Do all synthetic oils act as a cleaner?
by Loobit - 01/18/20 08:26 AM
Mobil 1 ESP now sold in 5qt jugs
by Patman - 01/18/20 08:12 AM
Mobil 1 Extended Performance Oil Filters
by jrommelt - 01/18/20 08:08 AM
These the same?
by Bettez88 - 01/18/20 06:53 AM
MaxLife SB 10w40 on Sale
by Mad_Hatter - 01/18/20 04:27 AM
Walmart Oil Change?
by Talent_Keyhole - 01/18/20 12:50 AM
Bleh, mother’s gas furnace fan burned up
by Rmay635703 - 01/17/20 11:23 PM
Rotella gas truck vs Valvoline modern engine
by MoPowa - 01/17/20 09:25 PM
Afton Specification Handbook -- September 2019
by Gokhan - 01/17/20 09:04 PM
Old Retired Navy Commander
by KeithS_NW_Ohio - 01/17/20 08:58 PM
Mobil 1 EP vs Mobil 1 EP Truck & SUV
by jrommelt - 01/17/20 08:29 PM
Stick with Maxlife or go back to DW-1?
by jayjr1105 - 01/17/20 07:58 PM
Thread locker
by zzyzzx - 01/17/20 07:56 PM
A preppers tale
by Bluestream - 01/17/20 07:50 PM
19 Ram Rebel oil choices
by Schwifty - 01/17/20 07:35 PM
Is it impossible to get a loan for an older vehicle?
by FordBroncoVWJeta - 01/17/20 07:22 PM
Fridge and freezer oil test
by jkhawaii - 01/17/20 06:59 PM
2EHA, jonnyb433, kzbd, 54Robert, CPA1989
70464 Registered Users
102 registered members (55hambone, 4WD, 53' Stude, 54Robert, 1foxracing, 7 invisible), 1,992 guests, and 19 spiders.
Topics300,274
Posts5,172,152
Members70,464
Most Online3,728
Jan 11th, 2020
Best oil for my BMW m240i (B58) #5318911 01/10/20 04:53 PM
O
Ov3rLord1377 Offline OP
O
Hi, I am new to understanding oil in more depth but I am definitely keen to learn if anyone wants to teach me. I understand basic stuff like lower NOACK is important to reduce oil burn off and higher base number is good to balance PH. I have also looked Into the importance of viscosity index and understand higher index is more stable.
Anyways on to my question, My car has just gone out of warranty so I will be servicing it myself from now on. I have narrowed it down to 5 oils based on my usage. The car is modified and making just shy of 500whp on e85. It is a weekend car and is mostly driven for joy rides and track days. Although I have done the occasional long distance road trip in it. I live in Australia so I never experience sub 0 climate and the summers can get pretty hot. I believe 0w-40 or 5w-40 would be suitable for my application (not sure which is better)
I have narrowed down to 5 oils and would love to hear other people’s opinions. Preferably if you could rank them 1-5 based on my application that would be very helpful. Please keep in mind money is not a factor I am simply looking for the best preforming product.
Kind regards, Richard
Redline 5w-40
https://www.redlineoil.com/Content/files/tech/5W40_MO_PROD_INFO(1).pdf
Redline 0w-40
https://www.redlineoil.com/Content/files/tech/0W40_MO_PROD_INFO.pdf
Pennzoil 5w-40
https://www.shell-livedocs.com/data/published/en-US/0e3544af-ccd8-4d0d-899f-10312920cbb8.pdf
Amsoil 5w-40
https://www.amsoil.com/lit/databulletins/g3395.pdf
Motul 5w-40
https://d23zpyj32c5wn3.cloudfront.net/images/product_descriptions/technical_data_sheets/52/8100_X-cess_5W-40_%28GB%29.pdf?1503652273
Last edited by Ov3rLord1377; 01/10/20 04:57 PM. Reason: Needed to mention car is run on e85
Re: Best oil for my BMW m240i (B58) [Re: Ov3rLord1377] #5318928 01/10/20 05:09 PM
E
edyvw Offline
E
Castrol 0W40 will do fine. Do not focus on 0W. That Castrol is thinner than 5W40 but pack same HTHS, indicting better base stocks.
Pennzoil will do, Motul etc. Amsoil is OK, but nothing there indicates anything better than otehr oils.
Redline is really thick. Not sure why would you need that.
11' BMW 328i xDrive 6MT (BMW TPT 5W30+OE filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: Best oil for my BMW m240i (B58) [Re: Ov3rLord1377] #5319003 01/10/20 06:36 PM
SR5 Offline
Hi Mate,
Let’s not confuse price and rareness with quality and ability. That is a strange selection of oils for Australia and it certainly shows “money is not a factor”. What you need is an oil rated BMW LL-01, and maybe Porsche A40 since you are modified. These are both based on the Euro ACEA A3/B4 spec.
My list would be, for Australia,
Shell Helix Ultra 5W40, KV100 = 13.1 cSt (our Pennzoil Platinum Euro)
Penrite HPR5 (5W40), KV100 = 14.4 cSt, 1240 ppm Zinc.
Castrol Edge 5W40 A3/B4, KV100 = 12.8 cSt
Castrol Edge 0W40 A3/B4, KV100 = 13.2 cSt (no longer lists BMW LL-01, but still A3/B4, PorscheA40 and MB 229.5)
Mobil 1 FS 0W40, KV100 = 12.9 cSt (no longer lists BMW LL-01, but still A3/B4, PorscheA40 and MB 229.5)
Castrol Edge 5W30 A3/B4, KV100 = 11.9 cSt (it’s BMW LL-01, but not Porsche A40)
Apart from the Penrite (which is a bit richer) they all should have about 1000 ppm Zinc. They are all updating and changing specs constantly, but above is the best I can do for what is commonly available in Australia.
Me? Shell Helix Ultra 5W40 as it’s easy to find, affordable, Shell’s top-shelf product and carries true OEM approvals for A3/B4, BMW LL-01, MB 229.5 and Porsche A40. Second would be Penrite HPR5 as it’s the thickest with the most zinc (for extra protection), it carries true OEM MB 229.5 spec, but I believe their BMW spec is just “suitable for”.
Ref:
(SHU PDF)
(Edge 5W40 PDF)
(Edge 0W40 PDF)
(Edge 5W30 A3/B4 PDF)
(HPR 5 PDF)
(M1 FS 0W40 link)
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
Re: Best oil for my BMW m240i (B58) [Re: Ov3rLord1377] #5319052 01/10/20 07:13 PM
E
edyvw Offline
E
I forgot you guys have Euro version of 5W40.
Re: Best oil for my BMW m240i (B58) [Re: SR5] #5319071 01/10/20 07:47 PM
O
O
Thanks for all the info!! I will look into Shell helix ultra as I like that it still maintains the ll-01 standard. Would you recommend I add a ZDDP additive as I have removed the catalytic converter?
Re: Best oil for my BMW m240i (B58) [Re: Ov3rLord1377] #5319083 01/10/20 08:16 PM
K
kschachn Offline
K
No additives. I am willing to bet your owner’s manual says to not add any additives to the oil. Why would you mess with the additive pack that comprises the Longlife-01 approval and negate that?
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Best oil for my BMW m240i (B58) [Re: Ov3rLord1377] #5319102 01/10/20 08:45 PM
O
O
I have narrowed it down to either penrite’s 0w40 premium or shell helix ultra 5w40
Penrite 0w-40
Shell Helix Ultra 5w-40
Between these two which is best ?
Re: Best oil for my BMW m240i (B58) [Re: Ov3rLord1377] #5319141 01/10/20 09:29 PM
A
adams355 Offline
A
Penrite 0w-40
Can't go past the shell ultra. I have tried most of the aussie brands and Castrol edge and Valvoline synpower. The shell ultra has been the only oil that made a significant difference in general. Read up on the GTL base oil that is used in shell ultra. The oil is very close or even equal to a PAO based oil. Make sure you get the shell ultra labeled with pure plus technology. Aussie oils are pretty good but cant compare to the big names and their resources.
2007 Ford XR6 Turbo (modified) - Shell Helix Ultra 5W-40 SN A3/B4 - Purolator ONE filter + ZF 6 speed - Gulf Western SYN-TS
2008 Holden Craptiva (wife's) - Castrol 5W-30 A3/B4 - Shell R next
Re: Best oil for my BMW m240i (B58) [Re: adams355] #5319240 01/11/20 12:36 AM
O
O
I had a read and it all sounds very promising Indeed!
Re: Best oil for my BMW m240i (B58) [Re: Ov3rLord1377] #5319248 01/11/20 01:03 AM
dave1251 Offline
The one which meets the specs for the least amount of money at the time of purchase.
don't use.
Re: Best oil for my BMW m240i (B58) [Re: Ov3rLord1377] #5319252 01/11/20 01:15 AM
SR5 Offline
Hi Mate,
Both are very good full synthetic oils.
The Penrite 10-Tenths Premium 0W40 is PAO based with real OEM approvals for MB 229.5 and Porsche A40, while suitable for BMW LL-01. It’s a bit thicker at KV100 = 13.9 cSt and has a higher Viscosity Index (VI) of 182 while being shear stable.
The Shell Helix Ultra 5W40 is GTL (PurePlus) based with Shell being very particular about getting all the correct OEM approvals BMW LL-01, MB 229.5 and Porsche A40. It’s KV100 = 13.1 cSt and a V.I. of 168.
Both would have a TBN over 10 for long oil life, and both would have around 1000 ppm (0.1 %) zinc for extra wear protection (over the standard ILSAC limit of about 800 ppm).
I would be very happy with either. BTW Don’t add an extra ZDDP (Zinc) additive to either oil, they are very well developed products, use as Shell / Penrite designed them.
Me ? I would go the Shell Helix Ultra. Shell is a BIG oil company, and this is the very best oil that they make.
Re: Best oil for my BMW m240i (B58) [Re: Ov3rLord1377] #5319274 01/11/20 02:44 AM
A
adams355 Offline
A
The Shell is about $50 for 5L
The Penrite is about $90 for 5L * from the website it says 14.9 @ 100C
Both very good oils but I am a Shell Ultra fan banana
However I just read your first post again lol. The Penrite would be a better track oil especially with e85.
Re: Best oil for my BMW m240i (B58) [Re: Ov3rLord1377] #5319305 01/11/20 05:12 AM
O
Olas Offline
O
E85 requires a longer injector-on time because of the reduced BTUs compared against regular pump fuel, along with the increased amount of air required to support 500hp, suggests to me that there will be a greater volume of blow-by than would be experienced in an unmodified engine.
For this reason I would tend toward an oil with a good amount of POE as it stands up better to fuel related shear.
40 is probably better than 30 for hard driving in Austrlia given the chance of exceeding 100c although the choice of base stock has an influence here too.
Any A3/B4 will probably be fine, but for the amount of money we can assume you have spent on the engine it would make sense to spend a little more on an oil designed for hard use and performance engines as compared to something made to meet spec and be used in family cars that sit in traffic.
Redline 5w30 or 5w40 would be my choice after logging oil temps in various driving scenarios
Cable ties should hold it
Re: Best oil for my BMW m240i (B58) [Re: Ov3rLord1377] #5319332 01/11/20 06:30 AM
A
adams355 Offline
A
Redline is a great oil but it is $100 a gallon here in AU
Motul might be worth looking at as well its not quite as expensive.
I still think the Penrite would do the job.
Re: Best oil for my BMW m240i (B58) [Re: Ov3rLord1377] #5319544 01/11/20 10:33 AM
cristo Offline
Still in warranty so will be using the BMW 0w30,
although I suspect the dealer will put the 0w20
in for the freebie changes.
I think I’ll try asking them to use the 0w30 TwinPower Turbo instead.
