Post your latest oil change
2018 Subaru Outback Limited 2.5L - 86,250 miles
OUT: Shell Rotella Gas Truck 0w20, Subaru OEM oil filter
IN: Shell Rotella Gas Truck 0w20, Fram Ultra Synthetic oil filter XG7317
Ford F-150 in signature
12/2/2019 Works package at quick lane at 8919 miles. 3700 miles on oil OLM 31%
Out: 6 qts of Motorcraft 5w-20 Semi Syn and FL500s filter
In: same thing
The engine has used no oil in the first 19 months of ownership
2007 Acura TSX, 136K, 5K OCI, 15% Maintenance Minder
Out: 5 qt QS Syn, Fram 7317 UG (2nd OCI, 11K miles)
In: 5qt Valvoline HM Syn 5w30, Fram 7317 UG
Warshed and waxed the TSX
Gonna do a brake pad slap and flush brake fluid.
I am finding the Fram UG to be very difficult to remove. TSX filter is in rear and hard to get to. Messy!
I can usually remove filters by hand. Might go back to M1...
2016 Toyota Sienna LE FWD 3.5 2GR-FE, 104,400 miles
About 4400 miles on oil & filter, time unknown.
OUT: unknown (though I suspect NAPA oil and filter as the small mom & pop dealership we purchased from in August '19 had NAPA Advertising all over in their repair bay.)
IN: Mobil 1 Extended Performance 0W-20 6.5 quarts +/-
Mobil 1 M1C-251A filter
I plan on running it 1 full year (Nov '19 - Nov '20) which will be 10,000+ miles and then send it out for analysis. This is my first time using M1EP so we'll see how it performs.
The engine is super quiet with M1EP 0W-20. It must like this "Flavor" LOL.
Someone put 100k on this engine in three years. So odds are, the oil wasn't changed often. How bad did the oil look at 4.4K? Can you see down the oil cap?
This new EP will clean the engine better than NAPA. You should 'at least' monitor the looks & smell of the dipstick oil during the summer. This first run of EP (on an unknown engine) may need to be changed earlier than 10K. Glad that you mentioned using a good quality trap filter.
2018 Toyota 4Runner SR5 Premium
43,500 miles on vehicle
Approx 3,800 miles on oil
Out: Liquimoly 0w20 (approx 3.5 quarts)/Shell RGT 0w20 (approx 3 quarts) OEM Filter
In: Shell RGT 0w20 OEM Filter
How do you know M1 EP will clean better than NAPA oil?
3.5Q is low for a change. Are you just sucking a bit out and replacing it a bit at a time?
This is funny!
You have 5k in service time here for the past 9+ years and you ask a question like it's your first week here.
I suppose you don't know which brand-name oil is in the NAPA jug either.
Keep reading stuff here. Keep reading about oils outside this website also. Things will eventually become clearer for retention purposes.
Ah, so you have no evidence or data for your claim and instead you resort to passive aggressive comments. This is funny, your slip is showing, all the way down to your ankles
2019 Subaru Impreza hatchback, FB20
18,195 miles with 5820 miles on oil
Out: Rotella 5w-30 multi-vehicle/Purolator PBL 14615 (12,295 miles on filter-2nd OC)
In: Rotella 5w-30 multi-vehicle/Purolator PBL 14615
10 Chevy Malibu
3.5 v6
Out: havoline 10/30, mighty filter
In: Napa 5/30, Napa gold filter
12 Ford fusion
2.5 4 cyl
Out: Napa 5/20, full throttle hm oil treatment, Napa gold filter
In: Napa 5/20, full throttle hm oil treatment, Napa gold filter
3.5 quarts of Liquimoly AND 3 quarts of Rotella Gas Truck. Approximately 6.7 quarts total.
Replaced with ALL Rotella Gas Truck.
2006 tahoe 196k
Out mix of 5w 30 penzoil ultra and qsud and ultra filter.
IN Valvoline full syn 10w 30 maxlife
Fram ultra filter
Trying to slow a rear main seal leak
Florida not to worried about cold flow
