30 monograde
by mpack88 - 01/21/20 10:15 AM
Extended life destroys copper?
by mpack88 - 01/21/20 09:49 AM
Project Farm Lucas transmission additive video
by 1978elcamino - 01/21/20 09:43 AM
1.8t 0w40, plus a situation.
by WMNN1988 - 01/21/20 09:25 AM
Mobil 1™ ESP X2 0W-20 US Availability
by TheIceStormof06 - 01/21/20 08:46 AM
Wire harness/connector
by Redright9 - 01/21/20 07:58 AM
Will You Jump Someone Else's Car?
by Gebo - 01/21/20 07:08 AM
NAPA Edge $20 A/R
by dblshock - 01/21/20 04:54 AM
8 Utes on test.
by Silk - 01/21/20 03:03 AM
Magnetic Socket Rails
by The Critic - 01/21/20 01:19 AM
Oreilly Select complete fuel system cleaner
by keantoken - 01/21/20 12:19 AM
Local Costco Has all Oils and Viscosities $10 Off
by SteveG4 - 01/21/20 12:14 AM
EBC Rotor Pictures
by BBDartCA - 01/20/20 11:28 PM
2012 Acura TSX Wagon
by WhyMe - 01/20/20 10:47 PM
Should I Stick With My Truck? Buy "new"?
by Miller88 - 01/20/20 08:04 PM
Not sure what Pep boys is up to
by Chris142 - 01/20/20 07:38 PM
PastPresMike, RedBeard83, dfrybeck, ckinch1, EAC1
70494 Registered Users
106 registered members (2011335d, 53' Stude, 67ZL1, 2015_PSD, 28oz, 1978elcamino, 9 invisible), 2,171 guests, and 16 spiders.
Topics300,385
Posts5,174,704
Members70,492
A/C Blowing Hot on Grand Marquis #5321063 01/12/20 07:44 PM
J
John_K Offline OP
J
Found online that folks say you can hold down buttons on AC module for it to go into diagnostic mode. Anybody out there know if this is true?
2009 Mercury Grand Marquis, 8 cyl auto, 95xxx miles, PU/Fram Ultra
2005 Hyundai Sonata, 4 cyl auto, 99xxx miles, Maxlife/OEM Filter
Current oil stash: 459 qts.
Re: A/C Blowing Hot on Grand Marquis [Re: John_K] #5321078 01/12/20 07:55 PM
J
JC1 Offline
J
Is this the test you are referring to?
https://www.youtube.com/watch?v=wSLjb8xh7Eg
Are the actuator motors stuck in one position? On my 2015 Caravan it does that when you want to start using the AC (after winter is done and it gets hot out).
The one giving me problems is the passenger side which is to the left of the glove box underneath the left part of the foot well carpeting.
What I found besides the obvious solution of new Actuator motors, was to find where the actuators are and if they are accessible, give them a few firm taps (don't go gorilla) with the side of a hammer. Then turn on the AC unit and cycle it between hot and cold and that seems to loosen up a stuck motor. At least on a Dodge Caravan.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: A/C Blowing Hot on Grand Marquis [Re: John_K] #5321088 01/12/20 08:05 PM
Chris142 Offline
Compressor coming on? If so.is the suction line cold?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: A/C Blowing Hot on Grand Marquis [Re: John_K] #5321206 01/12/20 11:35 PM
F
Falcon_LS Offline
F
Petro-Canada Duron HP 15W-40 CK-4/SN
99 Explorer: H17W02
00 Pajero: XG9688
01 Grand Marquis: XG2
05 Envoy: XG9837
Motorcraft 5W-50:
18 Mustang GT: XG10575
Re: A/C Blowing Hot on Grand Marquis [Re: John_K] #5321243 01/13/20 05:19 AM
dnewton3 Offline
Global Moderator
Global Moderator
AS shown by others; yes - it's true, there is a self diagnostic test.
If you're only getting hot air, regardless of desired setting, then the BDA (blend door actuator) is bad. Not uncommon on the Panther cars. Not really "hard" to fix, but a long, tedious task. Have to pull the entire dash panel (the whole thing, not just the facia bits on the front) away from the chassis a bit to reach it. I did mine and successfully was able to do it in a few hours with help of a friend. There are many vids on this; watch several and you'll get the idea.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
