Duralast Max Ceramic Pads Photos!
by NASTI - 01/20/20 11:23 AM
expensive rotors
by Donald - 01/20/20 11:19 AM
3 Fram Ultra's Cut Open
by jetman - 01/20/20 10:31 AM
Standard Cab Commercial
by Duffyjr - 01/20/20 10:17 AM
The thin grease for firearms
by fnbrowning - 01/20/20 10:07 AM
Replace coil packs with spark plugs?
by jayjr1105 - 01/20/20 09:34 AM
Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
Oil ideas for 2 v6 fords and more
by kessellrun - 01/20/20 06:50 AM
Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
FCA and Foxconn partner on EV's
by OVERKILL - 01/19/20 08:55 PM
IIHS Crash pics of Full Size Trucks
by kstanf150 - 01/19/20 08:15 PM
Are Engine Splash Guards Really Needed?
by Mr_Luke - 01/19/20 08:14 PM
supertec cartridge filters
by super20dan - 01/19/20 06:17 PM
RSH, Bobjr94, GarageKings, JohnnyD1980, Harry_Seaward
70487 Registered Users
104 registered members (aquariuscsm, 1978elcamino, Anthony, 2015_PSD, AlienBug, 2011335d, 8 invisible), 2,968 guests, and 28 spiders.
Topics300,349
Posts5,173,896
Members70,487
Most Online3,825
Jan 19th, 2020
Def fluid in 2015 PSD & winter #5318241 01/09/20 09:43 PM
Donald Offline OP
I have not be able to figure out if there is a DEF fluid heater that runs when the truck is off. DEF can freeze so what happens overnight when it's 10F outside?
I know the manual it says not to add DEF fluid in the winter and then shut-off the truck.
The DEF fluid pump at the truck stop has a quilted blanket all around the pump with a flap you can open to remove the nozzle. So people obviously work about it freezing.
I would think the vehicle battery would discharge in a few days in the winter if battery power was used to run the DEF fluid heater when the truck is off.
2015 Ford F-250 w/Powerstroke
Re: Def fluid in 2015 PSD & winter [Re: Donald] #5318249 01/09/20 09:55 PM
P10crew Offline
Donald when my 2015 psd was brand new it threw a code that when ford checked it out def heater failure.
They were on national back order. I just drove it and am still driving it with supposedly no def heater.
Winters are brutal at times here and no problems so far with def @110,000 miles . Everything else has happened to the drive train of this joke but not def related.
Re: Def fluid in 2015 PSD & winter [Re: Donald] #5318397 01/10/20 05:42 AM
R
roadrunner1 Offline
R
No DEF heat when truck isn’t running. My ‘15 is currently at 125,000 mi., trouble-free.
'15 F350 6.7
Re: Def fluid in 2015 PSD & winter [Re: Donald] #5318436 01/10/20 07:09 AM
T
themaxx Offline
T
Can't comment on the Ford system specifically, but the DEF systems I've seen on equipment have some sort of heating system that operates when the equipment or truck is running. It may be electric or engine coolant heated.
Keep in mind that the DEF is an aftertreatment. The engine does not need it to run. Yes the DPF will get dirtier faster without it, but the short time between startup and DEF thaw shouldn't contribute to that much.
Someone check me if I'm wrong here.
Re: Def fluid in 2015 PSD & winter [Re: themaxx] #5318447 01/10/20 07:22 AM
B
BMWTurboDzl Offline
B
You're basically correct in that they're all designed to warm the DEF in some way. I can't think of how it would impact DPF loading since it's upstream of the SCR (DEF Injection). EGR -.> DPF ->> SCR--> Tailpipe.
435i
Re: Def fluid in 2015 PSD & winter [Re: Donald] #5318459 01/10/20 07:46 AM
Chris142 Offline
It may circulate it through a heat exchanger.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Def fluid in 2015 PSD & winter [Re: Donald] #5318746 01/10/20 02:36 PM
R
roadrunner1 Offline
R
Ford uses an electric heater within the DEF tank on the 6,7
'15 F350 6.7
Re: Def fluid in 2015 PSD & winter [Re: Donald] #5318773 01/10/20 03:00 PM
E
edyvw Offline
E
No heat if it is not running. Now, in heavier equipment there are coolant lines too, so they postpone coolng off of DEF. Not sure whether heavy equipment has heater that runs when needed if engine off.
Electric heater in tank is known issue in early SCR systems as most vehicle manufacturers were using BOSCH supplied heater. DEF is good to 12f, and 10f outside should not create too much of an issue. However, droppoing further might. But as someone mentioned, engine does not need DEF to run, and manufacturers took that into consideration.
ON BMW X5 35d I had there were two DEF tanks. One, so called active had DEF heater and stored 1.6 gallons of DEF, second was passive tanks storing 5.4 gallons of DEF, but no heater. I drove and park car as low as -37f, never had issue due to cold temperature. Heating unit on other hand was problematic and failed once during summer.
11' BMW 328i xDrive 6MT (BMW TPT 5W30+OE filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: Def fluid in 2015 PSD & winter [Re: Donald] #5319074 01/10/20 07:57 PM
B
BBDartCA Offline
B
There are a variety of strategies to manage DEF freezing. Firstly, from a regulatory standpoint, the vehicle must inhibit operation (obviously usually starting), if DEF is frozen (there are a variety of ways to monitor this). The methods of maintaining DEF temperatures include a combination of heated Def lines, heating tanks electrically or with engine coolant. Plus there is (under interpretation) some allowance for startup without DEF system fully fault checked.
https://www.govinfo.gov/content/pkg/FR-2014-08-08/pdf/2014-18738.pdf#page=17
Former lube industry insider...now vehicle OEM engineering insider.
Re: Def fluid in 2015 PSD & winter [Re: Donald] #5319080 01/10/20 08:10 PM
Skippy722 Offline
My buddies DEF froze on him over night, and it started a countdown in miles till he was limited to 5mph. Ended up causing a fairly significant amount of damage. It was -5F out though.
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Def fluid in 2015 PSD & winter [Re: Donald] #5319114 01/10/20 09:05 PM
P10crew Offline
Skippy I’ve been in -35 with no problems. Who even knows if my heater is working or not? Our F dealer here is the biggest bunch of bozos I’ve ever seen. I know for a fact that the service manager that I have been forced to talk to on several occasions was convicted of embezzlement at his previous job. There is NO hope here. Junk!
