Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
30 monograde
by mpack88 - 01/21/20 10:15 AM
Extended life destroys copper?
by mpack88 - 01/21/20 09:49 AM
Project Farm Lucas transmission additive video
by 1978elcamino - 01/21/20 09:43 AM
1.8t 0w40, plus a situation.
by WMNN1988 - 01/21/20 09:25 AM
Mobil 1™ ESP X2 0W-20 US Availability
by TheIceStormof06 - 01/21/20 08:46 AM
Wire harness/connector
by Redright9 - 01/21/20 07:58 AM
Will You Jump Someone Else's Car?
by Gebo - 01/21/20 07:08 AM
NAPA Edge $20 A/R
by dblshock - 01/21/20 04:54 AM
8 Utes on test.
by Silk - 01/21/20 03:03 AM
Magnetic Socket Rails
by The Critic - 01/21/20 01:19 AM
Oreilly Select complete fuel system cleaner
by keantoken - 01/21/20 12:19 AM
Local Costco Has all Oils and Viscosities $10 Off
by SteveG4 - 01/21/20 12:14 AM
EBC Rotor Pictures
by BBDartCA - 01/20/20 11:28 PM
2012 Acura TSX Wagon
by WhyMe - 01/20/20 10:47 PM
Should I Stick With My Truck? Buy "new"?
by Miller88 - 01/20/20 08:04 PM
reylafo, PastPresMike, RedBeard83, dfrybeck, ckinch1
70495 Registered Users
97 registered members (aba4430, 1978elcamino, 53' Stude, 2011335d, 28oz, 90crvtec, 5 invisible), 2,248 guests, and 22 spiders.
Topics300,387
Posts5,174,744
Members70,495
Transmission Fluid Change on 125,000 Mile Vehicle #5321048 01/12/20 07:30 PM
A
Ativin Offline OP
A
Hey All,
I have a 2002 Ford Ranger with automatic transmission and 125,000 miles on it. As far as I know, the transmission fluid has never been changed. I was wondering if I should go ahead and change it, or if I'd be doing more harm than good at this point? I was thinking of maybe doing one of the following:
(1) Doing a drain and fill with maybe a transmission filter change.
(2) Siphoning and replacing maybe 1 quart of fluid every 1,000 miles or so from the dipstick hole?
Any recommendations would be really appreciated.
Here's a photo of what the current fluid looks like:
[Linked Image]
Thanks in advance!
Re: Transmission Fluid Change on 125,000 Mile Vehicle [Re: Ativin] #5321050 01/12/20 07:34 PM
J
JC1 Offline
J
That fluid looks pretty clean IMO.
I would do a drain and fill first. Drive it for a few hundred miles and then do another drain and fiil along with dropping the Transmission pan and replacing the filter and cleaning the inside of the pan and magnets.
Then every 2 years or 30K miles or whatever you are comfortable with, I would do a drain and fill. Every second or third time, I would drop the pan and change the filter.
I know there are some guys that never change Transmission fluid or just do drain and fills and never touch the filter. The only cars I don't change the AT filters on, are my 97 Civic.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Transmission Fluid Change on 125,000 Mile Vehicle [Re: Ativin] #5321069 01/12/20 07:50 PM
E
eljefino Offline
E
+2, what you have is clean. If it were dirty you'd have a brown or grey ring around your pink blots.
Change it anyway. I brought a nearly dead cutlass ciera back to life by changing its fluid. Old filter was so plugged it wouldn't make pressure.
The whole "old fluid holds it all together" is a falsity.
Re: Transmission Fluid Change on 125,000 Mile Vehicle [Re: Ativin] #5321091 01/12/20 08:09 PM
W
WillB Offline
W
Do a spill and fill, change filter.
Thanks,
Will
2016 Jeep Sahara JKU
2017 Ram 1500 Crew Cab 4x4 Hemi 5.7 6 Speed Auto - Traded.
2011 GMC 1500 CC 4WD 4.8 - Traded.
04 GMC 1500CC Z71 350,000km 217,000 miles - Retired.
Re: Transmission Fluid Change on 125,000 Mile Vehicle [Re: Ativin] #5321112 01/12/20 08:48 PM
slacktide_bitog Offline
If your transmission doesn't have a drain plug, get an aftermarket pan that has one smile
Re: Transmission Fluid Change on 125,000 Mile Vehicle [Re: Ativin] #5321215 01/13/20 12:55 AM
J
Jetsfan421 Offline
J
That fluid is serviceable. Go ahead and change it out with no worries. A little lubegard red never hurt a thing either.
Re: Transmission Fluid Change on 125,000 Mile Vehicle [Re: Ativin] #5321222 01/13/20 03:12 AM
F
FordBroncoVWJeta Offline
F
I highly doubt that's the original ATF. Looks way too new.
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2003 Ford Taurus 3.0 Vulcan
Re: Transmission Fluid Change on 125,000 Mile Vehicle [Re: FordBroncoVWJeta] #5321232 01/13/20 04:22 AM
demarpaint Offline
Me too. Either way I'd change it since the OP is not sure when the transmission was last serviced.
God Bless Our Troops
Re: Transmission Fluid Change on 125,000 Mile Vehicle [Re: Ativin] #5321234 01/13/20 04:36 AM
L
Lubener Offline
L
I would drop the pan, replace the pan with one equipped with a drain plug, change the filter, refill and you can then easily do additional partial changes quick and easy.
The "thinking" man's friend.
Re: Transmission Fluid Change on 125,000 Mile Vehicle [Re: Ativin] #5321281 01/13/20 06:47 AM
K
Kira Offline
K
Is your Ranger a RWD or 4WD?
The 4WD has a deeper pan and a filter with an extended pick-up.
I installed a Dorman pan (with drain plug) on my Ranger 4WD and changed the filter.
You can do this on a RWD Ranger. It'll increase the pan capacity.
My vehicle had <50K. The fluid was darkened but not bad.
I'm going to wait until Summer to perform a drain & fill.
My OE deep pan can be had for $10 over postage.
Re: Transmission Fluid Change on 125,000 Mile Vehicle [Re: Ativin] #5321291 01/13/20 07:00 AM
J
jeepman3071 Offline
J
When in doubt, change it out. A drain and fill won't hurt anything.
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (56k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Transmission Fluid Change on 125,000 Mile Vehicle [Re: jeepman3071] #5322039 01/13/20 09:11 PM
B
bbhero Offline
B
Good way to go ^^^^^^^^
Nissan Altima 3.5 Coupe
Cam2 full synthetic 5w30 Wix 57356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Transmission Fluid Change on 125,000 Mile Vehicle [Re: Ativin] #5322044 01/13/20 09:15 PM
dblshock Offline
use the OEM fluid.
05 Lexus GX470 175k
640:1 TCW-3
M1 0W40 XG-3614
Toyo Open Country H/T II
06 4Runner SR5 155k
640:1 TCW-3
M1 0W40 XG-3614
Falken Wildpeak AT3W
Re: Transmission Fluid Change on 125,000 Mile Vehicle [Re: demarpaint] #5322047 01/13/20 09:16 PM
B
bbhero Offline
B
I agree demarpaint.... The fluid does look quite new...
Interestingly the new fluid in my car looks rather different... A fair amount less color on it now. Before it looked like motor oil with about 2k miles on it while it was on the dip stick. Now it looks like it is translucent clear. Rather hard to see on the dip stick. Like brand new motor oil is when first put in.
Re: Transmission Fluid Change on 125,000 Mile Vehicle [Re: dblshock] #5322133 01/14/20 01:08 AM
dave1251 Offline
Originally Posted by dblshock
use the OEM fluid.
No. Just use any licensed MERCON V.
don't use.
