Has anyone tinted a dash cluster?
by Vern_in_IL - 01/25/20 08:40 AM
Coolant flush machines
by Donald - 01/25/20 08:24 AM
How do you scratch the new car itch?
by supton - 01/25/20 08:07 AM
2019 f550 6.7
by ame299 - 01/25/20 07:49 AM
unthinkable problem after oil change
by NH73 - 01/25/20 07:37 AM
Anybody burn wood for heat? Advice please.
by dlundblad - 01/25/20 07:21 AM
2002 cummins
by coondog - 01/25/20 07:07 AM
New Mercedes Ute
by Shannow - 01/25/20 03:04 AM
A decent battery charger for sub $50?
by michaelluscher - 01/25/20 02:03 AM
Temperature swing affects on oil
by leeaspell - 01/25/20 12:58 AM
Coefficient of Friction
by jrommelt - 01/24/20 11:46 PM
2017 Chevy Cruze Diesel Oil
by Ponch - 01/24/20 11:03 PM
electric motor amp rating
by motor_oil_madman - 01/24/20 10:42 PM
Radio, Instrument panel, display, AC cutting off
by DrDanger - 01/24/20 09:39 PM
Filter Brand Quality Change?
by BBDartCA - 01/24/20 09:21 PM
Autozone $7 off $30
by GMguy84 - 01/24/20 09:17 PM
Honda Power Steering Fluid
by shortlid - 01/24/20 09:14 PM
Autozone Clearance 2020 M1EP
by GMguy84 - 01/24/20 09:11 PM
M635_Guy, ame299, Whoop, coondog, steelbeams
70523 Registered Users
93 registered members (AandPDan, 53' Stude, alarmguy, A310, 77GrandPrix, 7 invisible), 2,581 guests, and 17 spiders.
Topics300,526
Posts5,177,769
Members70,523
ZF Lifeguard 8,VW Amarok, 8HP45 transmission #5318144 01/09/20 08:18 PM
H
Hendo Offline OP
H
2014 VW Amarok, 225K kms. Ute has done a fair bit of towing, glad I changed the oil!
It's supposed to be "lifetime fill" but this is most certainly not the case in this application. Trans holds 9L of oil but only 5 came out, (rest is in the torque converter) so I'm considering changing it again to further dilute the contaminants that are left.
Amaroks use an alloy pan and separate filter (which I haven't changed) but after this report I think I'll drop the pan. Thoughts?
[Linked Image]
Re: ZF Lifeguard 8,VW Amarok, 8HP45 transmission [Re: Hendo] #5318258 01/09/20 10:15 PM
wwillson Online Content
Administrator
Online Content
Administrator
There is a Youtube video that has been posted here where two ZF engineers are discussing fluid changed intervals in this transmission. They state passionately to never under any circumstances run the fluid for more than 60,000 miles.
Re: ZF Lifeguard 8,VW Amarok, 8HP45 transmission [Re: Hendo] #5318340 01/10/20 01:46 AM
dave1251 Offline
It's a lifetime fluid. The AT lifetime. What fluid did you replace this with?
don't use.
Re: ZF Lifeguard 8,VW Amarok, 8HP45 transmission [Re: Hendo] #5318370 01/10/20 04:30 AM
demarpaint Offline
I always laugh when I hear the term "lifetime fluid" smart move changing it! Yes, I would do the pan drop too. I have no clue why they made the filter part of the pan, either way I'd be changing it if I were you.
God Bless Our Troops
Re: ZF Lifeguard 8,VW Amarok, 8HP45 transmission [Re: wwillson] #5318435 01/10/20 07:07 AM
B
BMWTurboDzl Offline
B
OP: ZF recommends a pan drop approx every 100,000 KM or 8 yrs for vehicles under severe service (ex, towing, high speed driving) otherwise the fill is lifetime. Your application obviously qualifies for severe service and you went over twice the mileage before having an oil change performed.
435i
Re: ZF Lifeguard 8,VW Amarok, 8HP45 transmission [Re: BMWTurboDzl] #5318511 01/10/20 09:03 AM
F
Fraser434 Offline
F
Correct, ZF put in documents they recommend fluid change at 60,000 miles (100,000 km) or after the manufacture warranty has expired.
Have a ZF 8HP70 in my Jeep Grand Cherokee, similar to the OP's ZF, changed the fluid at 90k miles(144k km) with Valvoline Maxlife, drain and fill, have to follow the steps in the checking the level. Maxlife fluid has 'Lifeguard 8' fluid on the list of compatible fluids.
Valvoline Information sheet:
https://sharena21.springcm.com/Publ...bd3/3fa3136a-09bd-e711-9c12-ac162d889bd1
Re: ZF Lifeguard 8,VW Amarok, 8HP45 transmission [Re: Fraser434] #5318529 01/10/20 09:40 AM
B
BMWTurboDzl Offline
B
Ya. I changed the ATF on my 8HP (BMW 435i) at 55k miles but used ZF LG8 because I'm somewhat OC.
435i
Re: ZF Lifeguard 8,VW Amarok, 8HP45 transmission [Re: Hendo] #5318815 01/10/20 03:40 PM
7
750IX Offline
7
Flush and filter twice, every 40.000 miles. Bmw 750, ZF 8hp70. First time i used lifeguard 8, this time i used Ravenol 8HP.
Here is what FCP Euro write about ZF in Bmw`s:
"Here at FCP Euro, we have an extremely close relationship with ZF, who is the supplier of 6HP and 8HP transmissions to BMW. BMW rates these transmissions for a "lifetime fill," however, through our channels at ZF and speaking with the engineers of those transmissions, we've learned that the transmissions are tested to 100,000 miles with an "acceptable rate of failure" on the original fill. 100,000 miles is BMW's definition of what a "lifetime fill" and that's passed the extended warranty and "good-will" repair limit, meaning a failure after that is no longer BMW's responsibility. In the case of the 6HP/8HP, ZF actually has a published service interval for those transmissions which completely contradicts BMW's service information with an interval of 8 years/80,000km (~50,000 miles). This information supersedes BMW's "lifetime fill" rating"
https://blog.fcpeuro.com/bmw-lifetime-transmission-fluid-isnt-lifetime.
Re: ZF Lifeguard 8,VW Amarok, 8HP45 transmission [Re: demarpaint] #5327474 01/19/20 11:04 PM
H
Hendo Offline OP
H
I used this oil- It's only available in AUS i believe.
http://www.anglomoil.com/wp-content/uploads/AutoTransmission-Type-MV-Lo-Visc-2018-07-30.pdf
luckily for me the amarok ZF uses an alloy pan and a replacable filter, so I'll replace that and drop another 5L of oil out.
NB they hold 9L of oil but a change will only release 5L, so half those wear metals are still in it. The torque converter and oil cooler hold the other 4L
