How do you scratch the new car itch?
by supton - 01/25/20 08:07 AM
2019 f550 6.7
by ame299 - 01/25/20 07:49 AM
unthinkable problem after oil change
by NH73 - 01/25/20 07:37 AM
Anybody burn wood for heat? Advice please.
by dlundblad - 01/25/20 07:21 AM
2002 cummins
by coondog - 01/25/20 07:07 AM
New Mercedes Ute
by Shannow - 01/25/20 03:04 AM
A decent battery charger for sub $50?
by michaelluscher - 01/25/20 02:03 AM
Temperature swing affects on oil
by leeaspell - 01/25/20 12:58 AM
Coefficient of Friction
by jrommelt - 01/24/20 11:46 PM
2017 Chevy Cruze Diesel Oil
by Ponch - 01/24/20 11:03 PM
electric motor amp rating
by motor_oil_madman - 01/24/20 10:42 PM
Radio, Instrument panel, display, AC cutting off
by DrDanger - 01/24/20 09:39 PM
Filter Brand Quality Change?
by BBDartCA - 01/24/20 09:21 PM
Autozone $7 off $30
by GMguy84 - 01/24/20 09:17 PM
Honda Power Steering Fluid
by shortlid - 01/24/20 09:14 PM
Autozone Clearance 2020 M1EP
by GMguy84 - 01/24/20 09:11 PM
Spark Plugs
by A_Spruce - 01/24/20 09:00 PM
Flank drive wrenches
by spasm3 - 01/24/20 08:39 PM
ame299, Whoop, coondog, steelbeams, Pete44
70522 Registered Users
104 registered members (55hambone, alarmguy, 1foxracing, 67ZL1, adams355, ame299, 9 invisible), 2,488 guests, and 20 spiders.
Topics300,524
Posts5,177,708
Members70,522
Max oil temps and myths? #5321430 01/13/20 10:22 AM
R
racin4ds Offline OP
R
Sorry guys, didn't really know where to put this one, I was lying awake last night with a nasty cold and cough so no sleep....
This weekend I got my deep fryer out and made a big batch of hot wings and as usual, I get my oil (Canola) up to 350-375*F before dropping my wings in... this got me to thinking why does everyone in the automotive world panic when the oils temps exceed 250*F??
It doesn't seem to phase this cheap canola oil and I know the high quality base oils used in all major suppliers of PCMO's and HDEO's has to better than this cooking oil, right??
Case in point- my 2005 Ford F350 with the 6.0 diesel engine. These are known to have oil cooler issues and folks on the forums as well as OE Ford TB's say oil temps in excess of 250* is BAD!! Why are we so concerned with what seems to be a relatively mild oil temp in cars? Especially if we're running a quality synthetic? Does 250-300* actually hurt todays oils?
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: Max oil temps and myths? [Re: racin4ds] #5321437 01/13/20 10:28 AM
supton Online Content
Online Content
Problem is, where are you measuring the temperature? The sump is one temp, the oil in the heads another. The temperature in the bearings is yet another, and then there is the oil temp on the cylinder walls and in the drain holes in the pistons. If I'm not mistaken, the temperature of oil in a deep fryer is a relative constant, hotter near the heat source I'm sure, but I am thinking it does not have the wild swings that an engine would have.
I wonder how long oil in a deep fryer is good for? contrasted against engine hours.
2011 Toyota Camry, base, 2.5L/6MT, 200k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 220k, his
Re: Max oil temps and myths? [Re: racin4ds] #5321452 01/13/20 10:44 AM
CR94 Offline
Try heating engine oil to that temperature in your fryer, with or without wings, and watch what happens.
2011 Toyota Prius now at 108K
Re: Max oil temps and myths? [Re: racin4ds] #5321456 01/13/20 10:50 AM
R
robertcope Offline
R
Oil in my NSX goes gets hot, I tend to shut it down at about 275F on track, but I've run hotter when having fun. I've emailed Red Line and they said that wasn't a problem. Pressures remain fine, OUA comes back fine. I also talked to Mobil 1, who told me they would set 300F as a "conservative limit". <shrug>
Re: Max oil temps and myths? [Re: racin4ds] #5321468 01/13/20 11:04 AM
N
nascarnation Offline
N
Beyond the oil itself is the effect on elastomer seals in your engine.
Typically that's a time at temperature relationship.
Re: Max oil temps and myths? [Re: racin4ds] #5321485 01/13/20 11:20 AM
Quattro Pete Offline
Apples to oranges, I'm afraid.
Canola is a much simpler fluid, not loaded with VIIs and additives that may not handle temperature extremes as well. Then there is the time component - is your Canola good for 300 hours of being in service and providing the necessary film strength between moving metal parts?
Maybe we should all just start using Canola in our engines because it's so good. smile
And Delo sucks - fried wings don't taste as good after being fried in it. smile
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Max oil temps and myths? [Re: racin4ds] #5321494 01/13/20 11:33 AM
RDY4WAR Online Content
Online Content
Oil temps are a sensitive subject to some. I personally don't care if the oil gets up there so long as there's a reason for it (I'm towing up a steep incline or racing, for example), and I know the oil can take it. I'm a drag racer so engine oil temp isn't an issue for me. The real issue for me is trans temperature. It kills me when people don't monitor trans fluid temp when using a transbrake. The ATF climbs +50-60*F per second while on the transbrake and some guys will sit there 5+ seconds trying to build boost or something and melting the trans in the process.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: Max oil temps and myths? [Re: racin4ds] #5321506 01/13/20 11:44 AM
B
BMWTurboDzl Offline
B
Apples to oranges. The canola oil in your deep fryer is oxidizing as well. 10-15 mins in a deep fryer is not comparable to what goes on inside an ICE.
435i
Re: Max oil temps and myths? [Re: BMWTurboDzl] #5321508 01/13/20 11:47 AM
4WD Offline
Agree … the wing fling sounds much more exciting than more lube tube stuff !
Re: Max oil temps and myths? [Re: racin4ds] #5321519 01/13/20 11:54 AM
R
racin4ds Offline OP
R
LOL all interesting and good responses.... sorry for the late night thoughts... large doses of cold meds and no sleep causes weird randomness... smile
My deep fryer has a good fitting lid and I do use the same oil many many times before replacing, I usually go by how dark it has gotten and how it smells... if it is oxidizing and evaporating, it isn't much though because it has a clear line that states "MAX" and I don't add often... smile
I'm thinking when I retire this fry daddy I'll take it to the shop for some youTube oil testing and see what happens! sounds like a better way to spend my sleepless nights..... smile
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: Max oil temps and myths? [Re: racin4ds] #5321544 01/13/20 12:28 PM
DGXR Offline
Motor oil has much more to handle besides high temperatures. Motor oil has to clean, lubricate, suspend particulates, combat sludge, neutralize acids, resist shearing forces, flow well at very low temperatures, etc. Lots of demands. I agree with the statement about oil temperature being much higher on the surface of some internal engine parts, particularly the underside of pistons. This brief but very high temperature is not reflected by the oil temperature gauge.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: Max oil temps and myths? [Re: racin4ds] #5321547 01/13/20 12:32 PM
B
benjy Offline
B
for starters your KILLING yourself with canola aka rapseed oil a seed oil NOT a vegetable oil, search + learn Dr Ken D Berry, your choice! the wings real fat ate NOT as bad as they want us to believe as its the carbs that quickly turn to SUGAR thats the culprit!! now about engine oils + the heat they occur + the THINNING that takes place from high heat, check out savage geese OIL the fine print, he notes even the best oils like Redline that are TOO thin do NOT protect an engine properly!!
Re: Max oil temps and myths? [Re: racin4ds] #5321730 01/13/20 03:37 PM
M
Mitch Alsup Offline
M
High temperatures means lower viscosity. At some point the viscosity becomes too low to support the loads.
There is an oil temperature gauge in my "sports car" that has a red line marked within spitting distance of 305ºF.
The Factory oil at the time of manufacture was Shell Helix 5W-40 that had an HTHS of 4.2 cP in 1999, when I started paying attention.
HTHS is measured at 150ºC which happens to be 302ºF which happens to be the same as the red line on the temperature gauge.
I take this to mean the factory does not want you to use the engine hard when the oil viscosity is lower than 4.2cP.
And with a red line above 8,500 RPMs in a flat plane crank V8, it can be used quite hard indeed.
Note: It is almost impossible to get the oil temperature above 250°F with extremely spirited back road driving,
there is an oil air heat exchanger 1/2 as large as the engine water air radiator and dry sump.
And the only times I have seen the oil temperature above 250ºF is on race tracks at HPDE events.
One of the things that always amazed me is that after a track event, the oil pressure gauge would always show a 5 PSI decrease in the oil pressure until the oil was changed at which time the oil pressure returned to 70 PSI at 3,000 RPMs and above. Even at race tracks, the car consumed no oil over a OCI.
Re: Max oil temps and myths? [Re: racin4ds] #5321736 01/13/20 03:48 PM
sloinker Offline
Get an air fryer.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: Max oil temps and myths? [Re: racin4ds] #5321748 01/13/20 04:05 PM
M
Mad_Hatter Offline
M
OP...
The Arrhenius rate rule says the rate of oxidation for a lubricant doubles for every +18f increase above operating temp.
Machinery Lubrication
Petroleum Service Co.
[Linked Image]
