Has anyone tinted a dash cluster?
by Vern_in_IL - 01/25/20 08:40 AM
Coolant flush machines
by Donald - 01/25/20 08:24 AM
How do you scratch the new car itch?
by supton - 01/25/20 08:07 AM
2019 f550 6.7
by ame299 - 01/25/20 07:49 AM
unthinkable problem after oil change
by NH73 - 01/25/20 07:37 AM
Anybody burn wood for heat? Advice please.
by dlundblad - 01/25/20 07:21 AM
2002 cummins
by coondog - 01/25/20 07:07 AM
New Mercedes Ute
by Shannow - 01/25/20 03:04 AM
A decent battery charger for sub $50?
by michaelluscher - 01/25/20 02:03 AM
Temperature swing affects on oil
by leeaspell - 01/25/20 12:58 AM
Coefficient of Friction
by jrommelt - 01/24/20 11:46 PM
2017 Chevy Cruze Diesel Oil
by Ponch - 01/24/20 11:03 PM
electric motor amp rating
by motor_oil_madman - 01/24/20 10:42 PM
Radio, Instrument panel, display, AC cutting off
by DrDanger - 01/24/20 09:39 PM
Filter Brand Quality Change?
by BBDartCA - 01/24/20 09:21 PM
Autozone $7 off $30
by GMguy84 - 01/24/20 09:17 PM
Honda Power Steering Fluid
by shortlid - 01/24/20 09:14 PM
Autozone Clearance 2020 M1EP
by GMguy84 - 01/24/20 09:11 PM
M635_Guy, ame299, Whoop, coondog, steelbeams
70523 Registered Users
112 registered members (alarmguy, 2004tdigls, 1foxracing, 2010Civic, 53' Stude, 55hambone, 8 invisible), 2,670 guests, and 17 spiders.
Topics300,526
Posts5,177,742
Members70,523
Motocross bikes & T4 users, quick question #5321627 01/13/20 01:55 PM
1
1978elcamino Offline OP
1
Currently using Rotella T4 15w40 in the dirtbikes with good success. However, Rural King has Valvoline Premium Blue on sale right now so I was wondering if there is an advantage of premium blue over rotella?
2018 F150 5.0
2016 Ford Fusion 2.5
Re: Motocross bikes & T4 users, quick question [Re: 1978elcamino] #5321723 01/13/20 03:31 PM
Spktyr Offline
Premium Blue does not meet JASO MA/MB and therefore may not be wet clutch safe.
Re: Motocross bikes & T4 users, quick question [Re: 1978elcamino] #5321749 01/13/20 04:06 PM
K
krismoriah72 Offline
K
"Currently using Rotella T4 15w40 in the dirtbikes with good success" -
Valvoline Premium Blue is on sale for $11.99/Gallon
Rotella 15w40 is currently $13.49/Gallon at Rural King.
Is $1.50 worth it?
Re: Motocross bikes & T4 users, quick question [Re: 1978elcamino] #5321782 01/13/20 04:47 PM
1
1
This will be in the engine side only. Just wondering if maybe the add pack in premium blue is better than rotella, im not sure.
2018 F150 5.0
Re: Motocross bikes & T4 users, quick question [Re: Spktyr] #5323217 01/15/20 08:46 AM
sunruh Offline
this is about the worst information possible
there is NOTHING. i repeat NOTHING about a non-jaso oil that that creates it to be non-wet clutch safe
as a matter of fact, most of the manuals only call out - do not use Energy Conserving II - which i have never seen labled on a bottle...ever.
ive seen EC, but never EC II.
for more than a decade shell rotella t 15w40 was not labled jaso and yet it never harmed one clutch
same for mobil1 15w40 redcap
or
ANY OIL before the jaso standard was created!!! ohhhhh how about that for REAL info.
motorcycle oil myth buster
Re: Motocross bikes & T4 users, quick question [Re: sunruh] #5324193 01/16/20 08:43 AM
Spktyr Offline
or
You missed the "may" part in my statement and then went all Scotty Kilmer ballistic. I suggest you do what Kilmer does and crawl under a vehicle that's supported only on a hydraulic jack, then rant loudly and shake the car as he does.
Regarding Energy Conserving II - it was replaced with SJ. See:
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=72549
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/110710/Re:_Energy_Conserving_II
Just how old are the bikes you're looking at that you're seeing "Energy Conserving II" in manuals? My daily driver bike was made in 02 and in the manual it does specifically call out JASO-MA and against the use of Energy Conserving, just like most bikes made in the last nearly two decades:
[Linked Image from live.staticflickr.com]
For the rest of us, the MA/MB cert means that a post API-SG oil is inherently wet-clutch safe and you need look no further, use with confidence in your motorcycle without worrying about it killing the wet clutch. Other non-MA/MB oils may be okay, as Rotella T was, but they may not be. If you wish to use an oil that does not state that it meets MA/MB, you can either use it and hope it doesn't kill your clutch (but be ready to replace it if the oil does), you can contact the manufacturer and ask, or you can do extensive internet research and find out what people's experience with it is (in order of effort required.) Point is, without JASO-MA/MB on the bottle, you don't inherently know. "Do ya feel lucky, punk? Eh? Do ya?"
By the way? Mobil 1 15W50 redcap SH wiped out a relatively new clutch on a CB750 I had. The break point was SG - the last API designation that was specifically wet clutch compatible. That was an expensive discovery.
Re: Motocross bikes & T4 users, quick question [Re: 1978elcamino] #5324315 01/16/20 10:55 AM
L
Linctex Offline
L
All of my Japanese bikes have a shared sump.
All of them get whatever 15W-40 I can find for cheap.
i have never looked for the JASO spec......EVER.
Never had a problem..... ever.
The only oil that has ever made a Japanese bike clutch slip was "Mobil 1 10W-40T" bike oil.
I went back to running the cheapest 15W-40 oil again, and no problems.
Re: Motocross bikes & T4 users, quick question [Re: Linctex] #5324385 01/16/20 11:53 AM
Spktyr Offline
Dunno what to tell you on the M1 bike oil, but 15W and up oil tends to be non-energy-conserving and is often safe for wet clutch use - but that's not 100%. Some of them emphatically aren't and none of the 10 or lower weight oils are (these days) unless they specifically state that. My friends and I found that out the hard way between the conversion from SG to SH-SJ-SL. Lots of people had clutches go at that time, and that problem continues to today. Some bikes can't use or don't like 15W due to how the engine was made or simply what happens to shift quality on thicker oil.
Again, if it says it's MA/MB certified, it's guaranteed to be safe for wet clutches. Doesn't mean you can't use something else (I used Rotella T before it got the MA cert because if you asked Shell they would tell you that it met the spec, its just that they hadn't bothered to get the certification), just saying that the MA/MB cert means you don't have to guess or do research if you have a wet clutch.
Re: Motocross bikes & T4 users, quick question [Re: 1978elcamino] #5324598 01/16/20 05:13 PM
1
1
So is Premium Blue any better than T4 in a motocross bike application?
2018 F150 5.0
Re: Motocross bikes & T4 users, quick question [Re: 1978elcamino] #5325030 01/17/20 08:04 AM
K
K
Better at what?
Since you are at rural king... take a look at Mystik 15w50.. it gives great reports and i think its a value oil.
I have no idea if its better.. it just looks good on paper in other guys bikes.
Re: Motocross bikes & T4 users, quick question [Re: krismoriah72] #5325106 01/17/20 09:32 AM
F
FastGame Offline
F
Better at what?
I agree and while you checkout Mystik oil checkout Harvest King oil, both are CITGO products.
Re: Motocross bikes & T4 users, quick question [Re: 1978elcamino] #5329047 01/21/20 07:01 PM
53' Stude Online Content
Online Content
FastGame: great point smile
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
