Are all 9012 bulbs HIR2?
by dvancleve - 01/18/20 03:30 PM
Ariens L-3 Synthetic Severe-Duty Gear Lube
by Astro_Guy - 01/18/20 02:04 PM
LSx Crank lock
by P10crew - 01/18/20 02:03 PM
ST9688 gasket
by Farnsworth - 01/18/20 01:26 PM
From my stash
by Fattylocks - 01/18/20 12:48 PM
Toyota to Mexico
by kstanf150 - 01/18/20 12:37 PM
Final Sludge Cleanup, HDEO - Diesel ??
by jssaab - 01/18/20 12:31 PM
A good cabin filter
by NH73 - 01/18/20 10:36 AM
K&N cut open.
by laserred96gt - 01/18/20 10:25 AM
Toyota Oem filter mileage
by Bettez88 - 01/18/20 10:22 AM
OCI, Owners manual versus oil Mfg.
by VQLT - 01/18/20 10:06 AM
MacBook Pro to Microsoft Surface
by Kira - 01/18/20 09:53 AM
Ford 5R55E Auxiliary Transmission Filter
by benjamming - 01/18/20 09:33 AM
Do all synthetic oils act as a cleaner?
by Loobit - 01/18/20 08:26 AM
Mobil 1 ESP now sold in 5qt jugs
by Patman - 01/18/20 08:12 AM
Mobil 1 Extended Performance Oil Filters
by jrommelt - 01/18/20 08:08 AM
These the same?
by Bettez88 - 01/18/20 06:53 AM
MaxLife SB 10w40 on Sale
by Mad_Hatter - 01/18/20 04:27 AM
Bebo77, 2EHA, jonnyb433, kzbd, 54Robert
70465 Registered Users
96 registered members (2015_PSD, 14Accent, Armkb, 750IX, 2oldtommy, 6 invisible), 2,580 guests, and 19 spiders.
Topics300,290
Posts5,172,543
Members70,465
Most Online3,728
Jan 11th, 2020
Supercharged 17 Mustang GT #5321266 01/13/20 06:20 AM
A
Anthony Offline OP
A
I have a VMP GEN2R 2.3 blower on the way for the car.
When it’s all said and done it should have a little over 600 RWHP.
I don’t plan on tracking the car. It calls for 5w20. I run Pennzoil Platinum 5W30. A lot of people say jump to 5w50. That seems a little overkill to me. I’ll enjoy my burst of power but it won’t live at redline.
I was thinking a 5w40 would be ideal.
What do y’all think of using one of the two Amsoil European 5w40 grades? Also considering Amsoil SS 0w40 or Amsoil SS 5W30.
I honestly think the current Platinum 5W30 is probably fine too.
95 Nissan Hardbody V6 - M1 HM 5w30
13 Nissan Titan - Pennzoil Platinum 5w30
17 Ford Mustang GT - Pennzoil Platinum 5w30
Re: Supercharged 17 Mustang GT [Re: Anthony] #5321282 01/13/20 06:49 AM
A
aquariuscsm Offline
A
I'd go with Ford spec 5W50.
SWEET car!!
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 0W20
Re: Supercharged 17 Mustang GT [Re: Anthony] #5321289 01/13/20 06:59 AM
4WD Offline
Lots of stuff making that kind of power run easy to find 0w40 synthetic
Re: Supercharged 17 Mustang GT [Re: Anthony] #5321323 01/13/20 07:57 AM
I
irekm Offline
I
I'm thinking on installing one on my 18' GT , ford recommends 5w50 in this case . I would use that
Re: Supercharged 17 Mustang GT [Re: Anthony] #5321340 01/13/20 08:18 AM
P
pzev Offline
P
On my 2016 F150 5.0 with a Roush blower (2.3l TVS), I use 0w-40 with good success based on several UOA's. I've also done UOA's on 5w-30, and that worked well though wear was slightly higher then the 0w-40. My Roush kit is far from stock and I beat on the truck at the drag strip often, and also daily drive it on top of that. I change the oil every 5k, and there is barely any oil consumption between changes. Coyote's are pretty tough and not too picky about oil. My engine runs cool, about 185 degrees, and this in turn reduces oil temperatures (oil to water cooler). Cold oil is thicker then warm oil, so I would never run 5w50 in my truck as the effective viscosity would be pretty high, robbing power and economy and potentially increasing wear.
2016 Ford F150 5.0 w/ Roush Supercharger
2012 Ford Mustang 5.0 (soon to be sold)
Re: Supercharged 17 Mustang GT [Re: Anthony] #5321346 01/13/20 08:29 AM
RDY4WAR Online Content
Online Content
No need to jump all the way to a 50 grade. What I'd look for is an oil with an HTHS >3.5 cP. That should be plenty sufficient. There's plenty of 30 grade oils out there that can achieve that.
Do you have a budget? There's some excellent oils out there for that application, but some people don't like spending $100 per oil change... though they have no problem spending thousands for a blower. lol (not pointing at you, but a friend of mine in particular)
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: Supercharged 17 Mustang GT [Re: RDY4WAR] #5321388 01/13/20 09:17 AM
A
Anthony Offline OP
A
For this car I don’t mind spending on good oil. Amsoil will likely be what I go with.
Re: Supercharged 17 Mustang GT [Re: Anthony] #5321390 01/13/20 09:20 AM
Cujet Online Content
Online Content
The 5W-50 (or 15W-50) favored by track day cars is for protection during periods of high oil temperature. It's also to protect highly loaded rod bearings. Remember that the inertia of high RPM can create rod bearing loads that exceed the loads placed by forced induction at lower RPM's.
But it's good to be mindful of the loads created by modification. Boost and high RPM = very high loads.
I echo the statement above, HTHS greater than 3.5
Re: Supercharged 17 Mustang GT [Re: Anthony] #5321530 01/13/20 12:10 PM
T
thastinger Offline
T
I run M1 Euro 0-40 in my 13 GT500. Have also ran RP HPS 5-30 in it, other than the factory fill (drained at 50 miles) it has never had 50W in it...but I don't track her.
Re: Supercharged 17 Mustang GT [Re: Anthony] #5321549 01/13/20 12:34 PM
Mr Nice Offline
I'd run a high quality 10w30 syn oil.
Save the 5w50 for the Daytona 500.
Re: Supercharged 17 Mustang GT [Re: Anthony] #5321556 01/13/20 12:44 PM
B
benjy Offline
B
in the heat of Georgia a 15w-40 or even 15W-50 for summers heat. few people realisze specs are given @ 40C + 100C after those temps oils continue to thicken + thin depending on the base oils + if you can do Scamsoil Redline would surely be my choice
Re: Supercharged 17 Mustang GT [Re: Anthony] #5321568 01/13/20 12:56 PM
J
Jimmy_Russells Offline
J
The oil grade you need is pretty much solely dependent on your sustained oil temperatures. 50 grade is absolutely not required unless you are tracking the car (not drag racing) and will see oil temps over about 260°.
If you want to use a 30 grade, that's fine, just know that PP is just about the thinnest 30 grade on the market.
Re: Supercharged 17 Mustang GT [Re: Anthony] #5321597 01/13/20 01:31 PM
H
HemiHawk Offline
H
I don't really have a recomendation as much as I wanted to say post some pics and a review when its installed! I've been thinking of some options for bumping up the power on my '15. The factory power is fun for awhile then starts to feel tame. Do you have the perf pack? I'd be worried the 3.73 gears might be too short with the blower. I think they're almost too short as it is.
2015 Mustang GT
2017 VW GTI sport
2001 Grand Cherokee
1995 Mustang GTS
Re: Supercharged 17 Mustang GT [Re: Anthony] #5321779 01/13/20 04:45 PM
B
BucDan Offline
B
IMO, find a 0w40 or 5w40 that holds BMW-LL04 certs. That should be more than enough.
Re: Supercharged 17 Mustang GT [Re: Anthony] #5321816 01/13/20 05:17 PM
R
RazorsEdge Offline
R
On my 500 horsepower Vortech Supercharged mustang, I've been running 10w30 Schaeffers oil with no issues.
2015 Ford Escape Ecoboost 1.6
Schaeffers 9000 5w20
1987 Mustang GT
Schaeffers 7000 10w30
