Coolant flush machines
by Donald - 01/25/20 08:24 AM
How do you scratch the new car itch?
by supton - 01/25/20 08:07 AM
2019 f550 6.7
by ame299 - 01/25/20 07:49 AM
unthinkable problem after oil change
by NH73 - 01/25/20 07:37 AM
Anybody burn wood for heat? Advice please.
by dlundblad - 01/25/20 07:21 AM
2002 cummins
by coondog - 01/25/20 07:07 AM
New Mercedes Ute
by Shannow - 01/25/20 03:04 AM
A decent battery charger for sub $50?
by michaelluscher - 01/25/20 02:03 AM
Temperature swing affects on oil
by leeaspell - 01/25/20 12:58 AM
Coefficient of Friction
by jrommelt - 01/24/20 11:46 PM
2017 Chevy Cruze Diesel Oil
by Ponch - 01/24/20 11:03 PM
electric motor amp rating
by motor_oil_madman - 01/24/20 10:42 PM
Radio, Instrument panel, display, AC cutting off
by DrDanger - 01/24/20 09:39 PM
Filter Brand Quality Change?
by BBDartCA - 01/24/20 09:21 PM
Autozone $7 off $30
by GMguy84 - 01/24/20 09:17 PM
Honda Power Steering Fluid
by shortlid - 01/24/20 09:14 PM
Autozone Clearance 2020 M1EP
by GMguy84 - 01/24/20 09:11 PM
Spark Plugs
by A_Spruce - 01/24/20 09:00 PM
ame299, Whoop, coondog, steelbeams, Pete44
70522 Registered Users
104 registered members (1foxracing, 2010Civic, 53' Stude, 55hambone, 67ZL1, adams355, 11 invisible), 2,458 guests, and 21 spiders.
Topics300,524
Posts5,177,720
Members70,522
3-in-1 multi-purpose oil - safe on rubber/plastic? #5319016 01/10/20 06:45 PM
W
WildCoast Offline OP
W
I know that non-synthetic dino grease can destroy or at least be hard on some rubber materials. I'm wondering if 3-in-1 multi-purpose oil will also adversely effect rubber?
Looking at the SDS for the oil:
- 97% - Severely Hydrotreated Heavy Naphthenic Oil
- 2% - Naphtha, petroleum
I don't know a lot about this stuff, so guessing: Naptha is made from crude, so non-synthetic oil. So I'm assuming it won't play well with rubber??
---Why am I asking?
So I have a set of studded (Nokian) winter tires sitting around, and noticed that the studs are heavily rusted. Would rather have the studs not rust and become useless during storage, so was gonna put a drop of oil on each. Was about to reach for the 3-in-1 when I realized I might actually damage the rubber (at least enough for the studs to become loose and fall out). I'm guessing I'm better off using a silicone-based oil?
Re: 3-in-1 multi-purpose oil - safe on rubber/plastic? [Re: WildCoast] #5319023 01/10/20 06:48 PM
I
Imp4 Online Content
Online Content
I
Seems like a job for 303...
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: 3-in-1 multi-purpose oil - safe on rubber/plastic? [Re: WildCoast] #5319135 01/10/20 09:26 PM
Donald Online Content
Online Content
How about a smear of wax on each stud from a Johnny ring.
2015 Ford F-250 w/Powerstroke
Re: 3-in-1 multi-purpose oil - safe on rubber/plastic? [Re: WildCoast] #5319143 01/10/20 09:30 PM
G
GMBoy Offline
G
You could probably use a brake lubricant that is safe with rubber.
Re: 3-in-1 multi-purpose oil - safe on rubber/plastic? [Re: WildCoast] #5319288 01/11/20 03:55 AM
Dave9 Offline
1) No, it's not necessarily a matter of synthetic vs non-synthetic.
2) It depends on the specific rubber formulation, assuming it is not natural rubber. You ID that and use a chemical compatibility chart. If in doubt, or it cannot be determined, assume a petroleum/like oil is not compatible.
The reason you should not oil your studs is that is nuts. You don't want any sort of lube, anywhere near your tire treads. Self-defeating, rusty studs grip better than oiled treads do.
Clean the rust off and store them in air tight bags. If it is humid when you pack them away, throw a sock full of dry rice in with them to absorb the moisture if you don't want to pay more for a fancier way to do it.
You should rinse (and dry) any salty residue off your tires before storage, but a little surface rust is not a problem.
Re: 3-in-1 multi-purpose oil - safe on rubber/plastic? [Re: WildCoast] #5319322 01/11/20 06:09 AM
B
Boomer Offline
B
I have noted on here before....most lubricating oils will swell a lot of different rubbers particularly EPDM and related elastomers. This type of rubber is frequently used in tires and rubber foam seals. Nitrile rubber is rather oil resistent in some forms and is used where contact with oil may occur (cork rubber gaskets or rubber gaskets for valve covers, for example). One of the ways of quantifying crosslink density in cured elastomers is to soak them in various solvents or oils and measure the amount of swelling. So you can see that oil is not a friend of certain rubber materials. Silicone based fluids or greases are much better around rubber. I use a silicone grease on my ddor seals to keep them soft and pliable.
I doubt that the studs will have a problem if you just took a hose and washed off the tire and allowed it to dry. After all, those tires sit in salt all winter and survive
2019 VW Passat 2.0 liter gasoline DI engine, DI, 2,700 miles, Castrol Professional VW 508 0W-20
2017 VW Golf All Track 1.8 liter gas engine DI, 25,500 miles Castrol Professional VW 505 5W-40
Re: 3-in-1 multi-purpose oil - safe on rubber/plastic? [Re: WildCoast] #5319355 01/11/20 07:09 AM
J
joekingcorvette Offline
J
I would wrap them in large plastic bags and call it good since tires are only safe for about 5 years.
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
