Duralast Max Ceramic Pads Photos!
by NASTI - 01/20/20 11:23 AM
expensive rotors
by Donald - 01/20/20 11:19 AM
3 Fram Ultra's Cut Open
by jetman - 01/20/20 10:31 AM
Standard Cab Commercial
by Duffyjr - 01/20/20 10:17 AM
The thin grease for firearms
by fnbrowning - 01/20/20 10:07 AM
Replace coil packs with spark plugs?
by jayjr1105 - 01/20/20 09:34 AM
Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
Oil ideas for 2 v6 fords and more
by kessellrun - 01/20/20 06:50 AM
Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
FCA and Foxconn partner on EV's
by OVERKILL - 01/19/20 08:55 PM
IIHS Crash pics of Full Size Trucks
by kstanf150 - 01/19/20 08:15 PM
Are Engine Splash Guards Really Needed?
by Mr_Luke - 01/19/20 08:14 PM
supertec cartridge filters
by super20dan - 01/19/20 06:17 PM
RSH, Bobjr94, GarageKings, JohnnyD1980, Harry_Seaward
70487 Registered Users
98 registered members (ARB1977, 1978elcamino, aquariuscsm, Anthony, 2015_PSD, 9 invisible), 3,053 guests, and 25 spiders.
Topics300,349
Posts5,173,904
Members70,487
Most Online3,825
Jan 19th, 2020
11k UOA PP SN+ 5w30 18 Edge 2.0 Ecoboost #5321352 01/13/20 08:39 AM
H
Hemi_Time Offline OP
H
First UOA!
2018 Ford Edge 2.0 Ecoboost with 5w30 Pennzoil Platinum SN+ run to 11k miles (75% highway driving). Expected the oil to be in pretty bad shape (OLM went to 0% at 10k miles).
(Oil ran from 40k to 51k odometer miles)
From Blackstone Labs:
"Your Ford Edge couldn't have asked for a much better first report. Universal averages show
typical wear for a 2.0L EcoBoost that's had its oil changed after about 6,300 miles, and you've got less
metal even after a much longer interval, meaning that your engine is wearing with the best of them. No fuel
or coolant contamination was detected, and the oil filter earns a great review for keeping insolubles (solids)
down to just 0.2%. The 2.7 TBN means the oil still had some active additive left in reserve, so feel free to
tap into that by going 13,000 miles next time."
Notes:
*Took the sample after driving the SUV for 20 minutes or so and fully warmed up
*Only 93 octane from Shell/Chevron
*Running oversized Purolator PBL20195 filter (about 1 inch longer)
*FilterMag SS300
*K&N panel filter (OEM airbox)
Cheers,
Pete
2016 Camaro 2SS 8AT
Re: 11k UOA PP SN+ 5w30 18 Edge 2.0 Ecoboost [Re: Hemi_Time] #5321356 01/13/20 08:43 AM
V
volk06 Offline
V
I have the same engine in my 2016 edge. Always enjoy UOAs of the same engine build. Looks like it has broken in nicely.
Looks like a good combination - thanks for the uoa.
Re: 11k UOA PP SN+ 5w30 18 Edge 2.0 Ecoboost [Re: Hemi_Time] #5321359 01/13/20 08:45 AM
V
Virtus_Probi Offline
V
I'd say that's a super impressive UOA given that PP 5W30 starts out sort of thin for its grade (9.8 cSt at 100C) and you are still in the 5W30 range after a long run in a turbo engine.
Very nice!!
2014 Forester XT, 111000 miles
Last Change;
M1 0W30 AFE
Tokyo Roki 15208AA170 filter
Re: 11k UOA PP SN+ 5w30 18 Edge 2.0 Ecoboost [Re: Hemi_Time] #5321373 01/13/20 09:02 AM
B
BMWTurboDzl Offline
B
A great example of why UOA's should not be done on a relatively new engine. It's refreshing change from the Euro owners who try to draw conclusions switching around with X, Y, and Z oil when the engine has only 25k miles on it.
435i
Re: 11k UOA PP SN+ 5w30 18 Edge 2.0 Ecoboost [Re: Hemi_Time] #5321402 01/13/20 09:39 AM
PimTac Offline
Good looking report.
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: 11k UOA PP SN+ 5w30 18 Edge 2.0 Ecoboost [Re: Hemi_Time] #5321405 01/13/20 09:47 AM
SevenBizzos Offline
Nice UOA there! I'm going to run my first report next change. Lots of discussion about the EB's on this forum.
2018 Ford Edge Sport 21k - Amsoil XL 5W-30, EA15k43
2009 Hyundai Sonata V6 Limited 171k - Mobi1 5W-20 HM, Fram Ultra Syn XG9999 frown
2002 Mustang GT 75k - Amsoil XL 5W-20, EA011,Rained on 7 times
Re: 11k UOA PP SN+ 5w30 18 Edge 2.0 Ecoboost [Re: Hemi_Time] #5321683 01/13/20 02:52 PM
A
alarmguy Offline
A
Great report.
The Filter Mag looks like a great product.
I always used Gold Plug oil pan drain plugs, I do like the idea of the metals getting trapped in the filter as with the Filter Mag better.
With that said (and keep in mind I use them too) I always wondered if the magnets "skew" the metal PPM in a UOA.
Meaning if the filter mag or magnetic oil pan plug is holding metals down to virtually 0 microns, does that skew the "wear numbers" in the report. to what a typical UOA might show??
I have always discounted that it may skew the numbers, as I guess a high efficiency oil filter may do the same, yet a magnet will remove even the finest smallest particles
Anyway, just some rambling thoughts, good report by the way!
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Re: 11k UOA PP SN+ 5w30 18 Edge 2.0 Ecoboost [Re: Hemi_Time] #5322232 01/14/20 07:32 AM
dnewton3 Online Content
Global Moderator
Online Content
Global Moderator
The numbers are desirable, for sure.
Note ... if you use the filter mag, then you're pulling Fe out of the oil. That's good in that the Fe isn't still going around and around in the engine. But it's bad because it's misleading; some Fe would have ended up in the UOA, and so the really low Fe is a bit low. The mag will not affect non-ferrous metals like Al, Cu, Pb, so those numbers are fairly accurate.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: 11k UOA PP SN+ 5w30 18 Edge 2.0 Ecoboost [Re: dnewton3] #5325614 01/17/20 07:08 PM
M
Mad_Hatter Offline
M
If the actual iron level was meaningfully higher than reported, would we see higher levels of other, softer, wear metals or is there no correlation? (more iron floating around in the oil would promote wear in the other softer metals and since we don't necessarily see that, it's a safe assumption actual iron levels are not significantly different than what the analysis reports???)
