Are all 9012 bulbs HIR2?
by dvancleve - 01/18/20 03:30 PM
Ariens L-3 Synthetic Severe-Duty Gear Lube
by Astro_Guy - 01/18/20 02:04 PM
LSx Crank lock
by P10crew - 01/18/20 02:03 PM
ST9688 gasket
by Farnsworth - 01/18/20 01:26 PM
From my stash
by Fattylocks - 01/18/20 12:48 PM
Toyota to Mexico
by kstanf150 - 01/18/20 12:37 PM
Final Sludge Cleanup, HDEO - Diesel ??
by jssaab - 01/18/20 12:31 PM
A good cabin filter
by NH73 - 01/18/20 10:36 AM
K&N cut open.
by laserred96gt - 01/18/20 10:25 AM
Toyota Oem filter mileage
by Bettez88 - 01/18/20 10:22 AM
OCI, Owners manual versus oil Mfg.
by VQLT - 01/18/20 10:06 AM
MacBook Pro to Microsoft Surface
by Kira - 01/18/20 09:53 AM
Ford 5R55E Auxiliary Transmission Filter
by benjamming - 01/18/20 09:33 AM
Do all synthetic oils act as a cleaner?
by Loobit - 01/18/20 08:26 AM
Mobil 1 ESP now sold in 5qt jugs
by Patman - 01/18/20 08:12 AM
Mobil 1 Extended Performance Oil Filters
by jrommelt - 01/18/20 08:08 AM
These the same?
by Bettez88 - 01/18/20 06:53 AM
MaxLife SB 10w40 on Sale
by Mad_Hatter - 01/18/20 04:27 AM
Bebo77, 2EHA, jonnyb433, kzbd, 54Robert
70465 Registered Users
86 registered members (Alfred_B, 2oldtommy, AlienBug, 2015_PSD, 14Accent, 9 invisible), 2,269 guests, and 19 spiders.
Topics300,290
Posts5,172,558
Members70,465
Most Online3,728
Jan 11th, 2020
Baldwin #5321577 01/13/20 01:05 PM
B
Bettez88 Offline OP
B
Are Baldwin filters anything special or they just a run of the mill filter? Supposedly they’re HD filters?
2013 Honda Fit, QSUD 0W20 with Honda filters
2009 Toyota Corolla, PP 0W20 with Toyota filters
Re: Baldwin [Re: Bettez88] #5321594 01/13/20 01:28 PM
K
kschachn Offline
K
There are numerous threads on Baldwin filters here on Bitog. May I suggest you start there first.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Baldwin [Re: Bettez88] #5321675 01/13/20 02:46 PM
L
Linctex Online Content
Online Content
L
Baldwin/Hastings fall under the Parker Filtration/CLARCOR umbrella.
Many, Many, Many larger engines in farms, construction, fleets, trucking, etc. etc run them.
Re: Baldwin [Re: Bettez88] #5321712 01/13/20 03:23 PM
SubieRubyRoo Offline
Great filters with paper elements and nitrile ADBVs. Always stoutly built. But as kschachn said, use the search function, browse some C&Ps, and convince yourself instead of relying on opinions.
Re: Baldwin [Re: SubieRubyRoo] #5321756 01/13/20 04:12 PM
Bud Offline
Funny, but these forums are made up of opinions. In my opinion of course.
2016 Honda Pilot EX-L with NAVI.....Mobil 1 0w20 AFE and Honda OEM Filter
Re: Baldwin [Re: Bettez88] #5321849 01/13/20 05:59 PM
That's why I said for him to do some legwork on his own, look at already cut Baldwin filters, and come up with his own position on their quality. I never recommended that he should read the drivel erroneous opinions of some others here who think that a quality filter requires synthetic media and silicone ADBVs.
Because the great equalizer of opinions is macro-data, and the available macro-data overwhelmingly says both oil filters and oil makeup itself play a nearly insignificant role in engine longevity, that's why I think he should utilize the great search function in the Oil Filter subforum. If oil and filter meet the manufacturer's specs and you change them when it's recommended to change, the vehicle will almost certainly not die from oil- or filter-related causes. I'm just here for the pictures, the +1s, and being IBTL. Oh, and the occasional stupid cat meme. LOL
But sir, you are absolutely entitled to your opinion on others' opinions and I support your right to this, and I thank you for your service. thumbsup
Re: Baldwin [Re: Linctex] #5321993 01/13/20 08:19 PM
4WD Offline
Yep. Often sold by the case … used many on big gen-set CAT’s …
Baldwin B7449 on one of the 5.3’s now … will be a while before C&P
Re: Baldwin [Re: 4WD] #5322076 01/13/20 09:57 PM
4WD Offline
Re: Baldwin [Re: Bettez88] #5322394 01/14/20 12:01 PM
Hootbro Offline
My opinion is the only one that matters, they are good to go. Anything said by anyone else otherwise is a heretic. grin2
2020 Jeep Gladiator Rubicon 3.6L (Dealer Bulk 0W-20)
2017 Jeep Renegade Latitude 2.4L (Idemitsu 0W-20)
2013 Volkswagen Jetta 2.5L (Havoline HM 5W-30)
Re: Baldwin [Re: Bettez88] #5322426 01/14/20 12:36 PM
N
nthach Offline
N
Not worth going out of your way for - but if your parts house or truck supplier stocks them and you need to put in an order, go for it.
Baldwin focuses on the heavy duty market. Still a good filter but there's cheaper and better choices for light duty.
Re: Baldwin [Re: nthach] #5322450 01/14/20 12:57 PM
4WD Offline
They also post good data … found the PRV opening PSI … and it looked pretty close to my spec
