Please go ahead and use a single weight oil. I'm looking forward to you posting it.
I'm not sure what you're expecting to see, that someone has used it or are you waiting for them to post a UOA? If the latter then the UOA will not show anything that determines performance. Or do you think you will see something that will?
It will behave just like any other appropriately rated oil in that engine, which is all a UOA ever shows.[/quote
I think there were some impressions made that would require further explanations. Mr. Shannow does not run single weight motor oil even though he lives in a hot environment. I thought he would, seeing he has a strong conviction towards it.
Mr. Kaschachn, you left the impression that there were auto manufacturers that spec single grade oil. A list would be good.
Nope. I don't accept someone's UOA's as amazing evidence that single grade is the way to go.
And FWD, you aren't really going to run that lawn mower oil in your Chevy, are you? But thanks for posting it.
Not trying to be a snot, but really, I'm getting it from all sides about the virtue of single grades but I haven't seen anyone step up to the plate.
