Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
30 monograde
by mpack88 - 01/21/20 10:15 AM
Extended life destroys copper?
by mpack88 - 01/21/20 09:49 AM
Project Farm Lucas transmission additive video
by 1978elcamino - 01/21/20 09:43 AM
1.8t 0w40, plus a situation.
by WMNN1988 - 01/21/20 09:25 AM
Mobil 1™ ESP X2 0W-20 US Availability
by TheIceStormof06 - 01/21/20 08:46 AM
Wire harness/connector
by Redright9 - 01/21/20 07:58 AM
Will You Jump Someone Else's Car?
by Gebo - 01/21/20 07:08 AM
NAPA Edge $20 A/R
by dblshock - 01/21/20 04:54 AM
8 Utes on test.
by Silk - 01/21/20 03:03 AM
Magnetic Socket Rails
by The Critic - 01/21/20 01:19 AM
Oreilly Select complete fuel system cleaner
by keantoken - 01/21/20 12:19 AM
Local Costco Has all Oils and Viscosities $10 Off
by SteveG4 - 01/21/20 12:14 AM
EBC Rotor Pictures
by BBDartCA - 01/20/20 11:28 PM
reylafo, PastPresMike, RedBeard83, dfrybeck, ckinch1
70495 Registered Users
115 registered members (1978elcamino, 28oz, aquariuscsm, 53' Stude, 2015_PSD, 90crvtec, 10 invisible), 2,252 guests, and 25 spiders.
Topics300,389
Posts5,174,797
Members70,495
Shell Rotella T6 0W40 Arctic Blend low saps API SN #5321497 01/13/20 11:37 AM
N
Navi Offline OP
N
I think I found a new oil for JButchs old turbo Subaru. Shell Rotella T6 5W40 is well known in the Subaru crowd but the only thing is that Shell will openly admit its not for gas engines and its bad for the cats. T6 5W40 produces great results on the Blackstone report.
Shell has now upped the ante with low saps API SN rated 0W40 version! So the JButch need not worry if the old Subaru going to lose a cat. [Linked Image]
[Linked Image]
Re: Shell Rotella T6 0W40 Arctic Blend low saps API SN [Re: Navi] #5321505 01/13/20 11:43 AM
N
Navi Offline OP
N
Just a note. I know this oils intended audience is heavy duty diesels...but thats not what I see it used for. It gets used in many cars for various reasons thus why I posted it here...
Re: Shell Rotella T6 0W40 Arctic Blend low saps API SN [Re: Navi] #5321513 01/13/20 11:51 AM
F
Fraser434 Offline
F
Whats more important to you your engine wear or catalytic converter degredation?
I put 0W40 T6 in my daily driver, and btw the jugs of 0W40 T6 I purchased said CJ4/SN on them, still actually rated for gas engines, old stock maybe?
Re: Shell Rotella T6 0W40 Arctic Blend low saps API SN [Re: Navi] #5321514 01/13/20 11:52 AM
G
Gokhan Offline
G
That's false marketing. It's not low-SAPS, which has SA ≤ 0.5%. In fact it's not even mid-SAPS, which has SA ≤ 0.8%. It's just another CJ-4/SN oil with SA ~ 1.0%, with nothing special about it.
If you want an HDEO, go with a CK-4, which is vastly improved over CJ-4.
Here is a UOA:
http://pics.tdiclub.com/showphoto.php?photo=115113&title=uoa-11-16-2015&cat=500
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 2,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Re: Shell Rotella T6 0W40 Arctic Blend low saps API SN [Re: Navi] #5321515 01/13/20 11:53 AM
4WD Offline
It’s a cult … with the NOACK higher than Delvac Super (at near half the cost)
I’d use that or Delo 15w40 in the summer in many of these cases
Re: Shell Rotella T6 0W40 Arctic Blend low saps API SN [Re: Navi] #5321517 01/13/20 11:53 AM
V
Virtus_Probi Offline
V
I would think about it if it were SN+ and actually showed up at a local WM....jbutch and I both own '14 FXTs IIRC.
I bought a case of M1 5W30 ESP some time ago and then completely freaked when somebody online reported getting fake ESP from Amazon!!!
2014 Forester XT, 111000 miles
Last Change;
M1 0W30 AFE
Tokyo Roki 15208AA170 filter
Re: Shell Rotella T6 0W40 Arctic Blend low saps API SN [Re: Navi] #5321550 01/13/20 12:35 PM
J
Jackson_Slugger Offline
J
Why not consider a gas engine version rather than run down the boutique/exotic oil rabbit hole? Pennzoil Plat has one you can get at Walmart: https://www.walmart.com/ip/Pennzoil...BgyAFuwAMOVJkKlOh4vwEIgUM6hoC4YYQAvD_BwE
Re: Shell Rotella T6 0W40 Arctic Blend low saps API SN [Re: Jackson_Slugger] #5321561 01/13/20 12:54 PM
J
Jimmy_Russells Offline
J
OP has about 40 threads on his 3.5 Ecoboost. Basically unless it's a solid 40 grade and stays there he doesn't want it. No rhyme or reason to that.
Re: Shell Rotella T6 0W40 Arctic Blend low saps API SN [Re: Navi] #5321648 01/13/20 02:12 PM
N
Navi Offline OP
N
If you are referring to Shell Rotella T6 its hardly boutique. Well I guess ita boutique when comparing to its brother 5W40 which is like 18 dollara for 5 liters and even comes in a larger discounted 2.5 gallon jug too. At my local Walmart the T6 5W40 is usually gone from the shelves with just a few token jugs left behind.
Maybe shrinking the jug and increasing the price was purposeful knowing its the lifeblood of many a Subaru...
Re: Shell Rotella T6 0W40 Arctic Blend low saps API SN [Re: Gokhan] #5321649 01/13/20 02:12 PM
V
V
Here is a UOA:
Thanks for the post...too much calcium for me! Even with the elevated ZDDP.
Last Change;
M1 0W30 AFE
Re: Shell Rotella T6 0W40 Arctic Blend low saps API SN [Re: Navi] #5321655 01/13/20 02:22 PM
J
J
It's not "boutique persay", but it's pretty rare or at least pricey to get in that weight, much like their 5W-30 and 0W-30 T6 variants. T6 5W-40 comes in gallon (4L) or 2.5 gallon jugs, not 5L that I've ever seen. They do have a rebate I assume. TSC also has T6 at good prices...
Re: Shell Rotella T6 0W40 Arctic Blend low saps API SN [Re: Navi] #5321656 01/13/20 02:24 PM
J
jbutch Offline
J
It's a 2015 FA20DIT, I wouldn't call that engine old, LOL
I don't feel I need a 40 weight in that engine though, happy with the oils I'm using.
Like Virtus_Probi said, too much calcium... The Euro LX I'm using right now is already slightly high at 1700ppm.
2015 Forester XT @ 104k km
Current fill: Pennzoil Euro LX 0w-30 with Fram Ultra XG7317
Re: Shell Rotella T6 0W40 Arctic Blend low saps API SN [Re: Jimmy_Russells] #5321657 01/13/20 02:24 PM
J
J
IKR, but what would this site be without people that:
[Linked Image from s3.amazonaws.com]
Re: Shell Rotella T6 0W40 Arctic Blend low saps API SN [Re: jbutch] #5321662 01/13/20 02:33 PM
V
V
Oops, thought you had a '14 like me...my engine has a model year and about 80000km on yours!
jbutch, do you know offhand if you got the redesigned CVT with the added filter? I know if was introduced in the course of the '15 MY production, I definitely do not have it and wish I did...my CVT was repaired under warranty at around 80kmiles after throwing codes and acting funny in reverse.
Last Change;
M1 0W30 AFE
Re: Shell Rotella T6 0W40 Arctic Blend low saps API SN [Re: Virtus_Probi] #5321677 01/13/20 02:47 PM
J
jbutch Offline
J
I checked a while back and my FXT should have the CVT filter. That darn CVT is the only thing that scares me on that vehicle. I really like the forester though, especially in the 16 inches of fresh snow that fell yesterday.
