75w140?
by mpack88 - 01/18/20 06:00 PM
Are all 9012 bulbs HIR2?
by dvancleve - 01/18/20 03:30 PM
Ariens L-3 Synthetic Severe-Duty Gear Lube
by Astro_Guy - 01/18/20 02:04 PM
LSx Crank lock
by P10crew - 01/18/20 02:03 PM
ST9688 gasket
by Farnsworth - 01/18/20 01:26 PM
From my stash
by Fattylocks - 01/18/20 12:48 PM
Toyota to Mexico
by kstanf150 - 01/18/20 12:37 PM
Final Sludge Cleanup, HDEO - Diesel ??
by jssaab - 01/18/20 12:31 PM
A good cabin filter
by NH73 - 01/18/20 10:36 AM
K&N cut open.
by laserred96gt - 01/18/20 10:25 AM
Toyota Oem filter mileage
by Bettez88 - 01/18/20 10:22 AM
OCI, Owners manual versus oil Mfg.
by VQLT - 01/18/20 10:06 AM
MacBook Pro to Microsoft Surface
by Kira - 01/18/20 09:53 AM
Ford 5R55E Auxiliary Transmission Filter
by benjamming - 01/18/20 09:33 AM
Do all synthetic oils act as a cleaner?
by Loobit - 01/18/20 08:26 AM
Mobil 1 ESP now sold in 5qt jugs
by Patman - 01/18/20 08:12 AM
Mobil 1 Extended Performance Oil Filters
by jrommelt - 01/18/20 08:08 AM
These the same?
by Bettez88 - 01/18/20 06:53 AM
Bebo77, 2EHA, jonnyb433, kzbd, 54Robert
70465 Registered Users
105 registered members (aircooled, Alfred_B, bdcardinal, 53' Stude, Bailes1992, 10 invisible), 2,095 guests, and 18 spiders.
Topics300,290
Posts5,172,590
Members70,465
Most Online3,728
Jan 11th, 2020
Tire Shop Says All Sensors Bad. #5317740 01/09/20 01:48 PM
J
john_pifer Offline OP
J
TPMS Light started flashing on my 2007 Tacoma (flashes after startup and eventually lights up solid). From research, this is an indication that one or more of the TPMS sensors are bad, or have dead batteries.
This is the first time this has happened.
I went across the street to Discount Tire, and the kid walked out with some sort of scanner that he held near each wheel, including the spare.
He said that the two left tires’ sensors are dead, and the other three have “weak batteries”.
When I called, I was quoted $60 to replace one sensor. After he told me they all needed replacing, he said he’d “cut me a deal” and do them all for $45/ea.
I said nah, let’s not worry about it right now (I let them mount/balance the fiancee’s winter tires while I was there).
So, I was just a little skeptical that they’d all fail at once, and wondering if anyone knows if there’s any way I can independently verify this. Auto parts stores can’t scan for this, can they?
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 223K
18 Civic HB 1.5T 6MT (Fiancee's) - Edge 0W-20, OEM filter
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
Re: Tire Shop Says All Sensors Bad. [Re: john_pifer] #5317742 01/09/20 01:51 PM
Duffyjr Offline
At 12 years old it's possible they are all going bad, I have a 2008 and had my first bad one about a year ago. $45 a piece is not bad, I think I paid $35 at wally.
89 GMC Sierra Advanced 5w30/51036 Wix
08 Lucerne CX Advanced 5w30/1040 Gold
18 Toro Super Recycler T5 10w30
Re: Tire Shop Says All Sensors Bad. [Re: john_pifer] #5317743 01/09/20 01:52 PM
slacktide_bitog Online Content
Online Content
They were installed at the same time, have the same lifespan, and were used in the same conditions. It makes sense for more than one to go at the same time or close smile
You might as well replace the sensors every time you get new tires. But since you have a 2007, they're not actually required (law only applies to 2008 and up). So you could just pull the bulb and don't worry about eh sensors ontome
Re: Tire Shop Says All Sensors Bad. [Re: slacktide_bitog] #5317744 01/09/20 01:54 PM
J
J
I need to call NTB, where I bought the tires and had them mounted. They may have replaced them at that time.
Re: Tire Shop Says All Sensors Bad. [Re: john_pifer] #5317826 01/09/20 03:18 PM
E
edyvw Offline
E
12 years? LOL, you are overdue for new sensors.
11' BMW 328i xDrive 6MT (BMW TPT 5W30+OE filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: Tire Shop Says All Sensors Bad. [Re: edyvw] #5317836 01/09/20 03:20 PM
Snagglefoot Offline
+1 Perfectly normal.
If you want the job done right......do it yourself.
Re: Tire Shop Says All Sensors Bad. [Re: john_pifer] #5317845 01/09/20 03:28 PM
Delta Offline
Kinda odd that two went dead at the same time, the system in these trucks is pretty darn sensitive and would have went off with just one. $60 a sensor is pretty darn cheap; has to be some aftermarket universal mumbo-jumbo. Had one replaced in my 09 due to a leak and even with discount it was $93 at my local shop (was aftermarket as well). The Toyota dealer would be expensive, maybe possibly another local shop that does tires can double check it for you.
'17 VW GTI 2.0T - 6MT - 19K - Edge 0w40
'15 Camry SE - 2.5 - 26K - PP 0w20
'09 Tacoma TRD Offroad 4x4 - 4.0 - 137K - RGT 5w30
Re: Tire Shop Says All Sensors Bad. [Re: john_pifer] #5317852 01/09/20 03:33 PM
U
Ursatdx Offline
U
Considering it would mean removing each wheel. Dismounting/mounting/repairing/balancing 5 tires/wheels.
I think $45 ea is a fair price (if done correctly).
"If there must be trouble, let it be in my day, that my child may have peace." --- Thomas Paine
Re: Tire Shop Says All Sensors Bad. [Re: john_pifer] #5317853 01/09/20 03:34 PM
sloinker Online Shocked
Online Shocked
The TPMS sensors are widely available for less than $20 each. You could always spend $40 at harbor freight and change your own sensors and then take it to a place for balancing and any programming if needed.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: Tire Shop Says All Sensors Bad. [Re: edyvw] #5317885 01/09/20 04:07 PM
H
HangFire Online Content
Online Content
H
I actually agree with edyvw!
Various musings: http://hangfire.net
Re: Tire Shop Says All Sensors Bad. [Re: john_pifer] #5317931 01/09/20 05:02 PM
2
2010Civic Offline
2
You don't need to remove the tire and rebalance it. You can just break the bead by the sensor and push the tire in while you swap the sensor out.
Also, the tire shop said 2 sensors were bad, not all of them.
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
Re: Tire Shop Says All Sensors Bad. [Re: john_pifer] #5317939 01/09/20 05:13 PM
dubber09 Offline
From what I know TPMS life span is 6-7 years on average but can be as long as 12 years. You are due.
Do them all at once or if due for tire change within 6 months or so - do them then since tires will be off anyway.
You can try TPMS reset by over inflating each tire including spare by 3-4 psi and then deflating all close to 0 and then inflating all to spec. This is free but time consuming.
Kia Sportage 2014 GDI 2.4L
Kia Forte 2014 MPI 1.8L
Re: Tire Shop Says All Sensors Bad. [Re: john_pifer] #5317941 01/09/20 05:16 PM
F
FordBroncoVWJeta Online Content
Online Content
F
Walmart does em for $30.
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2003 Ford Taurus 3.0 Vulcan
Re: Tire Shop Says All Sensors Bad. [Re: john_pifer] #5317950 01/09/20 05:25 PM
spasm3 Offline
1 or more are bad on my 13 Elantra. I don't really use need them as I regularly use a tire gauge.
Is there any way to get them to leave them out and not replace them when you get new tires?
I really don't want to pay $100-$160 for Tpms sensors on a small car.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Tire Shop Says All Sensors Bad. [Re: john_pifer] #5317961 01/09/20 05:35 PM
G
Gebo Offline
G
I'd replace them all. Including the spare.
I had one heckuva time with my GX470. I purchased Denso TPMS'a off Amazon thinking Denzo-Toyota-Lexus...no problem. Replaced all 5. Tire dealer did the syncing thing and I figure all is well. Two weeks later here come the codes.
I would check the tire pressures and then take my Blue Driver and erase all the codes. I did this too many times to remember.
I go back to the tire dealer a couple of months or so later and he said that had to take his Lexus to Lexus to get them to sync and he had to purchase TPMS's from the Lexus Dealer. My Lexus mechanic told me to bring my car to him, he would bring the "machine" home from work one night and then sync them for me at no charge (I'm a loyal customer).
He then calls me and says his machine won't recognize 2 of the 5 TPMS's. At this point, what do you do?
I ended up getting all 5 TPMS's from Lexus at about double the price of the Denso's off Amazon.
I am so thankful there has now been several months of not hearing my wife say, "That stupid light is on again."
I understand my case may be an extreme situation but from this point on, I am going to Lexus dealer to purchase mine. Hopefully 10-15 years from now.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
PP HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
