2002 cummins
by coondog - 01/25/20 07:07 AM
New Mercedes Ute
by Shannow - 01/25/20 03:04 AM
A decent battery charger for sub $50?
by michaelluscher - 01/25/20 02:03 AM
Temperature swing affects on oil
by leeaspell - 01/25/20 12:58 AM
Coefficient of Friction
by jrommelt - 01/24/20 11:46 PM
2017 Chevy Cruze Diesel Oil
by Ponch - 01/24/20 11:03 PM
electric motor amp rating
by motor_oil_madman - 01/24/20 10:42 PM
Radio, Instrument panel, display, AC cutting off
by DrDanger - 01/24/20 09:39 PM
Filter Brand Quality Change?
by BBDartCA - 01/24/20 09:21 PM
Autozone $7 off $30
by GMguy84 - 01/24/20 09:17 PM
Honda Power Steering Fluid
by shortlid - 01/24/20 09:14 PM
Autozone Clearance 2020 M1EP
by GMguy84 - 01/24/20 09:11 PM
Spark Plugs
by A_Spruce - 01/24/20 09:00 PM
Flank drive wrenches
by spasm3 - 01/24/20 08:39 PM
Auto assembly and mfg. logistics
by P10crew - 01/24/20 08:26 PM
Kodiak
by P10crew - 01/24/20 08:05 PM
yet another black eye for the 2,4 ecotec
by super20dan - 01/24/20 07:52 PM
New incentive for 0w20
by Snagglefoot - 01/24/20 06:43 PM
coondog, steelbeams, Pete44, Connie7, 2020XT
70520 Registered Users
77 registered members (BAJA_05, bbhero, atikovi, bachman, Bighorn2500, 11 invisible), 1,879 guests, and 19 spiders.
Topics300,520
Posts5,177,667
Members70,520
1st Gen Toyota Sequoia #5320239 01/11/20 08:37 PM
M
maverickfhs Offline OP
M
Looking at a 2003 Toyota Sequoia(200k miles) and based on all the reading and reviews seems to be a well built one.
It does have good service history, besides timing belt and I don't think that has been changed!!!!
Except things like suspension, timing belt replacement expenses etc. is there anything major which can be a pain and expensive to replace?
Besides being gas guzzler, is there anything should be paying specific attention during the test drive?
I believe battery light on the ODO is on, could be an alternator/charging issues or a ground, is there anything major which could be the reason?
Appreciate any help and inputs.
2006 Civic EX 209K/AT
2006 Acura TSX 199K/AT
2007 Accord VP 154K/AT
Re: 1st Gen Toyota Sequoia [Re: maverickfhs] #5320258 01/11/20 08:56 PM
M
madRiver Offline
M
Starter is difficult to repair(below manifold).
Cool packs occasionally die and 8 or replace.
Very good vehicles as I know families who bought this new similar vintage and still drive them.
Re: 1st Gen Toyota Sequoia [Re: maverickfhs] #5320261 01/11/20 08:57 PM
B
bubbatime Offline
B
WHY?
2019 Honda CRV 1.5T dealer bulk
2017 Chrysler Pacifica SuperTech synthetic 5W20
2013 Yamaha XT250 Valvoline motorcycle 10W40
2006 GMC Sierra SuperTech high mileage 5W30
Re: 1st Gen Toyota Sequoia [Re: bubbatime] #5320300 01/11/20 09:39 PM
M
mjk Offline
M
WHY?
And this is something that needs to be explained ?
Re: 1st Gen Toyota Sequoia [Re: maverickfhs] #5320312 01/11/20 09:49 PM
02SE Offline
That's from the era of improperly made frames by Dana Corp. So check the frame carefully for rust.
Re: 1st Gen Toyota Sequoia [Re: maverickfhs] #5320358 01/11/20 10:41 PM
J
JeffKeryk Offline
J
If it is anything like our 2001 Tundra, you gonna love it.
When I got the Tundra, I serviced all the fluids except antifreeze, did front brakes, installed Bilstein shocks.
You can use a larger oil filter in place of that tiny toy size filter. Then it is a 7 quart fill.
I would also service the PS fluid.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: 1st Gen Toyota Sequoia [Re: maverickfhs] #5320424 01/12/20 04:02 AM
1
14Accent Offline
1
You'll be happy with it, just have the timing belt changed ASAP. It'll need shocks at 200k, but other than that you should be good to go. The cats are probably burned up by now, so expect a P0420/430 code soon, not a huge deal if you don't have emissions testing in your area.
There's really nothing to go wrong on that vehicle. Full frame, solid axle, V8 engine. Can't go wrong with that!
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: 1st Gen Toyota Sequoia [Re: bubbatime] #5320442 01/12/20 06:08 AM
dlundblad Online Happy
Online Happy
WHY?
I take this comment to mean that you know nothing on the topic and have nothing beneficial to add.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: 1st Gen Toyota Sequoia [Re: maverickfhs] #5320443 01/12/20 06:12 AM
Online Happy
A friend of mine had one with similar mileage that he was willing to let go for $3500. It did need new cats and the rear driver side wheel well was rusted pretty bad. Only visible when the door was open, but it was an unacceptable area to rust too IMO.
I want to say when the timing belt goes, the engine just dies. Not an interference engine IIRC.
I’ve noticed that between these and first gen Tundras, dealers can’t keep them on the lot.
Re: 1st Gen Toyota Sequoia [Re: maverickfhs] #5320460 01/12/20 06:42 AM
spk2000 Offline
Will it be a travel vehicle over the road or just a local car? These vehicles sometimes eat tires so replace shocks if original most likely as someone else suggested and make sure in alignment. If a local car and vehicle becoming stranded not an issue I would consider leaving the timing belt alone. But an over the road vehicle might change that. Can't recall if there is a plug to inspect the timing belt on this but you might be able to inspect it too. One of my old vehicles had this and I can't recall which one.
96 Grand Marquis 203,000 mi
01 Sable LS Wagon 163,000 mi
02 Montero 191,000 mi
03 Sable LS Sedan 73,000 mi
Re: 1st Gen Toyota Sequoia [Re: maverickfhs] #5320506 01/12/20 08:04 AM
AZjeff Offline
Known good SUV but can't understand advice not to service a 200k timing belt. It might fail in your driveway or it might fail in the passing lane in heavy traffic and cause a dangerous situation. It's way past interval, it needs changed so why risk it.
And FWIW you might want to do some thorough research on whether that 4.7 engine is interference or not.
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, 0W-20 QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: 1st Gen Toyota Sequoia [Re: maverickfhs] #5320522 01/12/20 08:22 AM
M
M
It's an interference engine and of course if I got it, timing belt and fluids would be the starting point.
Re: 1st Gen Toyota Sequoia [Re: 02SE] #5320523 01/12/20 08:22 AM
W
wag123 Offline
W
This is a BIG +1.
Before you buy it make sure to put a scanner on it to check for stored codes and readiness status. Also, check that it is equipped with the upgraded (larger) front disc brakes. Figure on replacing the timing belt and associated parts ASAP.
Re: 1st Gen Toyota Sequoia [Re: maverickfhs] #5320536 01/12/20 08:31 AM
M
M
In 2013, dealer record indicates this: C0D FRAME&ST INSP, CLEAN FRM & CRC APPL - SEQUOIA
Does it mean frame was checked and some rust prevention was applied?
Re: 1st Gen Toyota Sequoia [Re: maverickfhs] #5320543 01/12/20 08:35 AM
W
wag123 Offline
W
It looks that way. This would have been done in response to the recall.
