Which of the car value books are accurate ?
by WhyMe - 01/27/20 09:05 PM
Severe Service
by tiger862 - 01/27/20 08:53 PM
Platinum, Iridium, Ruthenium, oh my!
by Astro_Guy - 01/27/20 08:28 PM
Hit 200K miles today!
by SLO_Town - 01/27/20 08:20 PM
Valve Cover at 304849 miles
by Marco620 - 01/27/20 08:17 PM
Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T
by chinee - 01/27/20 07:11 PM
Quaker State deal
by JohnnyJohnson - 01/27/20 06:46 PM
A new deal on Castrol Edge EP 5W-30
by JohnnyJohnson - 01/27/20 06:37 PM
Burning smell from rear wheel
by 2010Civic - 01/27/20 06:01 PM
2017 VW Golf 1.8T - Valvoline 5w40 MST - 8,600 miles
by BurntMusic - 01/27/20 06:00 PM
Cost to rebuild a Ford 4R75E vs. new or used.
by atikovi - 01/27/20 05:26 PM
Autozone Clearance 85w140 gear oil 5 gal
by GON - 01/27/20 04:31 PM
Resonating Noise at 3000rpm
by tookien - 01/27/20 04:28 PM
Looking for Purolator Tech oil filter pics.
by Black_Thunder - 01/27/20 04:02 PM
2019 Mini Cooper Clubman S ALL4 Review
by oilpsi2high - 01/27/20 02:51 PM
The "Penny Challenge"
by ZeeOSix - 01/27/20 02:32 PM
2008 Highlander Battery Post Bolt Snapped
by maverickfhs - 01/27/20 02:31 PM
conventional wisdom rebuild axle or replace?
by NissanMaxima - 01/27/20 01:22 PM
IslandOil, 01VFR, M10, H20ham, Meletz
70544 Registered Users
65 registered members (2009Caraman, 2strokeNorthstar, 4WD, bbhero, BigCahuna, 7 invisible), 1,930 guests, and 15 spiders.
Topics300,653
Posts5,180,382
Members70,544
Is Conoco-Philips FS ow20 Good Oil? #5318711 01/10/20 02:01 PM
M
Mr_Luke Offline OP
M
I just learned this is the oil that was put into my 2012 Prius. It's full synthetic 0w20.
The Acura / Mazda dealership buys it in bulk and evidently if it's good enough for Acura and Mazda cars it should be good enough for my Prius.
If this is good I should be all set until about late December of this year.
I only drive up to about 5000 miles per year.
2012 Toyota Prius C / 108k
Conoco Phillips 0w20 FS
Federated PG4476F
Re: Is Conoco-Philips FS ow20 Good Oil? [Re: Mr_Luke] #5318715 01/10/20 02:03 PM
I
Imp4 Offline
I
What specs does the OEM require?
What approvals does the oil carry?
If the oil meets the manufacturer specifications, then it is a good oil.
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Is Conoco-Philips FS ow20 Good Oil? [Re: Imp4] #5318749 01/10/20 02:37 PM
M
Mr_Luke Offline OP
M
Someone here said my car needs ILSAC GF5.
I'll look into the Conoco oil now.
Quote
CP reportedly makes Honda Genuine full syn for what that's worth. Part no.-9037.
Plus CP makes Motorcraft oils which seem to be highly regarded here.
Federated PG4476F
Re: Is Conoco-Philips FS ow20 Good Oil? [Re: Mr_Luke] #5318755 01/10/20 02:43 PM
L
ls973800 Offline
L
Conoco Phillips had at one time made Motorcraft oil if I recall. Not sure if they still do or not. Good oil to use regardless if they don't still supply Ford and Lincoln.
2019 Honda Pilot Touring AWD
Re: Is Conoco-Philips FS ow20 Good Oil? [Re: Mr_Luke] #5318771 01/10/20 03:00 PM
dave1251 Offline
It's a good oil just like that. Your Prius is being treated well.
don't use.
Re: Is Conoco-Philips FS ow20 Good Oil? [Re: Mr_Luke] #5318779 01/10/20 03:06 PM
I
Imp4 Offline
I
Just about every API rated SN/SN+ 0w-20 oil is also ILSAC GF5.
Take your pick.
Re: Is Conoco-Philips FS ow20 Good Oil? [Re: Mr_Luke] #5318870 01/10/20 04:25 PM
M
Mr_Luke Offline OP
M
Glad to hear it.
I swapped 3 Federated filters for my Fiesta for 3 for the Prius : the Federated PG4476F made by Premium Guard (about $2.17 each). He had one other for the same Prius, a made by Hastings for about $5 more. He showed it to me and they looked almost identical only the Federated has plastic covering the open end to keep it clean inside before you install it. They're both tiny oil filters and the one on the car now is too. It's blue and white but I can't tell what brand it is. It may be a Federated also. So in late December I guess I'll run one of these oil filters with the FS 0w20 oil of my choice.
I drove it up on ramps and looked under there.
I think it would take me about 10 minutes to change the oil & filter but I'm going to run this CP FS oil for a year.
Federated PG4476F
Re: Is Conoco-Philips FS ow20 Good Oil? [Re: Mr_Luke] #5318941 01/10/20 05:25 PM
SR5 Offline
It’s a good oil, no worries.
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
Re: Is Conoco-Philips FS ow20 Good Oil? [Re: Mr_Luke] #5318977 01/10/20 06:08 PM
T
Triple_Se7en Offline
T
Nice find Luke for your 2012. The Conoco is probably very similar to Motorcraft oil. 1Y/5K'ish OCI sounds good too.
I'm not familiar with the Federated filter. Hoping it serves you well for a year.
Keep Your Dipstick Oil Clear
19' Hyundai SantaFe 2.4 GDI - Valv Adv. 5w30 / OEM Filter
20' Kia Soul X-Line 2.0 MPI / Pennz Gold 5W30 / OEM Filter
04' Colorado 3.5 Castrol Edge 0W40 / K&N filter
Re: Is Conoco-Philips FS ow20 Good Oil? [Re: Mr_Luke] #5319920 01/11/20 03:47 PM
L
littlehulkster Offline
L
It's fine and meets all relevant specs for your engine. For what it's worth, as reliable as those are you could probably run canola oil in it and still hit 250k.
2015 Mazda3 I 2.0
