Are all 9012 bulbs HIR2?
by dvancleve - 01/18/20 03:30 PM
Ariens L-3 Synthetic Severe-Duty Gear Lube
by Astro_Guy - 01/18/20 02:04 PM
LSx Crank lock
by P10crew - 01/18/20 02:03 PM
ST9688 gasket
by Farnsworth - 01/18/20 01:26 PM
From my stash
by Fattylocks - 01/18/20 12:48 PM
Toyota to Mexico
by kstanf150 - 01/18/20 12:37 PM
Final Sludge Cleanup, HDEO - Diesel ??
by jssaab - 01/18/20 12:31 PM
A good cabin filter
by NH73 - 01/18/20 10:36 AM
K&N cut open.
by laserred96gt - 01/18/20 10:25 AM
Toyota Oem filter mileage
by Bettez88 - 01/18/20 10:22 AM
OCI, Owners manual versus oil Mfg.
by VQLT - 01/18/20 10:06 AM
MacBook Pro to Microsoft Surface
by Kira - 01/18/20 09:53 AM
Ford 5R55E Auxiliary Transmission Filter
by benjamming - 01/18/20 09:33 AM
Do all synthetic oils act as a cleaner?
by Loobit - 01/18/20 08:26 AM
Mobil 1 ESP now sold in 5qt jugs
by Patman - 01/18/20 08:12 AM
Mobil 1 Extended Performance Oil Filters
by jrommelt - 01/18/20 08:08 AM
These the same?
by Bettez88 - 01/18/20 06:53 AM
MaxLife SB 10w40 on Sale
by Mad_Hatter - 01/18/20 04:27 AM
Bebo77, 2EHA, jonnyb433, kzbd, 54Robert
70465 Registered Users
80 registered members (55hambone, 69Torino, 2oldtommy, 14Accent, 77GrandPrix, 8 invisible), 2,254 guests, and 18 spiders.
Topics300,290
Posts5,172,566
Members70,465
Most Online3,728
Jan 11th, 2020
Whole house surge protector legit? #5318548 01/10/20 10:15 AM
J
jayjr1105 Offline OP
J
https://www.homedepot.com/p/Square-...rge-Protective-Device-QO2175SB/100202111
Our house and 90% of US is littered with electronics. Are these whole house surge protectors worth it?
I will soon have a void in my panel when I switch an electric range to a gas one so this will fill that void nicely.
2013 Mazda 3 - PP 0w20
2005 Honda Odyssey - PP HM 5w20
Re: Whole house surge protector legit? [Re: jayjr1105] #5318554 01/10/20 10:25 AM
Cujet Offline
I live in South Florida, AND my house backs up to the NENA area (north east everglades natural area) Everglades in Jupiter. As such, we get lightning strikes galore. As the lightning avoids the water and hits my house.
There are various surge protectors available. The link shows one in the 20kv range. That's pretty low.
Unfortunately, the larger and more capable ones will not shunt a minor surge.
Sooooo, I have both a small one and a large one, on the advice of local electricians.
The best choice might be a professional grade unit that covers all ranges effectively, along with 2 grounding rods at least 10 feet apart.
The Seimens FS140 has a great reputation, if you can get your hands on one.
https://www.amazon.com/Siemens-FS14...&hvtargid=pla-315970290468&psc=1
OH, and follow the directions carefully. The wiring MUST NOT have sharp bends in it. As a true lightning strike will jump right out of the ground wire at the bend.
Re: Whole house surge protector legit? [Re: Cujet] #5318561 01/10/20 10:36 AM
Donald Online Content
Online Content
Whats the price on the professional ones?
2015 Ford F-250 w/Powerstroke
Re: Whole house surge protector legit? [Re: Donald] #5318588 01/10/20 11:08 AM
N
nickaluch Offline
N
I don't know if there legit but from my experience I would say yes. When I finished my basement I installed one on my panel while I was running the electric. During and after super storm Sandy we were getting electric spikes and on and off constantly. Everything in my house was fine afterwards my neighbors not so lucky. Everyone lost a board or two on there appliances even a few TV's. My one neighbor the board on his furnace was fried $900 repair. So I do recommend just spend a little more money on a better one. You don't need a super expensive one since you live in PA. If you lived in FL I would recommend you follow Cujet advise.
2007 G6 beater.2012 E450 box truck. 2018 Chevy Traverse.2017 E450 box truck.2017 Chevy 3500 extend cargo van.
Re: Whole house surge protector legit? [Re: jayjr1105] #5318604 01/10/20 11:40 AM
SubieRubyRoo Offline
And don't skimp on the wire to the grounding rods! In this case, bigger is always better.
Re: Whole house surge protector legit? [Re: Cujet] #5318607 01/10/20 11:45 AM
There's a reason basic electrical training teaches current similar to the amount of flow of water out of a hose, and voltage as the pressure. Some estimates consider lightning bolts to be around 1 BILLION volts... so a parallel is even 480V is roughly 2 million times less than lightning, meaning your water analogy of roughly 45psi of tap water would become roughly 93 MILLION psi.... hence why it despises sharp bends and blows right through the insulation. Smooth flow is always better/safer! Also always keep the ground runs as short as possible, no longer than necessary.
Re: Whole house surge protector legit? [Re: SubieRubyRoo] #5318626 01/10/20 12:09 PM
J
J
My area just requires a single rod near the meter outside with #6 solid copper. On top of that a #8 is required to the incoming water line.
Re: Whole house surge protector legit? [Re: jayjr1105] #5318627 01/10/20 12:09 PM
K
Kestas Online Content
Global Moderator
Online Content
Global Moderator
K
As I understand it, the whole house surge suppressors will filter out any voltage spikes going into the house. The house itself can generate voltage spikes. Additional surge suppressors may be needed immediately before any electronic equipment.
Re: Whole house surge protector legit? [Re: jayjr1105] #5318629 01/10/20 12:15 PM
SLO_Town Offline
When we bought a brand new house and lived briefly in Colorado Springs, CO (lots of lightning), I had the electrical utility come out and install a whole house surge protector. It actually tied into the main wires upstream from the circuit breaker box. It was a substantial piece of kit, not the simple thing you show on Amazon. I paid for it via a surcharge on our monthly electric bill.
FWIW,
Scot
03 BMW E46 330Ci ZSP (BMW TPT 5W-30)
10 Honda Element SC (Castrol Magnatec 5W-30)
11 BMW E90 328i M-Sport (Pennzoil Euro 5W-40)
16 VW Passat VR6 3.6L SEL Premium (Euro Castrol 0W-40)
Re: Whole house surge protector legit? [Re: SLO_Town] #5318634 01/10/20 12:32 PM
J
J
FWIW,
Scot
What you're describing is pretty much the same thing but beefier which requires it be installed in a box adjacent to the panel.
Re: Whole house surge protector legit? [Re: jayjr1105] #5318641 01/10/20 12:39 PM
M
MasterSolenoid Offline
M
I have a Whole House Surge Protector wired into the Circuit Breaker Box (Siemens) did it myself.
My neighbor lost a TV once.
Installing was a nice Winter project.
For any surges that originate inside the house (from any motor turning ON) I plug my electronics into separate Surge Protectors (bought at any big box store).
[Linked Image]
2002 Ford Ranger / bought new
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Whole house surge protector legit? [Re: jayjr1105] #5318645 01/10/20 12:43 PM
4
440Magnum Offline
4
I would say they're "legit," after all the link is a reputable brand (Square-D) and the engineering of surge protection isn't exotic. But you have to remember that surge protection in all forms is a bit of a statistical gamble. Surges come in different forms with different peak voltages, different pulse widths, some are oscillations, some are more DC pulses, some are due to equipment on the power grid itself, (a substation dropping a big branch line can put a surge on the lines that aren't dropped, for example), and some are external like lightning strikes. A protector can only do so much, it can't really guarantee that no abnormal voltage pattern get through... it just decreases the odds of damage. And many surge protection devices do so by taking on damage themselves, so they have to be replaced after doing their job.
What I've chosen to do is put individual smaller surge protectors on my devices that are either high value or high sensitivity... things like the main computer, the TV, the expensive fridge with an electronic brain and variable-frequency drive compressor, etc. In other words, I let the lower-value stuff on my home power grid (old style more rugged motors, light bulbs, resistive loads etc.) take some of the brunt of surges and let the point-of-use protectors "clean up" whatever is left over right at the device to be protected.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
Re: Whole house surge protector legit? [Re: jayjr1105] #5318658 01/10/20 12:58 PM
N
NO2 Offline
N
No surge protector will stop a direct lightning strike. I would just install local ones on your electronics and appliances. For most places, brownouts are more of an issue.
Re: Whole house surge protector legit? [Re: NO2] #5318756 01/10/20 02:46 PM
J
J
I do have surge protectors on most expensive electronics and I agree with the direct lightning strike thing. When I replace my stove with Gas, I'll have 2 spots open on my panel. This will fill that gap nicely and possibly save some electronics down the road from a surge.
Re: Whole house surge protector legit? [Re: jayjr1105] #5318843 01/10/20 04:07 PM
F
Fitter30 Offline
F
I'm in a very rural area have overhead lines. Telephone is buried 1/4 mile to house. Have that style of protection at panel and use surge protection strips at all electronic devises and on my cordless landline use surge on the phone line since in 14 years have loss 10 cordless phones from lighting but since adding surge protection on phone wire survived at least two lighting strikes close to the house.
