Duralast Max Ceramic Pads Photos!
by NASTI - 01/20/20 11:23 AM
expensive rotors
by Donald - 01/20/20 11:19 AM
3 Fram Ultra's Cut Open
by jetman - 01/20/20 10:31 AM
Standard Cab Commercial
by Duffyjr - 01/20/20 10:17 AM
The thin grease for firearms
by fnbrowning - 01/20/20 10:07 AM
Replace coil packs with spark plugs?
by jayjr1105 - 01/20/20 09:34 AM
Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
Oil ideas for 2 v6 fords and more
by kessellrun - 01/20/20 06:50 AM
Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
FCA and Foxconn partner on EV's
by OVERKILL - 01/19/20 08:55 PM
IIHS Crash pics of Full Size Trucks
by kstanf150 - 01/19/20 08:15 PM
Are Engine Splash Guards Really Needed?
by Mr_Luke - 01/19/20 08:14 PM
supertec cartridge filters
by super20dan - 01/19/20 06:17 PM
RSH, Bobjr94, GarageKings, JohnnyD1980, Harry_Seaward
70487 Registered Users
110 registered members (2015_PSD, AlienBug, 2011335d, Ag76, 3Aone, 8 invisible), 2,768 guests, and 41 spiders.
Topics300,349
Posts5,173,895
Members70,487
Most Online3,825
Jan 19th, 2020
Opinions on Liqui Moly 5W/40 Synthetic Motorcycle Oil. #5319353 01/11/20 07:06 AM
M
Morganator Offline OP
M
The Aprilia dealer that i have my 2016 Tuono Factory serviced at changed to this brand. Anyone running this?
“King of Clean”
Re: Opinions on Liqui Moly 5W/40 Synthetic Motorcycle Oil. [Re: Morganator] #5319357 01/11/20 07:12 AM
A
alarmguy Offline
A
Never ran it but have thought about it, tough oil to buy in the USA at a reasonable price.
As far as my thoughts (which doesnt mean much) from everything I read and seen from this company it might be my oil of choice for spec specific engine applications. They cover all the bases right to exotic sports cars.
Check out their website (yeah, I know, marketing) but specs are specs and they have quite an impressive lineup of products.
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Re: Opinions on Liqui Moly 5W/40 Synthetic Motorcycle Oil. [Re: Morganator] #5319390 01/11/20 07:55 AM
P
Pelican Offline
P
I don't know about motorcycles, but It's an outstanding company with products that work, I've used their oil in my MB.
Great bikes the Aprilias!
Re: Opinions on Liqui Moly 5W/40 Synthetic Motorcycle Oil. [Re: Morganator] #5319427 01/11/20 08:50 AM
K
kschachn Offline
K
It is JASO MA2 approved, that means something. Is that what your bike requires?
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Opinions on Liqui Moly 5W/40 Synthetic Motorcycle Oil. [Re: Morganator] #5319597 01/11/20 11:28 AM
B
benjy Offline
B
good stuff, but unless you ride in very cold temps a 5W is not needed as it breaks down faster due to the wide spread viscosity + needs thinner base oils that burn off. USA is awful big what state do you live in + ride.
Re: Opinions on Liqui Moly 5W/40 Synthetic Motorcycle Oil. [Re: benjy] #5319628 01/11/20 11:49 AM
M
M
I live around Houston, Tx. area.
Aprilia strongly recommends 5W/40 for the Tuono. Why i’m not sure but as fragile as these bikes are i’m doing what they suggest...lol
“King of Clean”
Re: Opinions on Liqui Moly 5W/40 Synthetic Motorcycle Oil. [Re: Morganator] #5319704 01/11/20 12:39 PM
K
kschachn Offline
K
Equally important is any specification or approval. Does it require or recommend a JASO spec as I noted above?
If so, then benjy's comments above are irrelevant. JASO standards require a specific shear stability determined through ASTM D6278. If an oil carries that spec then it will have the required shear stability.
http://www.jalos.or.jp/onfile/pdf/4T_EV1904.pdf
1994 BMW 530i, 251K
Re: Opinions on Liqui Moly 5W/40 Synthetic Motorcycle Oil. [Re: kschachn] #5319787 01/11/20 01:41 PM
M
M
Manual says use brand name oils with performance comparable or greater than specifications ACEA A3-API SL-JASO MA- JASO MA2
Liqui Moly has the same wording on the bottle but only JASO MA2 not JASO MA
“King of Clean”
Re: Opinions on Liqui Moly 5W/40 Synthetic Motorcycle Oil. [Re: Morganator] #5320151 01/11/20 07:07 PM
BusyLittleShop Offline
Ligui Moly has no moly... virgin oil sample shows what you are buying... (nice of Blackstone to show 40c viscosity of 77.6 cSt)
[Linked Image]
Larry L
Have a Wheelie NICE day
94 RC45 #2 58,000 on 30 Grade, Currently Mobil 1 5W30 SN
2002 Camaro Mobil 1 5W30
1952 De Havilland Chipmunk
Re: Opinions on Liqui Moly 5W/40 Synthetic Motorcycle Oil. [Re: BusyLittleShop] #5320164 01/11/20 07:20 PM
M
M
Is that good?...lol
“King of Clean”
Re: Opinions on Liqui Moly 5W/40 Synthetic Motorcycle Oil. [Re: Morganator] #5320197 01/11/20 07:51 PM
K
kschachn Offline
K
Is that good?...lol
This is actually a good question. You can't tell by a $35 VOA, how you tell is by the approvals and certs the oil has and using the appropriate grade.
1994 BMW 530i, 251K
Re: Opinions on Liqui Moly 5W/40 Synthetic Motorcycle Oil. [Re: Morganator] #5320246 01/11/20 08:43 PM
Is that good?...lol
Moly or no moly any 40 grade synthetic oil will meet and exceed your mileage expectations...
Aprilia Tuono V4 used oil sample after 3,600 miles... oil is Motul 300V 10W40...
Blackstone comments...
" Thanks for the note. It usually takes a few oil changes before wear-in has a chance to clear out
entirely, and we're taking that into consideration when looking at the aluminum level. It shows wear at the
pistons/clutch in your 1100 V4, and we should see aluminum steadily improve with each consecutive oil
change. Averages show typical wear for the engine type after ~1,700 miles of oil use. The other metals are
already in good standing with the averages. The viscosity is low but these engines tend to (harmlessly)
shear the oil. Check back to see improvements."
[Linked Image]
Larry L
