Shell Rotella gas truck oil change intervals?
by gtrplr71 - 01/19/20 07:12 AM
Ford Focus belt idler puller bolt ?
by rkpatt - 01/19/20 06:51 AM
Havoline 5w20 $1.72/quart
by Villalobos - 01/19/20 05:42 AM
Amazon 5qt PUP 5w-20 $16.24
by Matt1980 - 01/19/20 03:42 AM
US Miltary News - F22
by ZeeOSix - 01/19/20 03:09 AM
OEM to Ravenol
by graphine - 01/19/20 02:38 AM
D905 Brake Pads: Bosch vs. Centric vs. Akebono
by The Critic - 01/19/20 01:55 AM
Dodge dart running issues after filling up fuel
by ram_man - 01/19/20 12:58 AM
Akebono ProAct brake pads now include hardware
by The Critic - 01/19/20 12:43 AM
16 Audi S3 G13 Coolant - 40,500 miles
by agpatel - 01/19/20 12:43 AM
BMW “G3” Axle Alternatives?
by E365 - 01/19/20 12:20 AM
Scan Tool recommendation
by zmelli - 01/18/20 11:57 PM
Keyless Entry Help Needed
by DeafBrad - 01/18/20 11:55 PM
75/140 owners manual vs 75/90 tag
by BigGee - 01/18/20 11:36 PM
toro super recycler with b&s engine HomeDepot
by passgas55 - 01/18/20 06:43 PM
75w140?
by mpack88 - 01/18/20 06:00 PM
Are all 9012 bulbs HIR2?
by dvancleve - 01/18/20 03:30 PM
Ariens L-3 Synthetic Severe-Duty Gear Lube
by Astro_Guy - 01/18/20 02:04 PM
LSx Crank lock
by P10crew - 01/18/20 02:03 PM
ST9688 gasket
by Farnsworth - 01/18/20 01:26 PM
madjid, michWB, Brianhefty, JimBremer, Katdaddy
70471 Registered Users
73 registered members (B767capt, 4WD, Astro_Guy, 53' Stude, atikovi, 12CruzeEcoAt, 6 invisible), 1,521 guests, and 25 spiders.
Topics300,307
Posts5,172,896
Members70,471
Most Online3,728
Jan 11th, 2020
Circle D for 4L80E #5321053 01/12/20 07:37 PM
P10crew Offline OP
I’m going to order the 278 MM converter tomorrow and have a couple questions. Do I use a dished LQ flexplate and the stock spacer? Is the stamped front a good choice or should I opt for the billet front option?
Re: Circle D for 4L80E [Re: P10crew] #5321073 01/12/20 07:52 PM
R
Rand Offline
R
I guess you just assume everyone remembers your truck and such but it might be a good idea to put that info in here.
Re: Circle D for 4L80E [Re: P10crew] #5321077 01/12/20 07:55 PM
P10crew Offline OP
4100 lb 500-550 hp and tq
2000 4l80
2001 LQ 6.0L
Blueprinted 4l80
Re: Circle D for 4L80E [Re: P10crew] #5321123 01/12/20 09:03 PM
O
oldhp Offline
O
You need to contact a high-performance transmission shop. I'm sure they could help you out.
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: Circle D for 4L80E [Re: P10crew] #5321139 01/12/20 09:24 PM
clinebarger Offline
You will need a 4L60E/6L80E dished flexplate......No spacer required! The early "Revolver" style ('98-'00) are the strongest OE flexplates.
Stock LSx/4L80E applications used a flat flexplate & a spacer, But Circle D uses 278mm 4L60E front covers to make their HP converters.
I wouldn't bother with a Billet cover on a HP series unit.....Step-up to the Pro Series ito get a better converter to go with a Billet cover.
Disable the PWM TCC apply & don't lock it under WOT.....And a stock front cover will be fine for a long time!
2001 Chevy Camaro L92/4L80E
Re: Circle D for 4L80E [Re: P10crew] #5321155 01/12/20 09:52 PM
P10crew Offline OP
Thanks buddy!
So 98-00 gm truck with 5.3 or 6.0?
Re: Circle D for 4L80E [Re: P10crew] #5321163 01/12/20 10:05 PM
clinebarger Offline
It will be a 4L60E flexplate.....So very few 6.0L trucks would be included. But V8 F-Bodies are a good source other than 4.8L/5.3L trucks.
Re: Circle D for 4L80E [Re: P10crew] #5321176 01/12/20 10:19 PM
P10crew Offline OP
[Linked Image]
Is this the revolver?
Re: Circle D for 4L80E [Re: P10crew] #5321183 01/12/20 10:28 PM
P10crew Offline OP
The revolver must be the ones with the round holes. This one is off an 01 5.3
Re: Circle D for 4L80E [Re: P10crew] #5321186 01/12/20 10:34 PM
clinebarger Offline
That's the "Bean" style smile which ran from 2001 to 2007. I wouldn't call them weak though, In fact it's stronger than the 2007-2013 "Hard Bend" style.
Hard Bend style, I call it that because the dish is very pronounced!
[Linked Image from i.imgur.com]
Re: Circle D for 4L80E [Re: P10crew] #5321188 01/12/20 10:37 PM
clinebarger Offline
Yes sir......
Re: Circle D for 4L80E [Re: P10crew] #5321190 01/12/20 10:43 PM
P10crew Offline OP
Ok I got a bean plate and I will order revolver plate.
duh
Lol
Re: Circle D for 4L80E [Re: P10crew] #5321995 01/13/20 08:21 PM
P10crew Offline OP
CLine I talked to Chris? @ circle D today. The stamped case is fully rated to 550/550 the billet front half option boosts it to 750/750. He also mentioned to disable WOT PWM TCC.
I want to ask you the following questions.
Why are we disabling lock up @ WOT?
On the rare occasion that the go pedal hits the floor what is the hot rod going to feel like or don’t you notice that it’s not locked?
When we dyno we always lock them up... this won’t hurt it will it?
Re: Circle D for 4L80E [Re: P10crew] #5322033 01/13/20 09:08 PM
clinebarger Offline
Locking the converter on a chassis dyno improves power numbers.....But, You mash the pedal with the converter already locked on the dyno which is much different than having the converter lock-up during a WOT pull on the street.
With a docile converter like the HP series....You won't notice much difference & the TC clutch will live a lot longer.
Re: Circle D for 4L80E [Re: P10crew] #5322060 01/13/20 09:34 PM
P10crew Offline OP
Ok got it thanks.
That is a good company to work with. He Gave me $100 off and a bunch of bling.
