belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
30 registered members (bbhero, cjcride, 4WD, bachman, CNT, aleneros, 2 invisible), 1,360 guests, and 26 spiders.
Topics301,894
Posts5,204,861
Members70,798
Best oil for ford 1.5 tdci? #5318630 01/10/20 12:22 PM
dv5tdci Offline OP
Hey all, im new to this forum. I've been thru all related posts for my question but couldn't find a conclusive answer. So here are my queries:
Engine: ford 1.5 tdci run 40k kms.
Weather: min 60F Max 115F
Usage: stop and go heavy traffic and highway (50:50)
Currently running ford spec 5w30 a5/b5 913c oil (mobil 3000). The official OCI is 10k kms but I've found the engine gets noisy and rough after around 7k kms.
Hence i stick to the 7k kms OCI
Engine consumes ~300-400 ml of oil in that period.
From what I've read, A5/b5 is a resource conserving oil with lower hths. And the 913c spec mandates extra zddp in the oil.
Would i be better off using a 5w30 A3/B4 oil or even an E7/E9 oil?
Would the higher HTHS and lower zddp in these oils cause more wear or less?
Im not bothered about about the fuel economy drop (which i assume would be marginal)
What would be the best oil for my usage and climate?
Re: Best oil for ford 1.5 tdci? [Re: dv5tdci] #5318697 01/10/20 01:49 PM
T
tig1 Offline
T
M1 5-30 performs very well in turbo engines and has the Honda high heat and low deposit spec.
2007 Ford Fusion 253,000 miles
M1 5-20HM
2017 Ford Fusion 86K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: Best oil for ford 1.5 tdci? [Re: dv5tdci] #5318718 01/10/20 02:05 PM
stxonall8 Offline
It’s a diesel correct? If so any 5w40 synthetic should do well
mine 15 silverado crew cab 5.3 2wd valoline syn 0w20 fram toughguard oil filter
hers 16 silverado ex-cab 4x4 4.3 ff
Re: Best oil for ford 1.5 tdci? [Re: stxonall8] #5318725 01/10/20 02:13 PM
T
tig1 Offline
T
OOPs. didn't notice the diesel. Maybe M1 5-30 ESP. smile
M1 5-20HM
M1 0-20EP
M1 10-30 in all OPE
MC filters
Re: Best oil for ford 1.5 tdci? [Re: stxonall8] #5318734 01/10/20 02:19 PM
dv5tdci Offline OP
Yes it is a diesel. How about using 5w30 a3/b4 which would be thicker than the a5/b5?
Re: Best oil for ford 1.5 tdci? [Re: dv5tdci] #5318765 01/10/20 02:55 PM
E
edyvw Offline
E
You did not provide crucial information: Does it have DPF?
11' BMW 328i xDrive 6MT (BMW TPT 5W30+OE filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: Best oil for ford 1.5 tdci? [Re: edyvw] #5318775 01/10/20 03:01 PM
dv5tdci Offline OP
My apologies, No it does not have DPF
Re: Best oil for ford 1.5 tdci? [Re: dv5tdci] #5318782 01/10/20 03:08 PM
E
edyvw Offline
E
Than you can use pretty much anything, but stick to diesel specified oil due to soot control. You can use ACEA C3 safely.
Re: Best oil for ford 1.5 tdci? [Re: edyvw] #5318791 01/10/20 03:23 PM
B
Bjornviken Offline
B
+1
Re: Best oil for ford 1.5 tdci? [Re: dv5tdci] #5319251 01/11/20 01:15 AM
B
Bailes1992 Offline
B
I've had 4 of these engines and my UOA's always showed best results with an ACEA C3 lube.
19 Volvo V40 D3 Auto Shell Helix ECT 0w30
18 Jeep Renegade Longitude eTorq 2WD Shell Helix 5w40
03 Ford Mondeo 3.0 V6 Shell Helix 5w40
96 Defender 300TDi Maxlife 15w40
Re: Best oil for ford 1.5 tdci? [Re: Bailes1992] #5319277 01/11/20 03:15 AM
dv5tdci Offline OP
Thanks for your input guys!
So my next oil will probably be Castrol edge ACEA C3.
Wondering if it'd last the the whole 10k.
I've another question.
Why hasn't ford recommended C3 instead of A5/B5?
Is it solely for fuel efficiency?
Re: Best oil for ford 1.5 tdci? [Re: dv5tdci] #5319331 01/11/20 06:29 AM
J
jbutch Offline
J
Yes, 100% fuel economy.
2015 Forester XT @ 104k km
Current fill: Pennzoil Euro LX 0w-30 with Fram Ultra XG7317
