Are all 9012 bulbs HIR2?
by dvancleve - 01/18/20 03:30 PM
Ariens L-3 Synthetic Severe-Duty Gear Lube
by Astro_Guy - 01/18/20 02:04 PM
LSx Crank lock
by P10crew - 01/18/20 02:03 PM
ST9688 gasket
by Farnsworth - 01/18/20 01:26 PM
From my stash
by Fattylocks - 01/18/20 12:48 PM
Toyota to Mexico
by kstanf150 - 01/18/20 12:37 PM
Final Sludge Cleanup, HDEO - Diesel ??
by jssaab - 01/18/20 12:31 PM
A good cabin filter
by NH73 - 01/18/20 10:36 AM
K&N cut open.
by laserred96gt - 01/18/20 10:25 AM
Toyota Oem filter mileage
by Bettez88 - 01/18/20 10:22 AM
OCI, Owners manual versus oil Mfg.
by VQLT - 01/18/20 10:06 AM
MacBook Pro to Microsoft Surface
by Kira - 01/18/20 09:53 AM
Ford 5R55E Auxiliary Transmission Filter
by benjamming - 01/18/20 09:33 AM
Do all synthetic oils act as a cleaner?
by Loobit - 01/18/20 08:26 AM
Mobil 1 ESP now sold in 5qt jugs
by Patman - 01/18/20 08:12 AM
Mobil 1 Extended Performance Oil Filters
by jrommelt - 01/18/20 08:08 AM
These the same?
by Bettez88 - 01/18/20 06:53 AM
MaxLife SB 10w40 on Sale
by Mad_Hatter - 01/18/20 04:27 AM
Bebo77, 2EHA, jonnyb433, kzbd, 54Robert
70465 Registered Users
90 registered members (750IX, 2oldtommy, Armkb, atikovi, Aichiguy, 7 invisible), 2,477 guests, and 18 spiders.
Topics300,290
Posts5,172,538
Members70,465
Most Online3,728
Jan 11th, 2020
Broken Oil Fill cap Removal -2007 Civic 1.8 #5319782 01/11/20 01:37 PM
U
user52165 Offline OP
U
Have an immediate need for tool or advise for removal of broken oil fill cap 1.8 Honda Civic. Something like this only larger?:
https://smile.amazon.com/Orbit-Sprinkler-Plastic-Extractor-26076/dp/B000I1RQZ8/ref=sr_1_1?
Don't want to remove valve cover unless necessary.
About 2 threads are in cover, clean break, no residue (Yet).
Thanks in advance.
Re: Broken Oil Fill cap Removal -2007 Civic 1.8 [Re: user52165] #5319827 01/11/20 02:32 PM
U
U
About 1 1/4" diameter.
Re: Broken Oil Fill cap Removal -2007 Civic 1.8 [Re: user52165] #5319848 01/11/20 02:48 PM
M
mk378 Online Content
Online Content
M
How hard have you tried to remove it? It should not be really stuck in there, try twisting it out with your fingers or using a pair of long-nose pliers spread apart.
Re: Broken Oil Fill cap Removal -2007 Civic 1.8 [Re: user52165] #5319926 01/11/20 03:51 PM
doitmyself Offline
This guy uses two opposing screwdrivers that creates a fulcrum to get the threaded piece out: https://www.youtube.com/watch?v=KEcXc2kVuH8
Re: Broken Oil Fill cap Removal -2007 Civic 1.8 [Re: user52165] #5320025 01/11/20 05:15 PM
Driz Offline
Tap gently counter clockwise with a big blunt screwdriver or fat blunt chisel or punch. Stuff a rag in hole in case something does chip off. It will come loose then grab with needle nose.
Here’s the real question everyone really wants to know?? How in %#$$ do you manage to break off an oil cap🤗.
Re: Broken Oil Fill cap Removal -2007 Civic 1.8 [Re: user52165] #5320029 01/11/20 05:18 PM
F
Farnsworth Online Content
Online Content
F
Turn on one side only, pressing on both sides can make tighter. I learned this from fixing camera lenses with thin threaded rings without the correct spanner tools. A sharp catch on one side and rotate it out, put a clean rag in the hole to catch any little chips.
A small sharp screwdriver or maybe just your finger is enough to turn it out. The threads are not tight on these. I've never seen a tight oil cap thread, just the gasket gets tight..
