Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
Oil ideas for 2 v6 fords and more
by kessellrun - 01/20/20 06:50 AM
Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
FCA and Foxconn partner on EV's
by OVERKILL - 01/19/20 08:55 PM
IIHS Crash pics of Full Size Trucks
by kstanf150 - 01/19/20 08:15 PM
Are Engine Splash Guards Really Needed?
by Mr_Luke - 01/19/20 08:14 PM
supertec cartridge filters
by super20dan - 01/19/20 06:17 PM
More Valvoline on rollback at WM
by jayjr1105 - 01/19/20 06:13 PM
Crossed poles on jumper cables
by 3Aone - 01/19/20 05:33 PM
Napa Gold 7060 7.5K miles
by KenshinHimura - 01/19/20 05:09 PM
Can you move a car with the starter?
by atikovi - 01/19/20 04:49 PM
Leaf spring advice.
by mpack88 - 01/19/20 02:19 PM
Bobjr94, GarageKings, JohnnyD1980, Harry_Seaward, MrH1325
70486 Registered Users
98 registered members (AndyB, ABerns, A310, aquariuscsm, atikovi, angeloc, 10 invisible), 2,238 guests, and 36 spiders.
Topics300,341
Posts5,173,722
Members70,486
Most Online3,825
Jan 19th, 2020
Replacing brake pedal rubber #5318796 01/10/20 03:24 PM
007 Offline OP
I recently noticed that my brake pedal rubber with the disc brake disc in the middle had cracked from top to bottom on my A body. I bought a new set of replacement pads which came with the regular pedal and emergency pedal rubber. I am sure it will be easy to get the old stuff off but is there a secret in getting the new stuff on?
Re: Replacing brake pedal rubber [Re: 007] #5318805 01/10/20 03:34 PM
P
pitzel Offline
P
Should just slide on. You might want to use a bit of water or silicone spray as a lubricant to aid the process of stretching the pedal rubber to fit onto the metal, but make sure that you clean any lubricant off of the pedal surface once you're done.
Change your thinking...not your oil!
Turn your mind....not your rotors!
Re: Replacing brake pedal rubber [Re: 007] #5318933 01/10/20 05:13 PM
T
Trav Offline
T
Grab the wife's hair spray. Seriously.
Re: Replacing brake pedal rubber [Re: Trav] #5318985 01/10/20 06:14 PM
T
Traction Online Content
Online Content
T
Exactly! Works good for motorcycle grips, etc. I'm still trying to figure out how to get the hair spray off the drivers side window of every car she has had. I've had to use a razor blade since I didn't have the right stuff.
Certified Tire Service Instructor since 2009
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: Replacing brake pedal rubber [Re: 007] #5318993 01/10/20 06:24 PM
P
PandaBear Offline
P
Are you talking about brake pedal that you step on? or the brake pad rubber cushion on the hardware?
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Replacing brake pedal rubber [Re: Traction] #5319145 01/10/20 09:31 PM
spasm3 Offline
Lacquer thinner should do it. A lot of hairspray is lacquer, at least the aqua-net i used to fuel my potato gun was.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Replacing brake pedal rubber [Re: spasm3] #5319380 01/11/20 07:40 AM
W
willbur Offline
W
Aqua-net was the good stuff. Worked better than other brands. Still available?
