Which of the car value books are accurate ?
by WhyMe - 01/27/20 09:05 PM
Severe Service
by tiger862 - 01/27/20 08:53 PM
Platinum, Iridium, Ruthenium, oh my!
by Astro_Guy - 01/27/20 08:28 PM
Hit 200K miles today!
by SLO_Town - 01/27/20 08:20 PM
Valve Cover at 304849 miles
by Marco620 - 01/27/20 08:17 PM
Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T
by chinee - 01/27/20 07:11 PM
Quaker State deal
by JohnnyJohnson - 01/27/20 06:46 PM
A new deal on Castrol Edge EP 5W-30
by JohnnyJohnson - 01/27/20 06:37 PM
Burning smell from rear wheel
by 2010Civic - 01/27/20 06:01 PM
2017 VW Golf 1.8T - Valvoline 5w40 MST - 8,600 miles
by BurntMusic - 01/27/20 06:00 PM
Cost to rebuild a Ford 4R75E vs. new or used.
by atikovi - 01/27/20 05:26 PM
Autozone Clearance 85w140 gear oil 5 gal
by GON - 01/27/20 04:31 PM
Resonating Noise at 3000rpm
by tookien - 01/27/20 04:28 PM
Looking for Purolator Tech oil filter pics.
by Black_Thunder - 01/27/20 04:02 PM
2019 Mini Cooper Clubman S ALL4 Review
by oilpsi2high - 01/27/20 02:51 PM
The "Penny Challenge"
by ZeeOSix - 01/27/20 02:32 PM
2008 Highlander Battery Post Bolt Snapped
by maverickfhs - 01/27/20 02:31 PM
conventional wisdom rebuild axle or replace?
by NissanMaxima - 01/27/20 01:22 PM
IslandOil, 01VFR, M10, H20ham, Meletz
70544 Registered Users
110 registered members (01VFR, AdRock, 330indy, 67ZL1, 2010Civic, 2015_PSD, 12 invisible), 2,694 guests, and 18 spiders.
Topics300,653
Posts5,180,335
Members70,544
reciprocating wobbly/imbalance noise above 3000 rpm #5318613 01/10/20 11:47 AM
T
tookien Offline OP
T
2nd Gen Rav4 (2003, 2.0L vvt-i).
where the rpm is steady at 3000rpm or above, such as driving at 120km/h (75 miles/h), ,
there is a reciprocating wobbly noise, coming from the front. It's not loud, but consistent and noticeable.
under that rpm the noise is not present.
I was thinking it could be bearings related water pump, alternator etc..
I do hear a little on off screeching noise at idle that seems like it could be a bearing, and maybe at higher rpm
torque converter? the car does struggle a bit uphill. I was thinking maybe the noise is related?
These vehicles have history of ECM issues causing transmission problems (shifting etc...), but I already had the ECM fixed and don't have shifting issues. I don't think that's the problem.
Re: reciprocating wobbly/imbalance noise above 3000 rpm [Re: tookien] #5318737 01/10/20 02:21 PM
K
KGMtech Offline
K
Wheel bearing? especially if you have ever hit a curb while driving in snow. Is the noise dependent on engine RPM's or vehicle speed ?
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: reciprocating wobbly/imbalance noise above 3000 rpm [Re: KGMtech] #5318922 01/10/20 05:01 PM
T
tookien Offline OP
T
Yes, the noise depends on RPM it seem more than vehicle speed.
When it hits 3000 rpm the noise starts, usually when I'm driving consistently at 120km/h the noise is also consistent.
the wheel bearings were all replaced, the noise is definitely not the wheel bearings as I had this problem from the beginning.
Re: reciprocating wobbly/imbalance noise above 3000 rpm [Re: tookien] #5318986 01/10/20 06:15 PM
super20dan Offline
check idler pullys
99 silverado 5.3
2003 tundra v6
1981 toyota cressida wagon
2003 kia sorento
04 toyota highlander 4cyl 2013 toyota rav4
Re: reciprocating wobbly/imbalance noise above 3000 rpm [Re: tookien] #5319008 01/10/20 06:39 PM
M
mk378 Offline
M
Does revving up to 3000 in neutral with the car parked make the noise?
If not, the next test would be to get going 75 mph then shift to neutral and let the engine idle and see if the noise stops.
Re: reciprocating wobbly/imbalance noise above 3000 rpm [Re: mk378] #5319201 01/10/20 10:53 PM
T
tookien Offline OP
T
Thanks. I will check that out.
Re: reciprocating wobbly/imbalance noise above 3000 rpm [Re: super20dan] #5319202 01/10/20 10:54 PM
T
tookien Offline OP
T
Originally Posted by super20dan
check idler pullys
Thanks will check that too.
