unthinkable problem after oil change
by NH73 - 01/25/20 07:37 AM
Anybody burn wood for heat? Advice please.
by dlundblad - 01/25/20 07:21 AM
2002 cummins
by coondog - 01/25/20 07:07 AM
New Mercedes Ute
by Shannow - 01/25/20 03:04 AM
A decent battery charger for sub $50?
by michaelluscher - 01/25/20 02:03 AM
Temperature swing affects on oil
by leeaspell - 01/25/20 12:58 AM
Coefficient of Friction
by jrommelt - 01/24/20 11:46 PM
2017 Chevy Cruze Diesel Oil
by Ponch - 01/24/20 11:03 PM
electric motor amp rating
by motor_oil_madman - 01/24/20 10:42 PM
Radio, Instrument panel, display, AC cutting off
by DrDanger - 01/24/20 09:39 PM
Filter Brand Quality Change?
by BBDartCA - 01/24/20 09:21 PM
Autozone $7 off $30
by GMguy84 - 01/24/20 09:17 PM
Honda Power Steering Fluid
by shortlid - 01/24/20 09:14 PM
Autozone Clearance 2020 M1EP
by GMguy84 - 01/24/20 09:11 PM
Spark Plugs
by A_Spruce - 01/24/20 09:00 PM
Flank drive wrenches
by spasm3 - 01/24/20 08:39 PM
Auto assembly and mfg. logistics
by P10crew - 01/24/20 08:26 PM
Kodiak
by P10crew - 01/24/20 08:05 PM
Whoop, coondog, steelbeams, Pete44, Connie7
70521 Registered Users
98 registered members (Astro14, 1foxracing, Aero540T, 53' Stude, 2009Edge, 2002 Maxima SE, 7 invisible), 2,206 guests, and 18 spiders.
Topics300,521
Posts5,177,678
Members70,521
$10 Harbor Freight Torque Wrench #5320192 01/11/20 07:46 PM
J
jayjr1105 Offline OP
J
Is this accurate enough for the occasional weekend use? Just did my spark plugs and my large Craftsman only goes as low as 20 ft/lbs and I needed 9-10. I'd use this maybe 3-4 times a year.
I see some cheap ones on Amazon for $25-40 so I wonder how decent the $10 one is from Harbor Freight.
2013 Mazda 3 - PP 0w20
2005 Honda Odyssey - PP HM 5w20
Re: $10 Harbor Freight Torque Wrench [Re: jayjr1105] #5320203 01/11/20 07:53 PM
Char Baby Offline
I think it'll be good enough for things like spark plugs & wheel lug nuts.
I too just bought this torque wrench for $10. I only want to keep/use it in my cars trunk, should I have a tire repair on the road. I still want to be able to put accurate/even torque on each lug nut out on the road. Even if this torque wrench isn't accurate as a better wrench, It'll be accurate enough for this while out on the road.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: $10 Harbor Freight Torque Wrench [Re: jayjr1105] #5320231 01/11/20 08:25 PM
E
eljefino Online Content
Online Content
E
You can get an 8 point socket (or an allen slug, etc) and compare against your Craftsman where the values overlap!
Re: $10 Harbor Freight Torque Wrench [Re: jayjr1105] #5320252 01/11/20 08:47 PM
samven Offline
I have all 3 of their torque wrenches. Mine are about 6 years old now so I dont know if they are better or worse but every once in a while I will take them over to a buddy who has a nice old Craftsman that he still sends in for calibration and they are always within 5% of his. I have noticed that its a good idea to lower the range and torque once to click after it has sat awhile. A couple times I got higher readings on the first use. The one really great part is that they are very repeatable.
Re: $10 Harbor Freight Torque Wrench [Re: jayjr1105] #5320253 01/11/20 08:47 PM
rollinpete Offline
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spd 190k
03 Saturn Ion 2.2 L4 5spd 241k
Shell Rotella Gas Truck 5w30
PPHM 5w30
Currently under the influence of oil shocked2
Re: $10 Harbor Freight Torque Wrench [Re: jayjr1105] #5320263 01/11/20 09:02 PM
Chris142 Offline
I have heard good things about them. When I looked at them every one in the store was used and broken.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: $10 Harbor Freight Torque Wrench [Re: eljefino] #5320299 01/11/20 09:38 PM
CR94 Offline
The simplest accurate way to check a torque wrench is to put it on something that won't turn, and hang an accurately known weight from the handle, and multiply the weight by the relevant distance. My old cheap Kmart beam wrench checks ok that way.
2011 Toyota Prius now at 108K
Re: $10 Harbor Freight Torque Wrench [Re: jayjr1105] #5320304 01/11/20 09:40 PM
R
RyanY Offline
R
I have all 3 sizes and they are consistent, very close to my old Craftsman, and overall a great value. My only complaint is that the click is not very loud for the 1/4" model (gotta rely more on feel than sound).
2007 Cadillac CTS 3.6L >128k miles (Castrol Magnatec 5W-30 + ACDelco PF2129G)
2012 Honda Odyssey EX-L >105k miles (STP (Amalie) 0W20 + ACDelco PF2057)
Re: $10 Harbor Freight Torque Wrench [Re: jayjr1105] #5320430 01/12/20 04:29 AM
1
14Accent Offline
1
I've got the Harbor Freight 1/4 and 3/8 torque wrenches, had them for years. They still work perfectly to this day, I've never had an issue. They might be off a percent or two, but that's fine.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: $10 Harbor Freight Torque Wrench [Re: jayjr1105] #5320454 01/12/20 06:30 AM
spk2000 Offline
They are fine for occasional home use but would not hold up to daily mechanic use.
96 Grand Marquis 203,000 mi
01 Sable LS Wagon 163,000 mi
02 Montero 191,000 mi
03 Sable LS Sedan 73,000 mi
Re: $10 Harbor Freight Torque Wrench [Re: jayjr1105] #5320524 01/12/20 08:22 AM
P
provels Offline
P
My 3 torque wrenches are all beam and 40 years old, but I bought the HF 1/2" for lug nuts. Better than standing on my head trying to read the beam. $10 well spent. But remember to relax the spring between uses if you want to maintain any accuracy.
Re: $10 Harbor Freight Torque Wrench [Re: jayjr1105] #5321665 01/13/20 02:37 PM
J
J
So either this thing is total garbage or I'm deaf. I hear no click from this thing at all. Did I get a bad one??
Re: $10 Harbor Freight Torque Wrench [Re: jayjr1105] #5321732 01/13/20 03:41 PM
demarpaint Offline
Bring it back and get another one, you might have a dud.
God Bless Our Troops
Re: $10 Harbor Freight Torque Wrench [Re: jayjr1105] #5321788 01/13/20 04:50 PM
T
totegoat Offline
T
My 3 seem to work well but gotta admit I don't torque spark plugs.
Re: $10 Harbor Freight Torque Wrench [Re: jayjr1105] #5321829 01/13/20 05:40 PM
T
Traction Offline
T
After dealing with countless fasteners over the last 48 years, I would trust my feel for feeling bolt clamping force, more than any $10 torque wrench. I do use a torque wrench on many other things, but it cost much more than $10 and I recently had it calibrated, and it was spot on after 17 years.
Certified Tire Service Instructor since 2009
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
