3 Fram Ultra's Cut Open
by jetman - 01/20/20 10:31 AM
Standard Cab Commercial
by Duffyjr - 01/20/20 10:17 AM
The thin grease for firearms
by fnbrowning - 01/20/20 10:07 AM
Replace coil packs with spark plugs?
by jayjr1105 - 01/20/20 09:34 AM
Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
Oil ideas for 2 v6 fords and more
by kessellrun - 01/20/20 06:50 AM
Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
FCA and Foxconn partner on EV's
by OVERKILL - 01/19/20 08:55 PM
IIHS Crash pics of Full Size Trucks
by kstanf150 - 01/19/20 08:15 PM
Are Engine Splash Guards Really Needed?
by Mr_Luke - 01/19/20 08:14 PM
supertec cartridge filters
by super20dan - 01/19/20 06:17 PM
More Valvoline on rollback at WM
by jayjr1105 - 01/19/20 06:13 PM
Crossed poles on jumper cables
by 3Aone - 01/19/20 05:33 PM
RSH, Bobjr94, GarageKings, JohnnyD1980, Harry_Seaward
70487 Registered Users
111 registered members (69GTX, 1978elcamino, 2011335d, 14Accent, 66ROGUE, 65convertible, 7 invisible), 2,686 guests, and 39 spiders.
Topics300,347
Posts5,173,826
Members70,487
Most Online3,825
Jan 19th, 2020
2018 RAM 2500 transfer case fluid options? #5318316 01/09/20 11:53 PM
Dragon44 Offline OP
The manual says use Mopar Borg-Warner 44-44 fluid for the T-case. I'm wondering is there any other options for it? Is it just another name for ATF-4 fluid so you have to buy MOPAR fluid? Thanks for your help.
Re: 2018 RAM 2500 transfer case fluid options? [Re: Dragon44] #5318336 01/10/20 01:20 AM
B
BrianF Online Content
Online Content
B
The HD trucks do not have an auto 4wd features they done require that mystery fluid. Just use a decent Atf. I am running a thicker 7.7cSt group 4 atf+4 compatible fluid in mine. Runs as good as it did before.
2006 Trailblazer LT. QSUD, Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30, Baldwin BT7349.
1993 GMC 1500. QSAD, Fram PH5
Re: 2018 RAM 2500 transfer case fluid options? [Re: Dragon44] #5318388 01/10/20 05:09 AM
Snagglefoot Offline
The owners manual says for towing, change every 60,000 miles. I couldn’t find the capacity but one Ram site said 3 pints, (less than two quarts.)
The Amsoil vehicle look-up said use Amsoil Mult-vehicle, ATF but also listed every Tom, Dick and Harry car maker and transmission.
So, basically 2 quarts every 60,000 miles. The Ram manual suggests ATF +4 for the six speed automatic transmission but not the transfer case. I wonder why. I’ll pick door #2. Mopar BW 44-44. Report back in 200,000 miles. smile
If you want the job done right......do it yourself.
Re: 2018 RAM 2500 transfer case fluid options? [Re: Dragon44] #5318547 01/10/20 10:14 AM
J
JTK Online Content
Online Content
J
If you really want to go down the BW44-44 rabbit hole, search the other 44-44 threads here. My 2017 Ram 1500 pentastar also uses the BW44-44. It's recommended you only use the $30/qt Mopar 44-44 fluid. Not ATF. I don't necessarily believe this, but that's what the OM says.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: 2018 RAM 2500 transfer case fluid options? [Re: JTK] #5318621 01/10/20 12:02 PM
P
panthermike Offline
P
Rabbit hole for sure! I'll use the 44 fluid in mine, expensive but infrequent luckily. There's just not alot of literature out there at all
'17 Armada Platinum; RGT 0w20, 52K
'19 Ram 1500; RGT 5w20, 15K
'70 F100; Valvoline 15w40
Biotech For All
Re: 2018 RAM 2500 transfer case fluid options? [Re: Dragon44] #5321499 01/13/20 11:38 AM
Hootbro Offline
Yeah, stick to the MOPAR OEM Jesus Juice for the BW 44-44. If it was a BW-44-45 chain driven transfer, you can get away with ATF+4 or other transfer case specific universal fluids like the one Valvoline offers.
Like others mentioned, it is a rabbit hole to go down trying to find a direct compatible fluid for the MOPAR OEM fluid for the BW 44-44 and you will not get anything remotely specific other than generality statements and unproven anecdotal statements for other fluids.
2020 Jeep Gladiator Rubicon 3.6L (Dealer Bulk 0W-20)
2017 Jeep Renegade Latitude 2.4L (Idemitsu 0W-20)
2013 Volkswagen Jetta 2.5L (Havoline HM 5W-30)
Re: 2018 RAM 2500 transfer case fluid options? [Re: Dragon44] #5322498 01/14/20 02:06 PM
dave1251 Offline
I have not seen any recommendations from companies for any fluid recommendation. Thus I conclude just use the Mopar fluid.
don't use.
Re: 2018 RAM 2500 transfer case fluid options? [Re: Dragon44] #5322595 01/14/20 03:39 PM
H
Harley Anderson Offline
H
Just wanted to post, I have 152k on my 14 2500 and used Amsoil ATF since 30k. Changed it 3 times total. I will continue to use the ATF. Sorry I know this doesn't help, but just about everyone I know runs ATF in the transfer case just like the old NVG273.
2014 Ram 2500, 5.7, 66rfe
2015 Honda Accord I4
