004 Corolla 138348
2006 Duramax 77060
Re: 2010 Jeep Commander 5.7 Hemi 78000 miles, 6000 miles on Redline 5w30 [Re: JohnnyJohnson] #5326507 01/18/20 05:50 PM
O
OVERKILL Online Content
Online Content
O
UOA's aren't designed for that purpose, you can't just compare wear metals and divine performance, that's not how it works. You'd have to do tear-down testing to truly gauge any sort of performance difference and I doubt anybody is interested in doing that.
Re: 2010 Jeep Commander 5.7 Hemi 78000 miles, 6000 miles on Redline 5w30 [Re: drfeelgood] #5326511 01/18/20 05:52 PM
T
Triple_Se7en Offline
T
My Gawd! We have members here that think Quaker State, Havoline and Supertech equal Red Line.
Thanks for the Report drfeelgood.
19' Hyundai Santa Fe 2.4 GDI - Valv Adv. 5w30 / OEM Oil Filter / 6oz Liqui-Moly
20' Kia Soul X-Line 2.0 Multi-port / Pennzoil Gold 5W30 / OEM filter
04' Colorado 3.5 Castrol Edge 0W40 / K&N filter
