Shell selling rebranded Pennzoil in Europe?
by FordCapriDriver - 04/02/20 02:54 AM
Mitsubishi Mirage for Basic Transportation
by parimento1 - 04/02/20 12:54 AM
Amsoil EaOM103
by Lufty - 04/02/20 12:46 AM
Wheel bearing grease discussion
by Zahndkile - 04/01/20 11:10 PM
Low mileage Hundai Kona 5w-20 or 5w-30?
by j_mac - 04/01/20 10:43 PM
Napa platinum and Napa oil
by NavyVet88 - 04/01/20 10:29 PM
5.0 oil leak f150
by oilstudent24 - 04/01/20 09:17 PM
Dodge Durango 3.6L - HPL 5w-20 - 5,000 Miles on oil
by wwillson - 04/01/20 09:14 PM
Does a cold engine make more power?
by Avery4 - 04/01/20 08:48 PM
Facebook Marketplace riddled with scam RV ads
by atikovi - 04/01/20 08:14 PM
2017 Corvette / 14.4k / ACDelco MTF
by dparm - 04/01/20 08:10 PM
Replacing Rusty Brake Lines
by 92saturnsl2 - 04/01/20 08:08 PM
2017 Corvette / 14.4k / ACDelco 75w90 gear oil
by dparm - 04/01/20 07:59 PM
Pennzoil Ultra Additive Fallout in Sump
by 5AcresAndAFool - 04/01/20 07:50 PM
2008 BMW M3, BMW TwinPower Turbo 10W-60, 4915 mi
by d00df00d - 04/01/20 07:41 PM
2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles
by dparm - 04/01/20 07:40 PM
Just when you think it can't get any worse
by Chris142 - 04/01/20 07:40 PM
VIRGIN NAPA PRO SELECT 21334
by 53' Stude - 04/01/20 07:18 PM
Code, Adam1, ripcord, KenoshaWizard, junipertoxic
71074 Registered Users
28 registered members (blufeb95, bbhero, 1foxracing, Blackgogo, Alex_K, avi1777, 4 invisible), 689 guests, and 26 spiders.
Topics303,470
Posts5,235,706
Members71,074
Which filter for next change: Purflux chevron vs MANN vs Manufacturer filter #5320733 01/12/20 01:54 PM
DrSmith Offline OP
Here for comparison are three filters. Two of the three are made by Purflux, a division of Sogefi.
[Linked Image]
[Linked Image from i.imgur.com]
As can be seen from a quick visual inspection, both of chevron style filters are made by purfux and this is reflected on the filter cap:
The Purflux:
And the Manufacturers:
By looking it appears that whilst the construction is identical, the manufacturer has requested a thicker media be used that is visible where the two ends of the filter media meet.
To contrast with this there is the MANN which has the more traditional vercal pleats. Although the media used on the MANN seems very thin
My application is a 2.0 common rail diesel, I run a good synthetic 5W30 and change the oil every 10k ( which is half of the maximum service interval)
So, which filter would you be using and why?
Re: Which filter for next change: Purflux chevron vs MANN vs Manufacturer filter [Re: DrSmith] #5320746 01/12/20 02:12 PM
Ded Mazai Offline
Mann. It has softer end caps and the paper won't tear. In fact, I would use only Mann if I were in Europe. Or an OEM filter. Purflux is probably fine too. Just looks cheap.
BRZ | M1 HM 5W-20, FU | PZ Synchromesh.
Re: Which filter for next change: Purflux chevron vs MANN vs Manufacturer filter [Re: DrSmith] #5320750 01/12/20 02:16 PM
SubieRubyRoo Offline
Certainly "appears" the Purflux has more media than OEM, but obviously the only difference is the media. All 3 should work, but I would pick between the Sogefi and Purflux ones, and cut one of each open and stretch out the media to see which is bigger, and if manufacturer tells you if media is synthetic and/or micron ratings, pick the one that filters finer.
De omnibus dubitandum.
Re: Which filter for next change: Purflux chevron vs MANN vs Manufacturer filter [Re: SubieRubyRoo] #5320783 01/12/20 03:02 PM
53' Stude Offline
I like the Citroen one myself smile
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: Which filter for next change: Purflux chevron vs MANN vs Manufacturer filter [Re: DrSmith] #5320833 01/12/20 03:50 PM
DrSmith Offline OP
I think I agree with the sentiment here, the Purflux just looks like a cheaper version of the OEM.
I was unable to find any information relating to the micron ratings by any of the manufacturers unfortunately.
So it's between the MANN and the genuine OEM filter, shame as I bought a pack of 6 Purflux filters for £12 on eBay!
Out of interest, at the 10k miles interval I assume all filters will be absolutely fine. Perhaps the OEM filter is made using the thicker media as they claim up to 20k miles when serviced with genuine parts?
Re: Which filter for next change: Purflux chevron vs MANN vs Manufacturer filter [Re: DrSmith] #5320838 01/12/20 03:53 PM
blupupher Offline
Put all 3 boxes in a bag, mix it around, stick you hand in and use what you grab.
Any of them will be fine.
I do like the wavy look of the purefluc filters.
'18 Santa Fe: PP 10W30/OEM
'18 Soul: Synpower 5W30/ProGuard
'12 xB: M1 EP 0W20/CQ Blue
'10 Santa Fe: Synpower 5W30/D+
'04 F150: Magnatec 10W30/ST
'02 F150: Magnatec 5W20/D+
'94 VT1100: Peak 15W40/D+
Re: Which filter for next change: Purflux chevron vs MANN vs Manufacturer filter [Re: DrSmith] #5320879 01/12/20 04:52 PM
slacktide_bitog Offline
Interesting that Purflux doesn't just rebox the factory filter with the white pleats to use themselves crzy
Does the PSA OE filter with the white media have a wire backing, or a plastic mesh?
I have seen Purflux-branded filters with the white media
Re: Which filter for next change: Purflux chevron vs MANN vs Manufacturer filter [Re: blupupher] #5320882 01/12/20 04:55 PM
L
Linctex Offline
L
Exactly what I was going to say, but got beat to it.
Run any of the three - - there isn't any practical, real difference.
Re: Which filter for next change: Purflux chevron vs MANN vs Manufacturer filter [Re: slacktide_bitog] #5320914 01/12/20 05:29 PM
DrSmith Offline OP
Haha, that is the general impression I get. I was just curious if there was a view on the chevron pleated media. I've only encountered this style on my car's OEM filters (the fuel filter is the same too)
I've just double checked and there is no metal backing on the PSA OEM filter. As you say it appears to be identical except for the media.
I'm curious if for purflux's own filters they are using a cheaper media compared to what they are supplying the OEM with?
Re: Which filter for next change: Purflux chevron vs MANN vs Manufacturer filter [Re: DrSmith] #5321001 01/12/20 07:28 PM
SteveG4 Offline
Use the filter with the straight media.
Crooked is just crooked.
cool
Somewhere between Alaska and Wisconsin...
2006 Silverado LT Crew Cab 4WD & 2013 Equinox AWD
Re: Which filter for next change: Purflux chevron vs MANN vs Manufacturer filter [Re: DrSmith] #5321016 01/12/20 07:44 PM
F
Farnsworth Offline
F
White media is usually synthetic. Wonder how old the standard purflux are. The media is flexible?Actually the zig zag pleats are longer but further apart so where is the advantage over the Mann? I would use the factory one without question over the others. By eye it’s media looks thicker too. May be something pretty nice there.
Re: Which filter for next change: Purflux chevron vs MANN vs Manufacturer filter [Re: DrSmith] #5321032 01/12/20 08:05 PM
J
JC1 Offline
J
From the pics it appears that you bought all three of these filters. I would use the one with the oldest date code first. No sense not using any of them if they still fit the vehicle and you still own the vehicle.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Which filter for next change: Purflux chevron vs MANN vs Manufacturer filter [Re: DrSmith] #5321245 01/13/20 06:20 AM
DuckRyder Offline
I would use the OE filter because I strongly suspect it is synthetic media based on the thickness and soft edges on pleats. Cut it apart when you’re done with it and let us see if it has any sort of backing that can’t be distinguished while assembled.
Not that I think theres anything really wrong with any of them...
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: Which filter for next change: Purflux chevron vs MANN vs Manufacturer filter [Re: DrSmith] #5321608 01/13/20 02:40 PM
DrSmith Offline OP
Very interesting replies. I had not considered the synthetic vs cellulose possibility of the OEM filter.
Whilst I do own all three filters (and another 5 of the purflux ones that i bought as a pack of 6 on eBay) I am leaning towards the OEM one at the moment for my own car. I service a few cars in my family and at least two of them (a Mini and a Land Rover) also take this type of filter; so they won't go to waste.
Are there any easy ways to determine if the white OEM one is made of synthetic media?
Re: Which filter for next change: Purflux chevron vs MANN vs Manufacturer filter [Re: DrSmith] #5321755 01/13/20 05:12 PM
blupupher Offline
I have never seen a full synthetic media filter without a metal/plastic mesh backer. Synthetic media in not able to stay together otherwise.
Not saying if it has a mesh backer that it is synthetic, just if it does not have one it most likely is not synthetic (but could be a syn/cellulose blend)
