Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
30 monograde
by mpack88 - 01/21/20 10:15 AM
Extended life destroys copper?
by mpack88 - 01/21/20 09:49 AM
Project Farm Lucas transmission additive video
by 1978elcamino - 01/21/20 09:43 AM
1.8t 0w40, plus a situation.
by WMNN1988 - 01/21/20 09:25 AM
Mobil 1™ ESP X2 0W-20 US Availability
by TheIceStormof06 - 01/21/20 08:46 AM
Wire harness/connector
by Redright9 - 01/21/20 07:58 AM
Will You Jump Someone Else's Car?
by Gebo - 01/21/20 07:08 AM
NAPA Edge $20 A/R
by dblshock - 01/21/20 04:54 AM
8 Utes on test.
by Silk - 01/21/20 03:03 AM
Magnetic Socket Rails
by The Critic - 01/21/20 01:19 AM
Oreilly Select complete fuel system cleaner
by keantoken - 01/21/20 12:19 AM
Local Costco Has all Oils and Viscosities $10 Off
by SteveG4 - 01/21/20 12:14 AM
EBC Rotor Pictures
by BBDartCA - 01/20/20 11:28 PM
2012 Acura TSX Wagon
by WhyMe - 01/20/20 10:47 PM
Should I Stick With My Truck? Buy "new"?
by Miller88 - 01/20/20 08:04 PM
Not sure what Pep boys is up to
by Chris142 - 01/20/20 07:38 PM
PastPresMike, RedBeard83, dfrybeck, ckinch1, EAC1
70494 Registered Users
97 registered members (1978elcamino, 2011335d, 28oz, 68nova, 77GrandPrix, aba4430, 8 invisible), 2,168 guests, and 17 spiders.
Topics300,385
Posts5,174,716
Members70,494
2018 3500HD Tranny/Rear End Maintenance #5319820 01/11/20 02:27 PM
P
Phishin Offline OP
P
So my 2018 Silverado 3500HD (6.0 Gas) is at 32k miles. It mostly gets driven around town and a few highway trips....mostly unloaded.
So far, the most I've ever pulled a 14' enclosed trailer with two garden tractors in it. 90% of the time my truck is empty. 5% of of the time there is a 800 pound garden tractor in the bed. So, for a 1-ton truck, it's living an easy life.
What do you think is the best schedule for the tranny and rear end?? I think the rear-end is due for a drain and fill. That should get rid of all the break-in debris.
But for the Tranny (6L90E), I was thinking I'd have the dealership do a complete fluid exchange in the near future. And then in around 60k miles, I'd drop the pan and change the filter. I would probably just do drain and fill's from 60-200k miles and then change the filter again at that time.
What do you think of this plan??
Lastly, what about fluids?? Would you stick with AC Delco DEXRON-VI or do you guys prefer an aftermarket fluid for the transmission and transfer case?? What about the front and rear differentials??
2018 Chevy Silverado 3500HD 6.0L Gas: RLI 10w30
2010 Accord-LX K24: MaxLife 5w30 + Torco MPZ
2014 CR-V LX K24: M1 0w30
Re: 2018 3500HD Tranny/Rear End Maintenance [Re: Phishin] #5319916 01/11/20 03:45 PM
R
Railrust Offline
R
Sounds like a good plan. I’d argue that if you’re capable of doing the tranny service yourself, why not just do it yourself, rather than the dealer? Pan drop, filter replacement, then do it again at 60k.
Every 30k for the diffs sounds good, I’ve been using Mobil1 but I imagine Amsoil would be better. For tranny fluid I just use DexlV. You should probably do your transfer case if you have one.
2018 Chevy Silverado 5.3
2007 Lexus LS460 (deceased)
2008 Honda CRV
(Whatever synthetic oil is on sale or rebate)
Re: 2018 3500HD Tranny/Rear End Maintenance [Re: Phishin] #5319986 01/11/20 04:33 PM
M
maxdustington Offline
M
Do drain and fills of the trans every 30k starting now.
99 Toyota Tercel CE 5EFE/C151
Re: 2018 3500HD Tranny/Rear End Maintenance [Re: Railrust] #5320581 01/12/20 09:15 AM
P
Phishin Offline OP
P
I think getting rid of all the fluid now is a good idea.... Getting rid of all break in clutch material. The filter will be good for another 30k, and then drop the pan and change the filter and freshen up fluid with 4-5 quarts from the pan drop.
Most friction material should slowly accumulate from them on.... So fresh fluid every 30k will keep everything in decent shape for awhile.
Re: 2018 3500HD Tranny/Rear End Maintenance [Re: Phishin] #5321246 01/13/20 05:23 AM
dnewton3 Offline
Global Moderator
Global Moderator
The tranny is a fairly decent unit. I'd advocate for just a drain/fill now and then every 50k after that. Dex VI is a good fluid and holds its vis well.
The diffs only need a decent GL-5 fluid. Assuming you have the G80 locking diff, you'll need a fluid with some FM in it to help with clutch operation (yes - there are clutches in this particular design of the Eaton "Gov-Lok" unit.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: 2018 3500HD Tranny/Rear End Maintenance [Re: Phishin] #5321254 01/13/20 05:44 AM
4WD Offline
AC Delco Dex VI is reasonable when ordered by the gallon. Check a few websites. Think Mobil made lots of it and P66.
I used Mobil 1 in Eaton diffs the longest … but about 4 years back I started getting Delvac 1 from Summit Racing and have used in 3 GM LT’s to date.
Re: 2018 3500HD Tranny/Rear End Maintenance [Re: Phishin] #5321439 01/13/20 10:31 AM
ls1mike Offline
The 6L90E holds about 12.5 quarts. I did a pan drop, filter and fill on my 2017. It took 6.5 quarts. That was at 30,000 miles. GM says change it every 45,000.
Most guys are adding 5.5 to 6.5 quarts after a pan drop, so you do get a bunch out.
Mine was nice and clean at 30,000. So I got half of it out. Ran it the rest of the summer and I am now at 32,000 miles.
Next oil change I will pull the drain plug and swap another 6 quarts. Should stay really clean like that. Not interested in having the dealer mess with it.
If I feel like it I will do what I did what the old truck and pull a cooler line and flush it that way.
I pull 7800lbs about 3000 to 4000 miles a year. Truck may get a total of 5000 miles a year on it.
This, as I have been told, is basically the same rear diff I had in my old 02. I just run Mobil 1 75W-90. I did the fluid once at 23,000 miles and then again at 55,000. I will probably just do it at 45,000 in this truck.
Mike
00 Trans Am WS6 5.7 LS1
17 Silverado 3500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
