Shell Rotella gas truck oil change intervals?
by gtrplr71 - 01/19/20 07:12 AM
Ford Focus belt idler puller bolt ?
by rkpatt - 01/19/20 06:51 AM
Havoline 5w20 $1.72/quart
by Villalobos - 01/19/20 05:42 AM
Amazon 5qt PUP 5w-20 $16.24
by Matt1980 - 01/19/20 03:42 AM
US Miltary News - F22
by ZeeOSix - 01/19/20 03:09 AM
OEM to Ravenol
by graphine - 01/19/20 02:38 AM
D905 Brake Pads: Bosch vs. Centric vs. Akebono
by The Critic - 01/19/20 01:55 AM
Dodge dart running issues after filling up fuel
by ram_man - 01/19/20 12:58 AM
Akebono ProAct brake pads now include hardware
by The Critic - 01/19/20 12:43 AM
16 Audi S3 G13 Coolant - 40,500 miles
by agpatel - 01/19/20 12:43 AM
BMW “G3” Axle Alternatives?
by E365 - 01/19/20 12:20 AM
Scan Tool recommendation
by zmelli - 01/18/20 11:57 PM
Keyless Entry Help Needed
by DeafBrad - 01/18/20 11:55 PM
75/140 owners manual vs 75/90 tag
by BigGee - 01/18/20 11:36 PM
toro super recycler with b&s engine HomeDepot
by passgas55 - 01/18/20 06:43 PM
75w140?
by mpack88 - 01/18/20 06:00 PM
Are all 9012 bulbs HIR2?
by dvancleve - 01/18/20 03:30 PM
Ariens L-3 Synthetic Severe-Duty Gear Lube
by Astro_Guy - 01/18/20 02:04 PM
LSx Crank lock
by P10crew - 01/18/20 02:03 PM
ST9688 gasket
by Farnsworth - 01/18/20 01:26 PM
madjid, michWB, Brianhefty, JimBremer, Katdaddy
70471 Registered Users
71 registered members (53' Stude, atikovi, 12CruzeEcoAt, AndyB, aircooled, 4 invisible), 1,448 guests, and 22 spiders.
Topics300,307
Posts5,172,877
Members70,471
Most Online3,728
Jan 11th, 2020
Need help maintaining Jeep only driven 2x/year #5320497 01/12/20 07:48 AM
K
kehyler Offline OP
K
Hi All,
I have a new maintenance project that I'm unsure how to tackle. I have a heavily modified 2003 Jeep Wrangler wrangler whose future is to be trailered to off-road parks probably 2x/year. I suspect the maximum speed this jeep will now ever see is 30 mph, and that it will have less than 30 miles total/year driven. It's unlikely that the Jeep will ever see streets again.
I'm familiar with how to maintain vehicles when they are driven regularly, but I'd like some suggestions for this new maintenance project. Could someone suggest to me the things I should do?
Thanks!
-kehyler
Re: Need help maintaining Jeep only driven 2x/year [Re: kehyler] #5320526 01/12/20 08:25 AM
Z
zrxkawboy Offline
Z
I'm sure it's going to be worked hard during those few miles. I'd probably use a good conventional oil with a Wix/NAPA Gold filter and change it annually. Again, that's just me...I'm sure you could change it every other year and be just fine.
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: Need help maintaining Jeep only driven 2x/year [Re: kehyler] #5320548 01/12/20 08:43 AM
E
eljefino Offline
E
Keep rodents and mice out of the interior, and away from the wiring harnesses, cowl air intake, and engine air filter. I ruined my mercedes the 2nd winter I owned it by parking it where mice could get in, and pee.
If you're somewhere humid, the brakes may rust up badly. My plow truck sits in the woods and the brake disks are fine, all summer long, somehow.
My fuel hasn't gone bad, and, on these low tech cars, the battery's been fine, too. I'd put a shutoff switch on your battery though.
You could change your oil every five years with your usage. Maybe do it when your air filter needs it, in case you get a lot of dust wherever you're wheeling.
Re: Need help maintaining Jeep only driven 2x/year [Re: kehyler] #5320566 01/12/20 08:59 AM
G
gfh77665 Offline
G
Adding 2X Stabil to the gas is Priority #1.
Oil is good for 5 years with that kind of useage. Disconnect battery between runs. Keep it protected from invading critters.
Did I mention adding 2X Stabil to the gas is Priority #1? Far and away.
Re: Need help maintaining Jeep only driven 2x/year [Re: kehyler] #5320665 01/12/20 11:03 AM
J
jeepman3071 Offline
J
-stabilize the fuel
-keep it on a battery maintainer
-keep rodents out
-I'd do a yearly oil change interval with conventional 10w30 and a good filter. The driveline fluids all depend on where the Jeep goes offroad. If it is doing mostly rock climbing in dry environments, then the fluids can stay in there longer. If there is a lot of mud and water fording, I would change them every year since water will get into the transmission, transfer case, and differentials.
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (56k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Need help maintaining Jeep only driven 2x/year [Re: jeepman3071] #5321015 01/12/20 06:42 PM
K
kehyler Offline OP
K
The Jeep will likely be kept outside - does that mean keeping rodents out is next to impossible?
Re: Need help maintaining Jeep only driven 2x/year [Re: kehyler] #5321308 01/13/20 07:25 AM
J
jeepman3071 Offline
J
I'd fill the HVAC system and interior with dryer sheets (the strong smelling name brand ones), and change them out periodically. I've had great luck with this in equipment, and also have a few friends who have had good luck with it in their antique cars that don't get driven often.
