Originally Posted by ad244
Hi BITOG users,
Anybody using straight 30wt in hotter climates n their passenger vehicles? - I'm talking the greater CA/AZ area where temps rarely dip into freezing temps. Would a vehicle which is spec'd for 5w-30 have any issues with this?
Thanks!
Let's see... Zero manufacturers recommend a straight weight oil.
You will gain zero by running a straight weight oil.
If you would choose to do so anyway, I would ask you why you'd choose to switch from a multi-weight oil.
Is your multi-weight oil not performing adequately?
Is the multi-weight oil the OEM recommends not performing adequately???
I can only imagine the answer is a resounding no.
Reality is, you're not 'smarter' than others by selecting a straight weight oil.
You're not more 'in the know' either.
And the straight weight won't do anything that the OEM multi-weight is not already accomplishing.
And no, the fact that the straight weight may be more resistant to shearing out of grade is does not make it a better choice because the only thing that is important is the there is enough shear stability in the oil and a multi-weight oil will definitely provide that.
It may be an interesting thought experiment and it may indeed work for the application, but it is definitely not 'better'.
To your original question, who knows if it would have any issues. I'm sure you'll hear from several here whose Grandpa ran is in his '53 Ford pickup for years.
Give it a whirl and report back in 5 years or so.
Good luck!!!
