Pecan Pie Cheesecake Recipe
by GumbyJarvis - 04/06/20 05:03 AM
Dewalt DXCM251 25-Gal Oiled Air Compressor
by The Critic - 04/06/20 03:40 AM
Windows File & Folder Fix Tool
by ZeeOSix - 04/06/20 01:53 AM
$.25 washer fluid at WM
by joel95ex - 04/06/20 12:13 AM
`16 Suburban OLM never tripped due to time
by zfasts03 - 04/05/20 11:26 PM
Straight 30W [Briggs & Stratton] @ Amazon
by SlavaB - 04/05/20 10:56 PM
Bosch 3323 Premium Filter Cut Open
by TrainingPolicy - 04/05/20 10:29 PM
CARQUEST Premium Oil filter 84341 Cut Open
by TrainingPolicy - 04/05/20 10:12 PM
C-1706 SAKURA Cut Open
by QuangTeo - 04/05/20 10:07 PM
Had to smile
by AZjeff - 04/05/20 10:04 PM
Childhood friend dies
by Marco620 - 04/05/20 10:00 PM
Leftover 100LL in vehicle
by PantherFan88 - 04/05/20 09:42 PM
The good old days.:)
by A310 - 04/05/20 09:04 PM
Harvest king switched suppliers confirmed.
by Micahmcmeen - 04/05/20 08:15 PM
Mobile 1 Synthetic 15w/50 - Not what it used to be?
by NorCalHD - 04/05/20 06:21 PM
Bad Rear Brakes- Not obvious
by ford46guy - 04/05/20 05:03 PM
Move car w/ NO coolant?
by SavagePatch - 04/05/20 04:39 PM
VIRGIN BOSCH 3400 CUT OPEN
by 53' Stude - 04/05/20 04:18 PM
First vehicle you ever purchased?
by 53' Stude - 04/05/20 03:56 PM
F7daved, khouan, daniell, carguy1701, London
71106 Registered Users
68 registered members (2015_PSD, 4WD, atikovi, Astro_Guy, 77GrandPrix, Astro14, 9 invisible), 1,557 guests, and 14 spiders.
Topics303,661
Posts5,239,357
Members71,106
RJ45 Connectors #5314855 01/06/20 02:08 PM
F
fraso Offline OP
F
I want to run some new Ethernet lines and will have to terminate each end with RJ45 connectors. I'm running low on connectors and they seem to a bit pricey from places like Home Depot. The ones on Amazon seem to be quite a bit cheaper but some of the reviewers complain about poor quality.
Any advice about which RJ45 brands are good and where to get them?
Re: RJ45 Connectors [Re: fraso] #5314868 01/06/20 02:22 PM
Donald Offline
Well thats a question with many possible answers. Amazon is where I get mine.
Some things to consider:
1) shielded or not shielded cable?
2) what kind of cable? CAT6?
3) OD of cable
4) gauge of wire
5) what kind of a connector is your crimper expecting. Some crimpers push in a strain relief so if that is the type of crimper you have you need connectors with a strain relief that can be pushed in.
I am doing mostly outdoor crimps of shielded wire 18' up on a telephone. I am using passthrough connectors. Expensive crimper and connectors.
2015 Ford F-250 w/Powerstroke
Re: RJ45 Connectors [Re: fraso] #5314872 01/06/20 02:25 PM
N
nthach Offline
N
I never had an issue with Ideal brand RJ45s. CAT6 cable is kinda finicky to terminate into modular plugs. Are you just using straight terminated ethernet or you have your main runs terminated into patch panels and using patch cords to connect between a jack and computer/box/terminal?
Re: RJ45 Connectors [Re: fraso] #5314873 01/06/20 02:25 PM
R
redhat Offline
R
I have bought the cheap ends on Amazon and they have been alright, biggest thing is making sure the brass terminals go into the wires properly.
Instead of ends, might you want to instead put wall plates or keystone jack RJ45 to allow you to plug in cables?
19 F150 2.7 - MCSB 5W-30, FL2062, 16k
17 Taurus Limited AWD - M1EP 5W-20, FL500S, 32k
84 JD 316 Repowered w/Vanguard 18
Re: RJ45 Connectors [Re: fraso] #5314897 01/06/20 02:50 PM
T
tcp71 Offline
T
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: PP 5w30 syn. (varies)
Re: RJ45 Connectors [Re: fraso] #5314956 01/06/20 04:14 PM
MrMoody Offline
For jacks that aren't junk, the name is Panduit. Yes, they cost more.
2018 Hyundai Kona 1.6T DCT
2006 Pontiac (Holden) GTO AT
2001 Pontiac Grand Prix GT 3.8 NA (beater)
2005 Toyota Matrix FWD (ultra beater)
"Fob" and "Noack" are not acronyms.
Re: RJ45 Connectors [Re: fraso] #5314962 01/06/20 04:16 PM
O
OVERKILL Offline
O
Male or female? The Cables2Go female one are quite decent and reasonably priced.
Re: RJ45 Connectors [Re: fraso] #5315027 01/06/20 05:39 PM
F
fraso Offline OP
F
I'm planning the additional wiring in my garage so I was planning to connect devices directly with male plugs. A wall plate with female jacks would be neater but unnecessary. I have wall plate in the house and connect to them with patch cables.
My ISP left me with lots of surplus cable and I'm not positive that it's CAT6. I have lots of CAT5 cable from when I built the house back in 2000. I thought the CAT6 connectors might be better but didn't realize they might be trickier to do right.
Re: RJ45 Connectors [Re: fraso] #5315062 01/06/20 06:19 PM
Donald Offline
When the 8 wires are inserted you do not want to have "wire float". Being the wire should only be a little smaller than the size of the hole it's sliding in. So get the proper connector for the cable you are using. Indoor and outdoor cable have different thickness of outer insulation and may require different connectors.
Also to meet the full speed that CAT6 allows you need to have only a tiny amount of untwisted cable in the connector and to me that's very difficult without a passthru connector.
Re: RJ45 Connectors [Re: Donald] #5315160 01/06/20 07:46 PM
O
OVERKILL Offline
O
Agreed thumbsup
My CAT6 ends/crimper are of the passthrough variety as well.
Re: RJ45 Connectors [Re: fraso] #5315182 01/06/20 08:06 PM
M
mk378 Offline
M
For desktop devices you really should use wall plates and patch cables, even in a garage. Something like a ceiling AP could be connected directly with a plug on the end of the house wire.
Look at the cable you have to see what type it is. It is always labeled with printing on the cable jacket. It's unlikely you have cat6 but if you do you need the cat6 plugs because cat5 type simply won't physically fit on-- the conductors are larger.
Re: RJ45 Connectors [Re: fraso] #5315263 01/06/20 09:21 PM
N
NO2 Offline
N
You should not try to terminate the cables. You should install RJ45 jacks instead, which are a lot more reliable. I like the keystone type which are most versatile; you install them in a case or patch panel. Use patch cables to go from the jacks to your device. Reliable cabling is a real PITA, and installing a jack and/or patch panel makes for a cleaner and more reliable installation.
Re: RJ45 Connectors [Re: fraso] #5315265 01/06/20 09:27 PM
Donald Offline
Or buy preterminated fiber. Not that expensive if you are going switch to switch.
Re: RJ45 Connectors [Re: fraso] #5320204 01/11/20 08:53 PM
F
fraso Offline OP
F
I checked the cable I was planning to use and it appears to be CAT5e outdoor and I have a spool of Lucent CAT5 indoor. I also found that I have some RJ45 jacks and might consider using them. Then again, I might also just practice crimping some connectors.
My ISP uses the T568 wire assignment and I think my Leviton RJ45 jacks also use T568B. Is there any difference in performance between T568A and T568B as along as each end is terminated the same? That is, why would you use one over the other?
Re: RJ45 Connectors [Re: fraso] #5320853 01/12/20 04:23 PM
O
OVERKILL Offline
O
No, there is zero difference in performance. Most of us use the "B" version in my experience.
