3 Fram Ultra's Cut Open
by jetman - 01/20/20 10:31 AM
Standard Cab Commercial
by Duffyjr - 01/20/20 10:17 AM
The thin grease for firearms
by fnbrowning - 01/20/20 10:07 AM
Replace coil packs with spark plugs?
by jayjr1105 - 01/20/20 09:34 AM
Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
Oil ideas for 2 v6 fords and more
by kessellrun - 01/20/20 06:50 AM
Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
FCA and Foxconn partner on EV's
by OVERKILL - 01/19/20 08:55 PM
IIHS Crash pics of Full Size Trucks
by kstanf150 - 01/19/20 08:15 PM
Are Engine Splash Guards Really Needed?
by Mr_Luke - 01/19/20 08:14 PM
supertec cartridge filters
by super20dan - 01/19/20 06:17 PM
More Valvoline on rollback at WM
by jayjr1105 - 01/19/20 06:13 PM
Crossed poles on jumper cables
by 3Aone - 01/19/20 05:33 PM
RSH, Bobjr94, GarageKings, JohnnyD1980, Harry_Seaward
70487 Registered Users
111 registered members (69GTX, 1978elcamino, 2011335d, 14Accent, 66ROGUE, 65convertible, 7 invisible), 2,678 guests, and 40 spiders.
Topics300,347
Posts5,173,826
Members70,487
Most Online3,825
Jan 19th, 2020
Page 1 of 3 1 2 3
Radiator Life / When to replace #5319898 01/11/20 03:34 PM
B
Bebop367 Offline OP
B
Need recommendation on when to replace original radiator.
2005 Toyota Camry V6 1MZ-FE purchased new. 130,000 mile now.
Toyota coolant every 3 years.
White residue along tank seams. Been there years with no change.
At 15 years old should I replace it?
If I replace what brand?
Re: Radiator Life / When to replace [Re: Bebop367] #5319901 01/11/20 03:36 PM
SVTCobra Offline
Unless it's diagnosed as causing a problem, if it ain't broke don't fix it.
Think twice, speak once.
Re: Radiator Life / When to replace [Re: Bebop367] #5319905 01/11/20 03:37 PM
R
Railrust Offline
R
Honestly I wouldn’t change a radiator unless it’s leaking, performance shouldn’t be an issue despite age. I guess if you’re worried it’s going to break on you, go ahead, but I wouldn’t.
2018 Chevy Silverado 5.3
2007 Lexus LS460 (deceased)
2008 Honda CRV
(Whatever synthetic oil is on sale or rebate)
Re: Radiator Life / When to replace [Re: Bebop367] #5319906 01/11/20 03:39 PM
Z
zzyzzx Offline
Z
Wait for it to start leaking.
Re: Radiator Life / When to replace [Re: Bebop367] #5319917 01/11/20 03:46 PM
I
incognito_2u Online Content
Online Content
I
Unless you have anything else wrong besides the residue, I would leave it be.......the 3 Toyota’s in my sig have never (knock wood) had a radiator issue due to our similar PM’ing of the cooling system.
2006 Jeep Commander 3.7 V6 -115k (M1EP5W30/XG3600)
2006 Toyota Corolla 1.8 VVTi -86k (M1EPHM5W30/XG3600)
1999 Toyota Corolla 1.8 -88k (PUP5W30/XG4386)
1998 Toyota Corolla 1.8 -68k (QSUD5W30/XG3600)
Re: Radiator Life / When to replace [Re: incognito_2u] #5319931 01/11/20 03:52 PM
B
Bebop367 Offline OP
B
Wow 98 & 99 on original radiator.
I now thinking I could put in new one that worse quality wise than the Original.
Re: Radiator Life / When to replace [Re: Bebop367] #5319943 01/11/20 04:02 PM
simple_gifts Offline
My 2003 echo i got rid of last year had the original radiator; always had red in it, changed less regularly than specified.
It had 3x+ the mileage as your car.
It probably is prudent just to do under hood inspections more often; i would not change unless you send a kid off to college with it.... or something similar
2004 Prius; 126K; ALM
2007 Yaris 103K ATM
2006 B2300;137K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: Radiator Life / When to replace [Re: Bebop367] #5320008 01/11/20 05:02 PM
Chris142 Offline
We recorded the average milage for broken rads at my work over several years. The average is about 120k. We did not compare car brands. Just averaged the milages of the cars that came in with broken rads.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Radiator Life / When to replace [Re: Bebop367] #5320012 01/11/20 05:04 PM
slacktide_bitog Offline
Radiators aren't wear items to be replaced at regular intervals. Replace it when it leaks smile
Re: Radiator Life / When to replace [Re: Bebop367] #5320017 01/11/20 05:10 PM
slybunda Offline
Mercedes e190 cracked plastic rad end tank outlet where hose goes onto after 25 years and caused overheat but cousin was able to catch it just in time.
I changed rad on my fiesta after 22 years age just to be on safe side and i suspected it may have been blocked or clogged up.
Took end tanks off and it was like new inside and even cut outlet off and noticed it had a brass reforcement inside it.
Turns out i didnt have rad issue. Plastic Waterpump impeller had shattered.
Celica got new rad on it. Original rad lasted 14 years and was missing a quarter of its fins.
1995 Ford Fiesta 1.6i 16v Si
2000 Toyota Celica 1.8 VVTL-i
2007 Toyota Aygo+ 1.0i
Re: Radiator Life / When to replace [Re: Bebop367] #5320034 01/11/20 05:24 PM
Snagglefoot Offline
I have 160,000 miles on my 20 year old Taurus rad. If you replace the coolant regularly, just keep going. smile
If you want the job done right......do it yourself.
Re: Radiator Life / When to replace [Re: Bebop367] #5320073 01/11/20 06:05 PM
H
HangFire Offline
H
Check the color of your ATF and Coolant regularly, and save your money.
Various musings: http://hangfire.net
Re: Radiator Life / When to replace [Re: Bebop367] #5320092 01/11/20 06:24 PM
Passport1 Offline
I have replaced two radiators. The neck broke off a brittle plastic side tank model and the other time a deer made it leak.
1992 940 Volvo turbo 320K
2006 Saab 9-3 86k
2007 Suzuki Burgman
2012 Suzuki Kizashi
Re: Radiator Life / When to replace [Re: slacktide_bitog] #5320120 01/11/20 06:44 PM
B
bullwinkle Online Confused
Online Confused
B
I miss the old days, when leaking meant boil it out & repair it (like my F-450, now 30+ years on the original one!).
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Radiator Life / When to replace [Re: Bebop367] #5320135 01/11/20 06:59 PM
Chris Meutsch Offline
280k original radiator...........why mess with success?
2005 Honda CR-V EX, 280k
Page 1 of 3 1 2 3
