Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
2016 Overland Jeep Wrangler Oil/Filter
by Since1941 - 05/29/20 04:24 PM
Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
KPVD Eerily Deserted
by wings&wheels - 05/29/20 12:24 PM
BMW N55 Recommendations
by BSchmidt25 - 05/29/20 10:21 AM
Castrol / Mobil 1 blend?
by mbres2000 - 05/29/20 09:40 AM
dieselworks, suburbandoom, alltogether, Vig03, dstocker
71566 Registered Users
100 registered members (4WD, 2_Tall_Mitchell, Alex38, 77GrandPrix, 2003f7, Alfred_B, 10 invisible), 2,124 guests, and 43 spiders.
Topics306,028
Posts5,285,161
Members71,566
Tire feathering and noise #5319401 01/11/20 09:12 AM
supton Offline OP
So my car likes to wear rear tires, not sure if toe is bad but the alignment is good (see here). Last time I did a rotation I had to put up with "singing" tires for a thousand or two miles (a month?) before they wore down. Right now I don't have tire noise--but I'm at the 5k rotation time.
Question: if I don't rotate, and live with it, will the chopped tires start making noise? Am I better to rotate and live with a lower level of noise for a short period of time, so as to avoid actual tire roar later on?
[Background: car had an alignment about 8 months / 17kmiles ago, and they didn't find anything wrong with rear alignment. But the car chopped rear tires before, and now after aligning. I drive about 500 miles per week, all highway. Tires are nice RT43's, 195/70R14 on my 1999 Camry, which has 220k on it.]
2011 Toyota Camry, base, 2.5L/6MT, 205k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 159k, ours
1999 Toyota Camry LE, 2.2L/4AT, 225k, his
Re: Tire feathering and noise [Re: supton] #5319406 01/11/20 09:25 AM
W
wag123 Offline
W
Have you ever had the rear shocks replaced? How about the rear suspension bushings? An alignment won't reveal problems with these components.
Re: Tire feathering and noise [Re: wag123] #5319411 01/11/20 09:29 AM
supton Offline OP
I did new Monroe quick struts not that long ago. 80k & 3 years.
No idea on bushings but it passes annual safety inspection. Just jack it up and see if the wheel has any play?
Re: Tire feathering and noise [Re: supton] #5319417 01/11/20 09:42 AM
A
ARCOgraphite Offline
A
I don't think you could apply enough force UNLESS you had it on a alignmentr rack AND used a come-a-long
Likely LCA bushings are gone and they are moving around with road force.
OR your last service guy messed up the alignment.
If they are feathering on the outside edges, that toe correction at last alignment just pigeon toed the tires
NOthing new , almost 100% of aligments ive had have screed up the wear and steering.
I was to the point I was doing toe in my drive way using wear and steering indicators to make tweeks.
Worked better than a dope with a rack.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Tire feathering and noise [Re: supton] #5319437 01/11/20 10:00 AM
G
Gebo Online Content
Online Content
G
misread the post. Deleted.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Tire feathering and noise [Re: supton] #5319443 01/11/20 10:10 AM
supton Offline OP
Ok, sounds like I might have worn suspension. Not sure what I can repair on my own in the garage...
The question still stands: if I ignore the tires and don't rotate, will they get real loud real quick? Should I rotate and accept short term discomfort?
Re: Tire feathering and noise [Re: supton] #5319484 01/11/20 10:48 AM
M
mclasser Offline
M
I've definitely had choppy/feathered tires make noise. Had one set rumble like bad wheel bearings.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Tire feathering and noise [Re: supton] #5319618 01/11/20 12:43 PM
slacktide_bitog Offline
Usually means the shocks are no good. 80k is a lot on shocks
If you do replace them consider Sachs quick struts smile
Re: Tire feathering and noise [Re: slacktide_bitog] #5319633 01/11/20 12:53 PM
supton Offline OP
How does shocks impact toe? You mean, the struts are sagging? thus causing a change in toe? Kinda means the springs are worn.
I didn't think to check ride height after I did the struts; now that I have a garage I guess I could monitor that.
Re: Tire feathering and noise [Re: supton] #5319864 01/11/20 04:08 PM
Nick1994 Online Content
Online Content
How bad is it? If it's minor and the tread life isn't all that bad, I'd just motor on. If you get 40k miles out of a set instead of 50k, and tires are $420, you're missing out on 20% of life, or $84 every 18 months or so, shrug , not sure if it's worth throwing stuff at.
2015 Hyundai Genesis 5.0L 61k Dealer Bulk SynBlend 5w20 & OEM
2000 Toyota Camry 2.2L 239k Mobil Delvac 15w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Mobil 1 HM 10w40 & Fram Ultra
Re: Tire feathering and noise [Re: supton] #5319894 01/11/20 04:33 PM
supton Offline OP
It is what it is, not sure how much it's worth spending on--it is a 20 year old car, and it's not going to be rust free too much longer, I noticed a bit of rust in a seam today.
I did give in and rotate. We'll see how much it sings. I can always wear earplugs.
Re: Tire feathering and noise [Re: supton] #5319940 01/11/20 04:59 PM
W
wag123 Offline
W
My vote is for worn lower control arm bushings. They DO wear out. When the car is sitting still on the alignment rack it can be in-spec, but with the force of the car going down the road acting on the rear wheels, the worn bushings are allowing a positive camber change and causing the rear tires to tow out. This will cause the kind of tire wear that you are experiencing Supton. It is not a major cost repair, if you are handy you could do it yourself for under $130 in parts to replace all of the control arms on both sides (you could replace just the bushings themselves for less than half this amount if you have an arbor press).
Re: Tire feathering and noise [Re: supton] #5320475 01/12/20 08:18 AM
CapriRacer Offline
A couple of thoughts:
First, the rear toe may be in tolerance, but I don't think it is good. My experience says that toe has to be within the inner half of the tolerance for tire wear not to be a problem. From what I see on the alignment sheets, the rear toe is outside the inner half.
Second, you should rotate on schedule. You want the tires to wear out at the same time. Plus, it reduces the risk that a pair of tires will develop irregular wear.
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: Tire feathering and noise [Re: supton] #5320812 01/12/20 03:33 PM
M
mightymousetech Offline
M
The rear toe may be showing green, but I would want the left and right to be identical. You have quite a bit of thrust angle there. Best if both rear tires were at .11 degrees. Feathering on the outside of the tire confirms this. Too much toe in causes uneven wear on the outside edge of the tire. If I was doing the alignment, I would set left and right rear to 0.10 toe in on each wheel.
That much thrust angle on the rear also causes uneven wear on the front tires IMHO.
Mighty Mouse Tech
BMW Diagnostic and Alignment Tech
2013 BMW 135i M Sport Edition PPE 5W40 MTL/MT-LV
2010 BMW 328i X-Drive, PPE 5W40 MT-LV
Re: Tire feathering and noise [Re: supton] #5321300 01/13/20 08:12 AM
supton Offline OP
Fronts seem to wear fine. I'm hesitant to mess with the alignment, I did once and was rewarded with a car that wandered in any cross breeze. Right now it seems reasonable on windy days.
I didn't notice any extra noise today. Slight change in ride, probably have a front tire slowly losing balance, but no singing like I worried. Motor on!
