unthinkable problem after oil change
by NH73 - 01/25/20 07:37 AM
Anybody burn wood for heat? Advice please.
by dlundblad - 01/25/20 07:21 AM
2002 cummins
by coondog - 01/25/20 07:07 AM
New Mercedes Ute
by Shannow - 01/25/20 03:04 AM
A decent battery charger for sub $50?
by michaelluscher - 01/25/20 02:03 AM
Temperature swing affects on oil
by leeaspell - 01/25/20 12:58 AM
Coefficient of Friction
by jrommelt - 01/24/20 11:46 PM
2017 Chevy Cruze Diesel Oil
by Ponch - 01/24/20 11:03 PM
electric motor amp rating
by motor_oil_madman - 01/24/20 10:42 PM
Radio, Instrument panel, display, AC cutting off
by DrDanger - 01/24/20 09:39 PM
Filter Brand Quality Change?
by BBDartCA - 01/24/20 09:21 PM
Autozone $7 off $30
by GMguy84 - 01/24/20 09:17 PM
Honda Power Steering Fluid
by shortlid - 01/24/20 09:14 PM
Autozone Clearance 2020 M1EP
by GMguy84 - 01/24/20 09:11 PM
Spark Plugs
by A_Spruce - 01/24/20 09:00 PM
Flank drive wrenches
by spasm3 - 01/24/20 08:39 PM
Auto assembly and mfg. logistics
by P10crew - 01/24/20 08:26 PM
Kodiak
by P10crew - 01/24/20 08:05 PM
Whoop, coondog, steelbeams, Pete44, Connie7
70521 Registered Users
98 registered members (Astro14, 1foxracing, Aero540T, 53' Stude, 2009Edge, 2002 Maxima SE, 7 invisible), 2,206 guests, and 18 spiders.
Topics300,521
Posts5,177,678
Members70,521
Can my 2005 Mercedes E320 CDI use Shell Rotella T6? #5321132 01/12/20 09:15 PM
J
juicester2013 Offline OP
J
I’ve been using Liqui Moly Long Life for past 50k miles in my 2005 Mercedes E320 CDI and I recently came across Shell Rotella T6 in the diesel section of Wal-Mart. It has the MB 228.31 certification spec on it. I’m not sure if I can use it in my car. I don’t want to start an oil war, but the price is way cheaper and it’s way more readily available.
1. What MB spec oil did Mercedes specify for my Benz back in 2005? Currently Mercedes diesels use 229.51
2. Would a MB 228.31 spec oil work in my Benz?
Re: Can my 2005 Mercedes E320 CDI use Shell Rotella T6? [Re: juicester2013] #5321153 01/12/20 09:51 PM
L
Lolvoguy Offline
L
welcome
What does your manual say? (the one located in the glove compartment).
If it says so, then go for it. It's one of the best oils on the market.
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Can my 2005 Mercedes E320 CDI use Shell Rotella T6? [Re: juicester2013] #5321603 01/13/20 01:36 PM
K
Kamele0N Offline
K
I am wondering the same for my Yaris....
Instead of ACEA C3....if I can use ACEA E6/E9...
But saps levels for EURO4-5-6 are not the same for PCMO vs HDEO smile
Pay attention here....since HDEOs in "low saps" oils can vary from 0.9x to 1.1
PCMO is 0.8MAX for C3 or 0.5max for C4
I will try Shell Rimula R6ML in it since it has saps level around 0.9x (just slightly higher then C3 level)
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: Can my 2005 Mercedes E320 CDI use Shell Rotella T6? [Re: juicester2013] #5321618 01/13/20 01:48 PM
L
Linctex Offline
L
I wouldn't worry about SAPS level if the engine doesn't consume oil.
