75w140?
by mpack88 - 01/18/20 06:00 PM
Are all 9012 bulbs HIR2?
by dvancleve - 01/18/20 03:30 PM
Ariens L-3 Synthetic Severe-Duty Gear Lube
by Astro_Guy - 01/18/20 02:04 PM
LSx Crank lock
by P10crew - 01/18/20 02:03 PM
ST9688 gasket
by Farnsworth - 01/18/20 01:26 PM
From my stash
by Fattylocks - 01/18/20 12:48 PM
Toyota to Mexico
by kstanf150 - 01/18/20 12:37 PM
Final Sludge Cleanup, HDEO - Diesel ??
by jssaab - 01/18/20 12:31 PM
A good cabin filter
by NH73 - 01/18/20 10:36 AM
K&N cut open.
by laserred96gt - 01/18/20 10:25 AM
Toyota Oem filter mileage
by Bettez88 - 01/18/20 10:22 AM
OCI, Owners manual versus oil Mfg.
by VQLT - 01/18/20 10:06 AM
MacBook Pro to Microsoft Surface
by Kira - 01/18/20 09:53 AM
Ford 5R55E Auxiliary Transmission Filter
by benjamming - 01/18/20 09:33 AM
Do all synthetic oils act as a cleaner?
by Loobit - 01/18/20 08:26 AM
Mobil 1 ESP now sold in 5qt jugs
by Patman - 01/18/20 08:12 AM
Mobil 1 Extended Performance Oil Filters
by jrommelt - 01/18/20 08:08 AM
These the same?
by Bettez88 - 01/18/20 06:53 AM
Bebo77, 2EHA, jonnyb433, kzbd, 54Robert
70465 Registered Users
106 registered members (aircooled, Alfred_B, bdcardinal, 53' Stude, Bailes1992, AZjeff, 10 invisible), 2,095 guests, and 19 spiders.
Topics300,290
Posts5,172,590
Members70,465
Most Online3,728
Jan 11th, 2020
Page 1 of 3 1 2 3
Reusing Fram Ultra Synth. Oil Filter? #5320355 01/11/20 10:38 PM
F
FirmTofu Offline OP
F
Hey guys,
Bought and installed a FRAM Ultra Synthetic Oil Filter (XG3614) my last oil change which was 5k miles ago. I'm in college so I won't be driving much, probably up to 5k mi a year. I'm doing my oil change next month and I was wondering if it would be okay to reuse the filter as it claims protection to 20k mi. Assuming I empty the oil from the filter each time, would I be fine using the filter up to 15k mi?
2016 Volkswagen Jetta S 1.4L
Castrol Edge 5w40 & Fram Ultra Synthetic
Re: Reusing Fram Ultra Synth. Oil Filter? [Re: FirmTofu] #5320359 01/11/20 10:42 PM
J
JeffKeryk Offline
J
Don't empty the oil filter, just refresh the crankcase. You will be fine.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Reusing Fram Ultra Synth. Oil Filter? [Re: FirmTofu] #5320360 01/11/20 10:43 PM
N
NYSteve Offline
N
Fram Ultra is fine for 2 or 3 OCIs. However, you will potentially cause lots of leaking/sealing issues if you remove the filter to empty it. Leave it on. Go 2x oil changes and you'll be fine.
Re: Reusing Fram Ultra Synth. Oil Filter? [Re: FirmTofu] #5320362 01/11/20 10:45 PM
F
FirmTofu Offline OP
F
Oh, sweet - thanks a lot!!
Re: Reusing Fram Ultra Synth. Oil Filter? [Re: FirmTofu] #5320363 01/11/20 10:52 PM
G
gregk24 Offline
G
Running for 2 oil change intervals is cake for the Fram Ultra. As others have said, leave the filter on for both intervals. To not remove and attempt to reinstall.
2012 Honda Accord EX-L K24z3
60,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
54,xxx miles
Castrol Edge 0w40 / OEM filter
Re: Reusing Fram Ultra Synth. Oil Filter? [Re: NYSteve] #5320365 01/11/20 10:52 PM
CR94 Online Content
Online Content
Originally Posted by NYSteve
... you will potentially cause lots of leaking/sealing issues if you remove the filter to empty it. ...
Which never happened even once in the many times I removed and reused spin-on filters.
Draining a spin-on filter with a functional anti-drain-back valve is tricky.
Whether one drains the filter or not, no harm will come of using the Ultra 15k miles or more, IF the engine isn't clogging it with abnormal amounts of crud.
2011 Toyota Prius now at 107K
Re: Reusing Fram Ultra Synth. Oil Filter? [Re: FirmTofu] #5320368 01/11/20 11:05 PM
B
brages Offline
B
There is a sub forum for filters; this topic is frequently discussed there.
Re: Reusing Fram Ultra Synth. Oil Filter? [Re: JeffKeryk] #5320372 01/11/20 11:23 PM
O
oldhp Offline
O
↑↑↑↑↑↑↑↑ This, right here. ↑↑↑↑↑↑↑↑..................and you'll be fine.
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: Reusing Fram Ultra Synth. Oil Filter? [Re: FirmTofu] #5320378 01/11/20 11:41 PM
B
bruckus Offline
B
Originally Posted by FirmTofu
Hey guys,
Great to see a college kid taking good care of their equipment. An easy way to save yourself a couple bucks and it just makes you feel good.
Check back anytime you have questions or a problem. Many knowledgeable members here for advise on cars and life.
Re: Reusing Fram Ultra Synth. Oil Filter? [Re: FirmTofu] #5320380 01/11/20 11:48 PM
T
Talent_Keyhole Offline
T
Hey guys,
10-20% of the used oil remains in your engine and you now want to put new oil through a used filter. I would contact Fram directly and take their advice. Let us know what they say.
Re: Reusing Fram Ultra Synth. Oil Filter? [Re: Talent_Keyhole] #5320381 01/11/20 11:57 PM
G
geeman789 Offline
G
THIS ^^^
The filter is rated for 20 k miles, using " old ... " oil. It will be even happier working with new oil ...
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
Re: Reusing Fram Ultra Synth. Oil Filter? [Re: FirmTofu] #5320397 01/12/20 01:10 AM
F
FordBroncoVWJeta Online Content
Online Content
F
I must be the only one in this thread that drains the filter. The CRV in the sig thats my first time reusing the filter this OCI. If you oiled the gasket both times, and no signs of wear on the gasket it should be A-OK.
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2003 Ford Taurus 3.0 Vulcan
Re: Reusing Fram Ultra Synth. Oil Filter? [Re: FirmTofu] #5320402 01/12/20 01:35 AM
M
Mainia Online Happy
Online Happy
M
Over cautious people, over worrying that some how a VERY heavy duty oil filter seal will some how leak if it is taken off and used again. I have 3 cars in my family and 3 friends in a car club where we all use Fram Ultras. Of the 3, one has 2 cars in his family. Second guy has 4 cars and the other guy has 2 cars. We all use Fram Ultras for 2 oil oil changes with the exception of one car in the group that gets a new filter every change.
We all pull our filters and drain them and we all use different items to open the silicone anti- drain back valve. I use a 1 sided wooden Q-Tip back end. Another guy uses empty ball point pen clear ink tubes. The other guy uses the back end of small drill bits. You lightly push open the valve just so it cracks the seal at the 12 o-clock hole and one at the 6 o-clock hole. And it drains right out. Fill the old filter up with oil like you do with a new one and hand tightening like a new one. We have been doing it like this for 10 years now with absolutely no issues. The have people in their friend sphere that do it too that I don’t know. No issues there either. More FUD from worry worts in all of opinions.
The only time I would worry about the oil filter gasket is if was sitting exposed to the full days sun light for more then 2 years, then I will worry. Of course it is your car and you can do what you want, but you guys who think an oil filter gasket is that fragile, are nuts.
2018 Lowered Hyundai Kona AWD 1.6T
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: Reusing Fram Ultra Synth. Oil Filter? [Re: FirmTofu] #5320403 01/12/20 01:39 AM
F
Falcon_LS Offline
F
I keep Fram Ultra filters on for 15,000 - 18,000 miles, just refreshing the crankcase at certain intervals. No problems.
Petro-Canada Duron HP 15W-40 CK-4/SN
99 Explorer: H17W02
00 Pajero: XG9688
01 Grand Marquis: XG2
05 Envoy: XG9837
Motorcraft 5W-50:
18 Mustang GT: XG10575
Re: Reusing Fram Ultra Synth. Oil Filter? [Re: FirmTofu] #5320413 01/12/20 02:40 AM
T
Triple_Se7en Online Content
Online Content
T
Taking off the filter and draining it - then reinstalling it, is fine. I've done it for almost 20 years now, with no leaks.
19' Hyundai Santa Fe 2.4 GDI - Valv Adv. 5w30 / OEM Oil Filter / 6oz Liqui-Moly
20' Kia Soul X-Line 2.0 Multi-port / Pennzoil Gold 5W30 / OEM filter
04' Colorado 3.5 Castrol Edge 0W40 / K&N filter
Page 1 of 3 1 2 3
