Are all 9012 bulbs HIR2?
by dvancleve - 01/18/20 03:30 PM
Ariens L-3 Synthetic Severe-Duty Gear Lube
by Astro_Guy - 01/18/20 02:04 PM
LSx Crank lock
by P10crew - 01/18/20 02:03 PM
ST9688 gasket
by Farnsworth - 01/18/20 01:26 PM
From my stash
by Fattylocks - 01/18/20 12:48 PM
Toyota to Mexico
by kstanf150 - 01/18/20 12:37 PM
Final Sludge Cleanup, HDEO - Diesel ??
by jssaab - 01/18/20 12:31 PM
A good cabin filter
by NH73 - 01/18/20 10:36 AM
K&N cut open.
by laserred96gt - 01/18/20 10:25 AM
Toyota Oem filter mileage
by Bettez88 - 01/18/20 10:22 AM
OCI, Owners manual versus oil Mfg.
by VQLT - 01/18/20 10:06 AM
MacBook Pro to Microsoft Surface
by Kira - 01/18/20 09:53 AM
Ford 5R55E Auxiliary Transmission Filter
by benjamming - 01/18/20 09:33 AM
Do all synthetic oils act as a cleaner?
by Loobit - 01/18/20 08:26 AM
Mobil 1 ESP now sold in 5qt jugs
by Patman - 01/18/20 08:12 AM
Mobil 1 Extended Performance Oil Filters
by jrommelt - 01/18/20 08:08 AM
These the same?
by Bettez88 - 01/18/20 06:53 AM
MaxLife SB 10w40 on Sale
by Mad_Hatter - 01/18/20 04:27 AM
Bebo77, 2EHA, jonnyb433, kzbd, 54Robert
70465 Registered Users
77 registered members (14Accent, 77GrandPrix, Alfred_B, 2oldtommy, 2015_PSD, 8 invisible), 2,253 guests, and 17 spiders.
Topics300,290
Posts5,172,565
Members70,465
Most Online3,728
Jan 11th, 2020
Page 1 of 3 1 2 3
0w40 in a 2.0 ecoboost #5319990 01/11/20 04:37 PM
B
BigShug681 Offline OP
B
Just curious if anyone has ran it in the 2.0 ecoboost, plan on seeing how it fairs vs the 5w30 that’s recommended
2006 F350 DRW 6.0 PSD with a ZF6 6Speed. If you can't find it or float it then just grind it
Re: 0w40 in a 2.0 ecoboost [Re: BigShug681] #5319995 01/11/20 04:41 PM
bdcardinal Offline
My mom has a 2014 Fusion with the 2.0EB and after the factory fill it received Mobil 1 0W40 for every fill except for one when they put in Motorcraft 5W30 full syn, and the latest one that has Castrol Edge 0W40. I don't really do any UOAs but the oil is changed every 5K miles with a Motorcraft FL-910S filter.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: 0w40 in a 2.0 ecoboost [Re: BigShug681] #5320004 01/11/20 04:54 PM
T
tig1 Offline
T
Maybe slightly less responsive.. What will a 40wt give you that 30 won't. welcome
2007 Ford Fusion 252,000 miles
M1 5-20HM
2017 Ford Fusion 85K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: 0w40 in a 2.0 ecoboost [Re: tig1] #5320009 01/11/20 05:02 PM
B
B
Honestly I’m looking for more protection from fuel dilution, I’ve been running amsoil SS 5w30 and at 15k miles it’s time for change due to fuel dilution knocking the oil into a thin 20w. I want to see how the 40w holds up and if it does well I may try the amsoil European car 5w40 improved.
Re: 0w40 in a 2.0 ecoboost [Re: BigShug681] #5320028 01/11/20 05:16 PM
M
MParr Offline
M
The longer you have any oil in your Ecoboost, the more fuel dilution that you will have. Use a 5W30 on the thicker side and change at 5,000 miles.
2019 VW Tiguan SE 2.0 TSI Now: Castrol Professional OE LL IV 0W20 & OE VW/Mann
2017 Ford Escape SE 2.0T Now: Kendall GT-1 Max 5W30 FS & NAPA Gold 1348
93 Octane Non-Ethanol
Re: 0w40 in a 2.0 ecoboost [Re: BigShug681] #5320041 01/11/20 05:30 PM
PimTac Offline
The Amsoil might be a extended use oil but only if the engine it’s in will allow it.
I agree on the 5k oci.
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: 0w40 in a 2.0 ecoboost [Re: tig1] #5320056 01/11/20 05:44 PM
G
geeman789 Offline
G
Mobil 1 0w40 FS is BARELY a 40 grade oil, at 12.9 cSt. Even Pennzoil Euro 5w40 is on the thin side, being 12.8 cSt at 100*C. A 30 grade oil is between 9.3 and 12.4 cSt at 100*c.
... Maybe slightly less responsive.
You most likely won't be able to tell the difference between the oils ...
If you really want thicker, step up to a 5w40 diesel oil like Rotella T6 or Mobil 1 Turbo Diesel. These will be in the 14 cSt range.
Not sure you really need that though.
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
Re: 0w40 in a 2.0 ecoboost [Re: geeman789] #5320065 01/11/20 05:53 PM
4WD Offline
I’d keep an eye on how much calcium goes in an EcoBoost
Re: 0w40 in a 2.0 ecoboost [Re: 4WD] #5320076 01/11/20 06:14 PM
T
tundraotto Offline
T
^He is right you know......
Re: 0w40 in a 2.0 ecoboost [Re: tundraotto] #5320104 01/11/20 06:32 PM
K
karter8 Offline
K
And what are the statistics regarding pre API plus in an EcoBoost?
Re: 0w40 in a 2.0 ecoboost [Re: BigShug681] #5320109 01/11/20 06:38 PM
J
JLTD Offline
J
Sure, give it a whirl. A 40 is probably specified somewhere else in the world for the same engine. Agree that it's probably a good idea to watch the calcium as mentioned above by 4WD, you wouldn't want to have an LSPI event. I would go with an oil that specifically addresses LSPI.
"Let’s not pretend like 0w20 is anything but a CAFE required crutch to eek another 1/2MPG" - BLND1
Hers: 2018 Ford Flex AWD EB, dealer fill
His: 2015 4Runner 60k, SS 5w20/Amsoil
Re: 0w40 in a 2.0 ecoboost [Re: PimTac] #5320233 01/11/20 08:25 PM
B
B
That’s way too short especially since the OCI is 10k per the manual
Re: 0w40 in a 2.0 ecoboost [Re: JLTD] #5320236 01/11/20 08:30 PM
B
B
All of Amsoil’s SS protects 100% from LSPI, allegedly. I’ve had zero issues with the SS line in the 85k miles we’ve owned it.
Re: 0w40 in a 2.0 ecoboost [Re: BigShug681] #5320379 01/11/20 11:43 PM
T
Talent_Keyhole Offline
T
Wow, you get 15k before it shears back to a 20w oil. My 2.4L Ecotec GDI knocks into the dirt after only 2.5k miles using Amsoil SS 5w-30. Feel fortunate you get the extended drain interval. Back in the 90's, I could easily get 20-25K per OCI with basic Bosch Port Injection system on my 280ZX.
What is your fuel dilution on your UOA's and how often do you test?
Re: 0w40 in a 2.0 ecoboost [Re: BigShug681] #5320385 01/12/20 12:15 AM
B
bbhero Offline
B
Well going to a 5w40 is not in your manual either it sounds like....
Who cares about it being too short... If you have to go up to a 40.... That oil may be low viscosity even at 7,500 miles... That manual may well be wrong about going that long to begin with. .
Nissan Altima 3.5 Coupe
Cam2 full synthetic 5w30 Wix 57356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Page 1 of 3 1 2 3
