75w140?
by mpack88 - 01/18/20 06:00 PM
Are all 9012 bulbs HIR2?
by dvancleve - 01/18/20 03:30 PM
Ariens L-3 Synthetic Severe-Duty Gear Lube
by Astro_Guy - 01/18/20 02:04 PM
LSx Crank lock
by P10crew - 01/18/20 02:03 PM
ST9688 gasket
by Farnsworth - 01/18/20 01:26 PM
From my stash
by Fattylocks - 01/18/20 12:48 PM
Toyota to Mexico
by kstanf150 - 01/18/20 12:37 PM
Final Sludge Cleanup, HDEO - Diesel ??
by jssaab - 01/18/20 12:31 PM
A good cabin filter
by NH73 - 01/18/20 10:36 AM
K&N cut open.
by laserred96gt - 01/18/20 10:25 AM
Toyota Oem filter mileage
by Bettez88 - 01/18/20 10:22 AM
OCI, Owners manual versus oil Mfg.
by VQLT - 01/18/20 10:06 AM
MacBook Pro to Microsoft Surface
by Kira - 01/18/20 09:53 AM
Ford 5R55E Auxiliary Transmission Filter
by benjamming - 01/18/20 09:33 AM
Do all synthetic oils act as a cleaner?
by Loobit - 01/18/20 08:26 AM
Mobil 1 ESP now sold in 5qt jugs
by Patman - 01/18/20 08:12 AM
Mobil 1 Extended Performance Oil Filters
by jrommelt - 01/18/20 08:08 AM
These the same?
by Bettez88 - 01/18/20 06:53 AM
Bebo77, 2EHA, jonnyb433, kzbd, 54Robert
70465 Registered Users
120 registered members (2015_PSD, 2004tdigls, 928, 53' Stude, 9 invisible), 2,249 guests, and 22 spiders.
Topics300,291
Posts5,172,608
Members70,465
Most Online3,728
Jan 11th, 2020
Is cylinder #4 trying to tell me something? #5319969 01/11/20 04:20 PM
J
jayjr1105 Offline OP
J
Changed out my plugs today on my Mazda 3. 4th cylinder is a bit cruddier than the rest with some carbon deposit on it. Not really oily. The electrodes seem fine but clearly from the pic there is something going on with the one. Is this normal? should I be using a fuel additive a time or two?
[Linked Image]
2013 Mazda 3 - PP 0w20
2005 Honda Odyssey - PP HM 5w20
Re: Is cylinder #4 trying to tell me something? [Re: jayjr1105] #5319971 01/11/20 04:21 PM
O
OVERKILL Offline
O
Is that the cylinder closest to where the breather or PCV meets the intake? If so, that's normal.
Re: Is cylinder #4 trying to tell me something? [Re: jayjr1105] #5319972 01/11/20 04:23 PM
J
J
Here is a hi-res image
https://i.imgur.com/BqokgiJ.jpg
Re: Is cylinder #4 trying to tell me something? [Re: OVERKILL] #5319975 01/11/20 04:23 PM
J
J
Yes, it's furthest right plug closest to the intake.
Re: Is cylinder #4 trying to tell me something? [Re: jayjr1105] #5319979 01/11/20 04:29 PM
O
OVERKILL Offline
O
Yeah, so it's getting the crankcase fumes/oil mist. So perfectly normal.
Re: Is cylinder #4 trying to tell me something? [Re: jayjr1105] #5320011 01/11/20 05:04 PM
danez_yoda Offline
you should rotate your plugs at every oil change to prevent that. smile
Re: Is cylinder #4 trying to tell me something? [Re: jayjr1105] #5320024 01/11/20 05:14 PM
R
ragtoplvr Offline
R
I would suggest installing a catch can to prevent much of the vapors from going into the intake.
If #4 is where the return water from the radiator enters, it may be running a little cold. You can use carboard to block half of the radiator in this kind of weather, Just do not forget it come spring.
Rod
Re: Is cylinder #4 trying to tell me something? [Re: OVERKILL] #5320040 01/11/20 05:27 PM
J
J
Thanks for the confirmation. Is an oil catch can really necessary for this motor?
Re: Is cylinder #4 trying to tell me something? [Re: jayjr1105] #5320054 01/11/20 05:43 PM
O
OVERKILL Offline
O
No, and a catch can won't eliminate all of it anyways and just gives you something else you need to worry about.
Re: Is cylinder #4 trying to tell me something? [Re: jayjr1105] #5320063 01/11/20 05:51 PM
spasm3 Offline
The tip and porcelain look clean, so a hotter plug is not needed. The build up is on the threads. The only problem i would see, is if you are not careful removing the plug with a lot of build up. If you meet resistance removing that plug, work it back and forth slowly, till its worked out.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Is cylinder #4 trying to tell me something? [Re: jayjr1105] #5320071 01/11/20 06:04 PM
Mr Nice Offline
On some engines a catch can is a good idea.
Re: Is cylinder #4 trying to tell me something? [Re: spasm3] #5320075 01/11/20 06:13 PM
J
J
That plug did give me a little more resistance than the others but nothing crazy. They all came out just fine with a regular 3/8 ratchet. I went with Ruthenium because they were $7 a plug from RockAuto and the NGK laser iridiums were over $10. We'll see how they pan out but car is running great.
Re: Is cylinder #4 trying to tell me something? [Re: jayjr1105] #5320111 01/11/20 06:40 PM
ddtmoto Offline
...just be aware there is a slew of counterfeit iridium NGK, and others, sparking plugs out there. Just a thought...that's my go to plug, but have to be careful where I buy them anymore. I've been burnt more than once with fraud plugs on eBay...center electrode burnt off to the porcelain before 6k miles.
Mustang GT 5.0 Brembo '11
ram 5.9
TL1000S
GSXR1000
DRZ400E
'09 GTZ1400 Concours
Re: Is cylinder #4 trying to tell me something? [Re: ddtmoto] #5320123 01/11/20 06:46 PM
RDY4WAR Offline
Yep. There's ways to tell the fakes from the real ones. The NGK letting will be slightly off center, and there's some differences in the part number on the mid section. I ordered a set off Amazon that ended up being fake. Amazon took them back and gave a refund. I only get them from NAPA now.
Brake pads are getting that way now too. A friend of mine bought a set of Hawk brake pads for his car and chunks of the pad broke off within just a few hundred miles. He called Hawk and they described exactly what the fake looked like and it was what he had.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: Is cylinder #4 trying to tell me something? [Re: jayjr1105] #5320178 01/11/20 07:34 PM
J
J
I stopped buying certain things from Amazon and instead from RockAuto. Spark plugs, water pumps, etc. Anything that can grenade your car or something that takes serious labor to install.
