Havoline 5w20 $1.72/quart
by Villalobos - 01/19/20 05:42 AM
Amazon 5qt PUP 5w-20 $16.24
by Matt1980 - 01/19/20 03:42 AM
US Miltary News - F22
by ZeeOSix - 01/19/20 03:09 AM
OEM to Ravenol
by graphine - 01/19/20 02:38 AM
D905 Brake Pads: Bosch vs. Centric vs. Akebono
by The Critic - 01/19/20 01:55 AM
Dodge dart running issues after filling up fuel
by ram_man - 01/19/20 12:58 AM
Akebono ProAct brake pads now include hardware
by The Critic - 01/19/20 12:43 AM
16 Audi S3 G13 Coolant - 40,500 miles
by agpatel - 01/19/20 12:43 AM
BMW “G3” Axle Alternatives?
by E365 - 01/19/20 12:20 AM
Scan Tool recommendation
by zmelli - 01/18/20 11:57 PM
Keyless Entry Help Needed
by DeafBrad - 01/18/20 11:55 PM
75/140 owners manual vs 75/90 tag
by BigGee - 01/18/20 11:36 PM
toro super recycler with b&s engine HomeDepot
by passgas55 - 01/18/20 06:43 PM
75w140?
by mpack88 - 01/18/20 06:00 PM
Are all 9012 bulbs HIR2?
by dvancleve - 01/18/20 03:30 PM
Ariens L-3 Synthetic Severe-Duty Gear Lube
by Astro_Guy - 01/18/20 02:04 PM
LSx Crank lock
by P10crew - 01/18/20 02:03 PM
ST9688 gasket
by Farnsworth - 01/18/20 01:26 PM
From my stash
by Fattylocks - 01/18/20 12:48 PM
michWB, Brianhefty, JimBremer, Katdaddy, graphine
70470 Registered Users
54 registered members (Buckeye_Rich, Bighorn2500, 2013ecof150, 2015_PSD, alchargo, 6 invisible), 1,221 guests, and 26 spiders.
Topics300,305
Posts5,172,860
Members70,470
Most Online3,728
Jan 11th, 2020
2004 LeSabre/4T65 GM hard shift when hot #5320683 01/12/20 11:35 AM
R
redhat Offline OP
R
Dad has a 2004 LeSabre, your typical 4T 65E and a Series II 3.8. Beautiful car runs great and shifts great about 120 K on the clock. After you’ve been driving the car for a while, out of nowhere the car will start to shift very hard almost as if it is commanding full line pressure. When this happens in the shifts will actually make the tires chirp sometimes. If you throw the car in neutral turn the key off and restart the engine it’ll drive and shift fine for another half hour or hour.
I think I’ve vaguely remember seeing about this and the fix was some sort of Mr. shift kit or maybe a couple of new springs in parts of the valve body or there is a cover you removing in the trans and a couple of new springs go in. Years ago I remember reading something about the transmission computer detects a ever so slightly longer shift than what it calls for so it thinks there’s an issue and goes into a limp mode and commands full line pressure.
Maybe some of you experienced GM techs or other folks know exactly what this is? I don’t think the trans is failing though because until this happens the thing shifts beautifully and gives no indication whatsoever of any issues. Fluid and filter has already been changed and the trans has been maintained very well.
19 F150 2.7 - M1EP 5W-30, FL2062, 11k
17 Taurus Limited AWD - M1EP 5W-20, FL500S, 30k
84 JD 316 Repowered w/Vanguard 18
Re: 2004 LeSabre/4T65 GM hard shift when hot [Re: redhat] #5320688 01/12/20 11:43 AM
J
JLTD Offline
J
Not sure about the shift kit.
When was the last fluid change?
"Let’s not pretend like 0w20 is anything but a CAFE required crutch to eek another 1/2MPG" - BLND1
Hers: 2018 Ford Flex AWD EB, dealer fill
His: 2015 4Runner 60k, SS 5w20/Amsoil
Re: 2004 LeSabre/4T65 GM hard shift when hot [Re: JLTD] #5320692 01/12/20 11:51 AM
M
mattd Offline
M
Is it throwing a code for max adapt and long shift?
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1
Re: 2004 LeSabre/4T65 GM hard shift when hot [Re: redhat] #5320699 01/12/20 12:04 PM
MrMoody Offline
Yes, this is fairly common, I've done it on my Grand Pa beater and it's been running for years with no issues.
I believe it's caused by a combination of pump wear, actuator seal wear and accumulator piston wear causing slightly slow shifting and triggering full pressure, just as you say. I think it's mainly jamming accumulators that cause the adapt to max out and still be unable to consistently shift quickly enough.
Put in the parts of the TransGo kit you can put in from the pan, and get and replace the accumulator pistons as well: the center bores wear oblong and allow them to cock.
When reinstalling the accumulator body, make darned sure the metal tubes that go into it are inserted fully, in the correct position all the way along and secure so they can't work their way out. That would kill the transmission. Other than this possible pitfall it's an easy job.
2018 Hyundai Kona 1.6T DCT
2006 Pontiac (Holden) GTO AT
2001 Pontiac Grand Prix GT 3.8 NA (beater)
2005 Toyota Matrix FWD (ultra beater)
"Fob" and "Noack" are not acronyms.
Re: 2004 LeSabre/4T65 GM hard shift when hot [Re: redhat] #5320738 01/12/20 01:03 PM
ls1mike Offline
Here if you need the photos I will find them for you.
Shift kit install 4T65EHD or Non HD
Mike
00 Trans Am WS6 5.7 LS1
17 Silverado 3500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: 2004 LeSabre/4T65 GM hard shift when hot [Re: redhat] #5320742 01/12/20 01:09 PM
ls1mike Offline
I found the photos.
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: 2004 LeSabre/4T65 GM hard shift when hot [Re: redhat] #5320806 01/12/20 02:26 PM
I
Ihatetochangeoil Offline
I
I have 3 Lesabres. Nice cars. All of them have the Transgo shift kit which comes with very nice & clear instructions. While you're in there, spend an extra $10-12 and install sonnax part # 84532-01k differential lube tube retainer https://www.transmissionpartsdistri...Y5SSjYe844JzacFqQX3l-k8KDqBoCAIwQAvD_BwE
I don't remember where I found the info, but the 6mm bolts on the accumulator housing that you'll need to undo to replace the springs (illustrated above) torque to 100 in. lbs....If you want to make FUTURE fluid changes much easier, put on a new ZZP aluminum pan with a magnetic drain plug. Make sure you check the (new) drain plug for tightness prior to putting fluid in. Mine was shipped just about finger tight. https://zzperformance.com/collections/3800/products/4t65e-aluminum-transmission-pan
Feel free to PM me if you have any ??? (I've done this several times)
