Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
30 monograde
by mpack88 - 01/21/20 10:15 AM
Extended life destroys copper?
by mpack88 - 01/21/20 09:49 AM
Project Farm Lucas transmission additive video
by 1978elcamino - 01/21/20 09:43 AM
1.8t 0w40, plus a situation.
by WMNN1988 - 01/21/20 09:25 AM
Mobil 1™ ESP X2 0W-20 US Availability
by TheIceStormof06 - 01/21/20 08:46 AM
Wire harness/connector
by Redright9 - 01/21/20 07:58 AM
Will You Jump Someone Else's Car?
by Gebo - 01/21/20 07:08 AM
NAPA Edge $20 A/R
by dblshock - 01/21/20 04:54 AM
8 Utes on test.
by Silk - 01/21/20 03:03 AM
Magnetic Socket Rails
by The Critic - 01/21/20 01:19 AM
Oreilly Select complete fuel system cleaner
by keantoken - 01/21/20 12:19 AM
Local Costco Has all Oils and Viscosities $10 Off
by SteveG4 - 01/21/20 12:14 AM
EBC Rotor Pictures
by BBDartCA - 01/20/20 11:28 PM
2012 Acura TSX Wagon
by WhyMe - 01/20/20 10:47 PM
Should I Stick With My Truck? Buy "new"?
by Miller88 - 01/20/20 08:04 PM
reylafo, PastPresMike, RedBeard83, dfrybeck, ckinch1
70495 Registered Users
95 registered members (1978elcamino, 2015_PSD, 2011335d, 28oz, 68nova, 77GrandPrix, 8 invisible), 2,185 guests, and 18 spiders.
Topics300,387
Posts5,174,722
Members70,494
Motul 300V report #5320734 01/12/20 12:55 PM
Sportage333444 Offline OP
Do any of you have maybe UOA Motul 300V 10w40 oil.
I want to see if it is suitable for touring motorcycles.
Thank you.
Re: Motul 300V report [Re: Sportage333444] #5320737 01/12/20 01:03 PM
SubieRubyRoo Offline
Does the oil meet the specs of your touring motorcycle? If yes, the oil is suitable.
There's nothing a UOA will tell you that can guarantee it will be suitable for your application. It depends if it meets the specs and weight required, that's all.
A UOA is good for insight on if the oil remained in grade, insolubles, particle counts (if tested), and the amounts of detergents and AW compounds in the oil, and that's about it. Anything else "derived" from a UOA report is pure speculation, as the UOA is NOT a valid test to determine "wear" or even see if your engine is on the verge of a catastrophic failure. You need different tests for quantifying wear, and they are extremely pricey.
Re: Motul 300V report [Re: Sportage333444] #5320756 01/12/20 01:31 PM
BusyLittleShop Offline
Motul 300V 10w40 will meet and exceed your mileage expectations...
[Linked Image]
Larry L
Have a Wheelie NICE day
94 RC45 #2 58,000 on 30 Grade, Currently Mobil 1 5W30 SN
2002 Camaro Mobil 1 5W30
1952 De Havilland Chipmunk
Re: Motul 300V report [Re: Sportage333444] #5320831 01/12/20 02:48 PM
blupupher Offline
'18 Santa Fe: PP 10W-30/OEM
'18 Soul: Synpower 5W-30/PG
'10 Santa Fe: Synpower 5w-30/D+
'04 F150: Magnatec 10w-30/ST
'12 xB: M1EP 0W-20/CQ Blue
'02 F150: Magnatec 5W-20/D+
'94 VT1100: Peak 15W-40/D+
Re: Motul 300V report [Re: Sportage333444] #5320855 01/12/20 03:25 PM
K
kschachn Offline
K
Crazy stuff, but you don't determine the suitability of a motorcycle oil via a $35 UOA. Somehow I think you already knew that, right?
What SubieRubyRoo posted above, and what I know I already posted in one of your other threads is correct. The only way to determine suitability is via the manufacturer's specs and approval requirements, and what the oil carries as approvals and specs.
Why is this concept sometimes so hard to grasp?
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Motul 300V report [Re: Sportage333444] #5320901 01/12/20 04:13 PM
M
M56959 Offline
Global Moderator
Global Moderator
M
Multiple threads on the same topic is considered trolling.
