Severe Service
by tiger862 - 01/27/20 08:53 PM
Platinum, Iridium, Ruthenium, oh my!
by Astro_Guy - 01/27/20 08:28 PM
Hit 200K miles today!
by SLO_Town - 01/27/20 08:20 PM
Valve Cover at 304849 miles
by Marco620 - 01/27/20 08:17 PM
Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T
by chinee - 01/27/20 07:11 PM
Quaker State deal
by JohnnyJohnson - 01/27/20 06:46 PM
A new deal on Castrol Edge EP 5W-30
by JohnnyJohnson - 01/27/20 06:37 PM
Burning smell from rear wheel
by 2010Civic - 01/27/20 06:01 PM
2017 VW Golf 1.8T - Valvoline 5w40 MST - 8,600 miles
by BurntMusic - 01/27/20 06:00 PM
Cost to rebuild a Ford 4R75E vs. new or used.
by atikovi - 01/27/20 05:26 PM
Autozone Clearance 85w140 gear oil 5 gal
by GON - 01/27/20 04:31 PM
Resonating Noise at 3000rpm
by tookien - 01/27/20 04:28 PM
Looking for Purolator Tech oil filter pics.
by Black_Thunder - 01/27/20 04:02 PM
2019 Mini Cooper Clubman S ALL4 Review
by oilpsi2high - 01/27/20 02:51 PM
The "Penny Challenge"
by ZeeOSix - 01/27/20 02:32 PM
2008 Highlander Battery Post Bolt Snapped
by maverickfhs - 01/27/20 02:31 PM
conventional wisdom rebuild axle or replace?
by NissanMaxima - 01/27/20 01:22 PM
will a thermostat gasket leak coolant into the engine?
by motor_oil_madman - 01/27/20 12:55 PM
IslandOil, 01VFR, M10, H20ham, Meletz
70544 Registered Users
135 registered members (01VFR, 4WD, 2015_PSD, 2003f7, 2009Edge, 330indy, 10 invisible), 3,267 guests, and 24 spiders.
Topics300,653
Posts5,180,312
Members70,544
Page 1 of 3 1 2 3
Briggs motor only runs on choke #5318035 01/09/20 06:32 PM
Cowboy35 Offline OP
Lawnmower will only run on choke, took the brand new carb and cleaned it, not a thing wrong with it. Getting plenty if fuel to the carb. Adjusted valves, check compression, checked for spark, all good. Anything else I can check that I'm missing. Thanx
Re: Briggs motor only runs on choke [Re: Cowboy35] #5318041 01/09/20 06:36 PM
E
Eddie Offline
E
Bad carb to engine gasket?
2014 CX5 Touring 2.5L :-)
Re: Briggs motor only runs on choke [Re: Cowboy35] #5318043 01/09/20 06:37 PM
T
tundraotto Offline
T
Too small a jet in the carb or dirt in it.....just buy a new cheap replacement carb.
Re: Briggs motor only runs on choke [Re: Eddie] #5318047 01/09/20 06:39 PM
Cowboy35 Offline OP
Gaskets are in good shape.
Re: Briggs motor only runs on choke [Re: tundraotto] #5318048 01/09/20 06:39 PM
T
tig1 Offline
T
Why not clean the jet instead?
2007 Ford Fusion 252,000 miles
M1 5-20HM
2017 Ford Fusion 85K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: Briggs motor only runs on choke [Re: tundraotto] #5318052 01/09/20 06:39 PM
Cowboy35 Offline OP
It is a brand new carb, I couldnt find anything wrong it
Re: Briggs motor only runs on choke [Re: tig1] #5318057 01/09/20 06:43 PM
Cowboy35 Offline OP
Went through the carb completely with carb cleaner, all jets clean.
Re: Briggs motor only runs on choke [Re: Cowboy35] #5318062 01/09/20 06:49 PM
P10crew Online Content
Online Content
Not sure what vintage it is but on the side of the carb there is a small plate held on by 3 or 4 screws there is a diaphragm and a spring under that plate. Your diaphragm is shot. Replace it.
The diaphragm is your fuel pump.
Re: Briggs motor only runs on choke [Re: Cowboy35] #5318067 01/09/20 06:54 PM
J
JLawrence08648 Offline
J
Bad carb
Re: Briggs motor only runs on choke [Re: tig1] #5318070 01/09/20 06:56 PM
T
tundraotto Offline
T
because fully cleaning the carb - esp diaphgram is a pain, and often not successful - and a new carb is about the same price as a carb kit.
Depends on how sentimental you are about the carb that doesn't work I guess.
Re: Briggs motor only runs on choke [Re: P10crew] #5318074 01/09/20 06:57 PM
Cowboy35 Offline OP
Ok I will have to check that, dont remember seeing anything like that but I could be wrong.
Re: Briggs motor only runs on choke [Re: Cowboy35] #5318080 01/09/20 07:04 PM
Online Content
[Linked Image]
Re: Briggs motor only runs on choke [Re: Cowboy35] #5318087 01/09/20 07:08 PM
Cowboy35 Offline OP
I was wrong the motor is actually considered a MTD motor. Carb has nothing like that on the side of it, tell u the truth I dont even know where the diaphragm is on this carb.
Re: Briggs motor only runs on choke [Re: Cowboy35] #5318091 01/09/20 07:11 PM
Online Content
Well ok then.
The symptom that you have described is exactly that of a shot diaphragm .
Re: Briggs motor only runs on choke [Re: Cowboy35] #5318093 01/09/20 07:12 PM
E
eljefino Offline
E
Get a drill kit like this one and find the bit that fits. Then run the next bigger one through your main jet. If you notice an improvement but it's still not great, do it again!
I had to do this to a brand new carb I put on a briggs generator I got at the dump. Sometimes carbs are, well, universal, and don't do well with our lean running E10 gas.
Page 1 of 3 1 2 3
