Ford 5R55E Auxiliary Transmission Filter
by benjamming - 01/18/20 09:33 AM
Do all synthetic oils act as a cleaner?
by Loobit - 01/18/20 08:26 AM
Mobil 1 ESP now sold in 5qt jugs
by Patman - 01/18/20 08:12 AM
Mobil 1 Extended Performance Oil Filters
by jrommelt - 01/18/20 08:08 AM
These the same?
by Bettez88 - 01/18/20 06:53 AM
MaxLife SB 10w40 on Sale
by Mad_Hatter - 01/18/20 04:27 AM
Walmart Oil Change?
by Talent_Keyhole - 01/18/20 12:50 AM
Bleh, mother’s gas furnace fan burned up
by Rmay635703 - 01/17/20 11:23 PM
Rotella gas truck vs Valvoline modern engine
by MoPowa - 01/17/20 09:25 PM
Afton Specification Handbook -- September 2019
by Gokhan - 01/17/20 09:04 PM
Old Retired Navy Commander
by KeithS_NW_Ohio - 01/17/20 08:58 PM
Mobil 1 EP vs Mobil 1 EP Truck & SUV
by jrommelt - 01/17/20 08:29 PM
Stick with Maxlife or go back to DW-1?
by jayjr1105 - 01/17/20 07:58 PM
Thread locker
by zzyzzx - 01/17/20 07:56 PM
A preppers tale
by Bluestream - 01/17/20 07:50 PM
19 Ram Rebel oil choices
by Schwifty - 01/17/20 07:35 PM
Is it impossible to get a loan for an older vehicle?
by FordBroncoVWJeta - 01/17/20 07:22 PM
2EHA, jonnyb433, kzbd, 54Robert, CPA1989
70464 Registered Users
101 registered members (2KBMW, 53' Stude, antonmnster, 77GrandPrix, 4WD, alphadog, 9 invisible), 1,925 guests, and 18 spiders.
Topics300,275
Posts5,172,203
Members70,464
Most Online3,728
Jan 11th, 2020
Rotated tires the wrong way? #5321154 01/12/20 09:52 PM
A
A_User55555 Offline OP
A
[Linked Image]
The first time I had my tires rotated, I accidentally told my mechanic to rotate them with the rearward cross pattern (A) in the picture.
However since I have a FWD car, It was supposed to be a Forward Cross tire rotation (C).
The next time I had a tire rotation, they did the Forward Cross rotation. This essentially brings back my tires to the position they were in when I bought the tires.
Is there any long term issue for having the wrong rotation done? Should I get another rotation again to get them wearing evenly?
2011 Cadillac DTS. No the headgaskets have not blown.....
5W-30 Napa Full Synthetic with a Carquest 85522 (Wix) Filter
Re: Rotated tires the wrong way? [Re: A_User55555] #5321159 01/12/20 09:57 PM
pkunk Offline
I like the X pattern. I think it evens out the wear better.
8200 ft elevation in the Sangre de Cristos
2008 Mini Cooper Clubman (toad)
2000 Mercedes ML320
1994 Dodge 2500 Cummins
1999 Ford F53 V10 Coachman Motorhome 34ft
Re: Rotated tires the wrong way? [Re: A_User55555] #5321166 01/12/20 10:09 PM
1
1WildPig Offline
1
Nah... You're good to go, just keep the tire pressure checked and keep rotating the same way from now on.
Re: Rotated tires the wrong way? [Re: A_User55555] #5321170 01/12/20 10:13 PM
I
Ihatetochangeoil Offline
I
Doesn't matter if you do rearward cross or forward cross...Duh, as long as you're consistent with how you rotate, eventually, the tires will be on all 4 corners of the vehicle.....Your diagrams do not take DIRECTIONAL tires into account, which I have...All I can do is front to back and forth....then have the tires broken off the wheels and turned over, so they'll end up on the other side of the vehicle.
Find something more important to obsess over.
Re: Rotated tires the wrong way? [Re: A_User55555] #5321200 01/12/20 11:05 PM
ctechbob Offline
Personally, I've never seen a big difference between left and right wear on any of mine, so I simply swap front to rear on same side. I suppose if you have really soft tires and big road crowns in your area then you might see a L/R difference and the crossing would make sense, but that all depends on your setup/location.
2008 Acura TL Type S-165k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W20
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: Rotated tires the wrong way? [Re: ctechbob] #5321201 01/12/20 11:10 PM
R
Rand Offline
R
I find cross rotating quiets the tires down on MT Equipped subaru which tend to have very even wear front to back.
as long as I dont wait too long.
Re: Rotated tires the wrong way? [Re: A_User55555] #5321211 01/13/20 12:06 AM
J
JLTD Offline
J
Have always done "A" on all vehicles with good results. My thought is that the tires on the rear move forward to rotate same direction on the steering wheels.
"Let’s not pretend like 0w20 is anything but a CAFE required crutch to eek another 1/2MPG" - BLND1
Hers: 2018 Ford Flex AWD EB, dealer fill
His: 2015 4Runner 60k, SS 5w20/Amsoil
Re: Rotated tires the wrong way? [Re: 1WildPig] #5321227 01/13/20 04:06 AM
Sayjac Offline
This. Key is you're rotating them. No worries.
Re: Rotated tires the wrong way? [Re: A_User55555] #5321267 01/13/20 06:21 AM
K
Kira Online Content
Online Content
K
I've always done the forward cross. I have a little mnemenic aid.
Jack the back, swap 'em
Then front to rear one side at a time.
I've always had evenly wearing tires.
My old pal who mocked tire rotation? He's gone now.
Re: Rotated tires the wrong way? [Re: A_User55555] #5321290 01/13/20 07:00 AM
Cujet Offline
Many people don't know a few of the reasons to rotate non-directional tires side to side, beyond the obvious difference in wear rates front to rear.
1) Tread blocks wear at the leading edge, caused by braking. (can cause tire noise)
2) Slight differences in wear rates side to side
3) Increased wear rate on the Right Rear tire on rear wheel drive vehicles with limited slip differentials or lead footed drivers.
Re: Rotated tires the wrong way? [Re: A_User55555] #5321303 01/13/20 07:15 AM
supton Offline
My cars seems to develop feathered tires on the rear (on my second car doing that, for some reason the wife has never had that issue). So I stick with a forward cross (my vehicles are FWD's).
Some people never rotate and do ok, so I'm in the camp of, it doesn't matter. Do the "proper" rotation next time, but don't lose sleep over it, it's close enough.
2011 Toyota Camry, base, 2.5L/6MT, 200k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 220k, his
Re: Rotated tires the wrong way? [Re: A_User55555] #5321305 01/13/20 07:20 AM
CapriRacer Offline
THEE most important thing about rotating tires is the front to rear difference.
Steer tires tend to wear the shoulders and drive tires tend to wear the centers. In a RWD, rotation evens out the wear and results in a longer life - up to 15%. In a FWD, the front tires are doing both actions, so the fronts wear more rapidly - about 2 1/2 times as fast as the rears.
You want your tires to wear out at the same time. That way the car maintains its front/rear handling balance throughout the life of the tires.
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: Rotated tires the wrong way? [Re: Cujet] #5321366 01/13/20 08:56 AM
P
Pew Offline
P
Nothing a good ole' burnout can't fix laugh
Re: Rotated tires the wrong way? [Re: Pew] #5321394 01/13/20 09:30 AM
Cujet Offline
crackmeup
Yes, I think you may be correct.... That could serve to even out the tread blocks.
On a serious note, many modern vehicles have larger rear brakes than they would have had in the past. The trend is to use the rear brakes more under light loads. This gives a better feel, lower chance of upset if low traction is encountered and often less nose dive. But it does lead to rear tire tread blocks wearing at the leading edges.
Re: Rotated tires the wrong way? [Re: CapriRacer] #5322427 01/14/20 12:36 PM
U
UG_Passat Offline
U
Sounds like a conspiracy theory to force people to buy 4 tires at a time. grin2 grin2 grin2
Since "experts" claim you want to keep the tires with more tire depth on the rear, then tire rotations are not necessary until the front tires wears out and you buy 2 new tires, then the old ones go up front and the new ones are installed on the rear.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
