Duralast Max Ceramic Pads Photos!
by NASTI - 01/20/20 11:23 AM
expensive rotors
by Donald - 01/20/20 11:19 AM
3 Fram Ultra's Cut Open
by jetman - 01/20/20 10:31 AM
Standard Cab Commercial
by Duffyjr - 01/20/20 10:17 AM
The thin grease for firearms
by fnbrowning - 01/20/20 10:07 AM
Replace coil packs with spark plugs?
by jayjr1105 - 01/20/20 09:34 AM
Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
Oil ideas for 2 v6 fords and more
by kessellrun - 01/20/20 06:50 AM
Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
FCA and Foxconn partner on EV's
by OVERKILL - 01/19/20 08:55 PM
IIHS Crash pics of Full Size Trucks
by kstanf150 - 01/19/20 08:15 PM
Are Engine Splash Guards Really Needed?
by Mr_Luke - 01/19/20 08:14 PM
supertec cartridge filters
by super20dan - 01/19/20 06:17 PM
RSH, Bobjr94, GarageKings, JohnnyD1980, Harry_Seaward
70487 Registered Users
101 registered members (1978elcamino, 69GTX, 2002 Maxima SE, 3Aone, amblerman, AnthemBassMan, 6 invisible), 2,661 guests, and 23 spiders.
Topics300,348
Posts5,173,854
Members70,487
Most Online3,825
Jan 19th, 2020
Another Round of Spark Plug Diagnosis #5321221 01/13/20 01:45 AM
spavel6 Offline OP
1993 Ford Ranger 3.0 V6
2-year old spark plugs. Possible head gasket issues.
What do these plugs tell you?
[Linked Image]
[Linked Image]
2003 VW Jetta Wagon TDI 198k M1 5W40 TDT
2001 VW GTI VR6 250k T6 5W40
2001 VW Passat Wagon V6 4motion 110k PP 5W30
Re: Another Round of Spark Plug Diagnosis [Re: spavel6] #5321248 01/13/20 05:24 AM
L
Lubener Offline
L
A few look as though they were getting a dose of oil and perhaps some poor filtering of the intake air or poor sealing of the intake ductwork... The wet one #3 doesn't look like it is firing. If you were burning coolant, the plug's insulators would be white and extremely clean looking.
The "thinking" man's friend.
Re: Another Round of Spark Plug Diagnosis [Re: spavel6] #5321273 01/13/20 06:29 AM
R
Rudy1999 250 Offline
R
Are you sure that its not a 4.0 V6 ? clean then up re gap and put back in and see how they look in a week ? Just a idea?
A Salesperson/Problem Solver
Re: Another Round of Spark Plug Diagnosis [Re: spavel6] #5321279 01/13/20 06:43 AM
A
Amkeer Offline
A
Tells me the engine is not running properly.
2014 Toyota Tacoma D Cab 4.0 M1 5-30 101000
2008 Toyota Tundra D Cab 5.7 M1 5-20 98000 miles
2003 Toyota Tacoma Ex Cab 2.7 M1 5-30 214000 miles
2014.5 Toyota Camry SE 2.5 M1 0-20 72000
Re: Another Round of Spark Plug Diagnosis [Re: spavel6] #5321296 01/13/20 07:04 AM
4WD Offline
Used them too much when they were new
Re: Another Round of Spark Plug Diagnosis [Re: spavel6] #5321318 01/13/20 07:41 AM
supton Offline
That I'd rather be vehicle shopping.
They look a bit old, no sharp edges on the center electrode? If this isn't driven a lot, or has other issues, I'd replace and monitor.
2011 Toyota Camry, base, 2.5L/6MT, 200k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 220k, his
Re: Another Round of Spark Plug Diagnosis [Re: spavel6] #5321334 01/13/20 08:12 AM
A
ARCOgraphite Offline
A
They look bad. Some oil fouled others ??? fouled and mixture off.
One doesnt look like it was firing at all - that will screw up everything.
Engine rebuild time.
Or at least valve seals and check for coolant loss.
Does a the oil test for coolant? Pressure test?
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Another Round of Spark Plug Diagnosis [Re: spavel6] #5321343 01/13/20 08:24 AM
T
Trav Offline
T
Any kind of additive use in oil or fuel? You can get a quick and dirty head gasket test for short money that will at least tell you if combustion gasses are getting into the cooling system past the gasket or a small crack in the head casting, check the oil for coolant contamination and look for external leaks at the head, if nothing comes up its probably not a head gasket.
https://www.amazon.com/gp/product/B01N1NA22J/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Re: Another Round of Spark Plug Diagnosis [Re: spavel6] #5321365 01/13/20 08:56 AM
G
Gebo Offline
G
What is the make and model of these plugs? grin
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
PP HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Another Round of Spark Plug Diagnosis [Re: ARCOgraphite] #5321435 01/13/20 10:28 AM
DaleRider Offline
And that's probably from his head gasket problem....the spark plug tip is getting steam cleaned with every firing.....
Re: Another Round of Spark Plug Diagnosis [Re: spavel6] #5321584 01/13/20 01:18 PM
T
thastinger Offline
T
"What do these plugs tell you?"
That that engine isn't feeling healthy right now. Have you done a compression and leak down test on the cylinders? Wouldn't be at all surprised to find out this truck has plugged up cats
Re: Another Round of Spark Plug Diagnosis [Re: spavel6] #5321613 01/13/20 01:44 PM
M
meep Offline
M
How time has passed. I've driven worse. These wouldn't be far out for a carbeurated car at 80,000 miles back in the day. Center top pic catches my eye, if it were a fuel additive, that look would be more consistent among plugs. I'm curious if there's a coolant involvement, though it's a little dark in color for that.
Plugs along won't give the full story. You have other things going on that affect diagnosis.
-m
2018 F150
2015 crv (wifey!)
Re: Another Round of Spark Plug Diagnosis [Re: Gebo] #5321780 01/13/20 04:46 PM
A
A
I was looking at autolite Ir for my wife's subaru
could be them. Stainless Steel body and that inverted funnel shaped Ir tip.
here is a new one:
[Linked Image]
Re: Another Round of Spark Plug Diagnosis [Re: ARCOgraphite] #5321832 01/13/20 05:45 PM
G
Gebo Offline
G
here is a new one:
[Linked Image]
Thanks, ARCOgraphite. I was more interested if they were the correct plugs for his Ranger.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
PP HM 10W-30
Re: Another Round of Spark Plug Diagnosis [Re: spavel6] #5322193 01/14/20 06:11 AM
K
ka9mnx Offline
K
First picture: Left plug is firing normally. Center plug is carbon fouled (old?). Right plug is not firing.
Second picture: Left plug is firing normally. Center and right plug are oil fouled.
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
